Hey!
I tried to make some kind of another sys-usb to attach the nitrokey (for the update process) to that VM.
So i detach the USB controllers from the sys-usb and attach them to the new VM.
But the new VM doesn’t start:
“unable to reset PCI device xyz no FLR, PM reset or bus reset available…”
Then I removed the USB controllers from the new VM and attached them back to the sys-usb.
But now the same result here. So I can not start sys-usb even after restart of the laptop.
So I went to settings of the sys-usb, then to devices, then “configure strict reset” and choose the PCI device which can not be reseted.
But I still get “unable to reset PCI device” +
“libxenlight failed to create new domain sys-usb”
#Edit: ah! If I choose all 3 devices, I can start the sys-usb
