How much are you swapping? I used the recipe here: Minimal templates | Qubes OS
and installed just these packages on top of it: `qubes-core-agent-networking, qubes-core-agent-network-manager and qubes-core-agent-dom0-updates (mirage-firewall doesn’t handle dom0 updates).
With X, memory utilization is roughly 300MB, including the 100MB swapped. Top memory hogs are Xorg, systemd-journal and nm-applet. If you are using xterm, xterm and qubes.StartApp also take a nice chunk of memory.
And I’m using debian-minimal, but I could try fedora to see if it’s better.
I run a debian-11-minimal based sys-net and haven’t removed X nor changed any swap configurations. I got the network manager icon in the tray and it’s fully functional and responsive. I gave sys-net 250MB memory and no maxmem (no memory balancing). The Qubes OS tray icon shows me the qube is actually only using 234MB and when I run top from within xterm I see …
So there is some swapping but it can’t be very frequent or impacting performance much. CPU load for sys-net is typically between 1-4% while e.g. playing a YouTube video. In some cases I’ve seen a little over 5%, but never more than 10%.
I doubt disabling X would improve this much and I’d loose the network manager tray icon (which is doubtless useful). Not in my wildest dreams would I consider giving sys-net 600MB … for what?
I moved to Mirage-firewall 0.8 (using a nightly build from a few days ago) which uses a fixed 64MB of RAM (no swapping and no balancing). Been quite happy so far.
That’s consistent with what I see - but I don’t use swap, and it doesn’t
seem to hit performance.
I do use some headless qubes, but not for memory saving.
If you’d like to try it, you can follow the instructions on that blog for the 0.7.1 build (the latest binary one) or, if you feel brave, try one of the nightly builds here: Job qubes-firewall on freebsd-12.
0.7.1 can only run in PV (due to a bug). The latest 0.8 nightly builds will run on PVH, which is better.
