OK it froze again…even with the template change.
Not sure when it happened but it was quick so journalctl is only about 125K in size. I can’t see anything obvious in it. First 700 or so lines in this post, the remainder in the next post.
Oct 21 21:46:31 localhost kernel: Linux version 6.18.55-1.qubes.fc41.x86_64 (mockbuild@0de3adfdd0f04e96b847a311284e143a) (gcc (GCC) 14.3.1 20251022 (Red Hat 14.3.1-4), GNU ld version 2.43.1-14.fc41) #1 SMP PREEMPT_DYNAMIC Sun Oct 11 12:53:27 UTC 2026
Oct 21 21:46:31 localhost kernel: Command line: systemd.machine_id=8e6c0906bae343bfb5e0b678e36b42b2 root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_privcmd.unrestricted xen_scrub_pages=0 apparmor=1 security=apparmor
Oct 21 21:46:31 localhost kernel: BIOS-provided physical RAM map:
Oct 21 21:46:31 localhost kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
Oct 21 21:46:31 localhost kernel: BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
Oct 21 21:46:31 localhost kernel: BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
Oct 21 21:46:31 localhost kernel: BIOS-e820: [mem 0x0000000000100000-0x000000005cbfefff] usable
Oct 21 21:46:31 localhost kernel: BIOS-e820: [mem 0x000000005cbff000-0x000000005cbfffff] reserved
Oct 21 21:46:31 localhost kernel: BIOS-e820: [mem 0x00000000fc000000-0x00000000fc00afff] ACPI NVS
Oct 21 21:46:31 localhost kernel: BIOS-e820: [mem 0x00000000fc00b000-0x00000000ffffffff] reserved
Oct 21 21:46:31 localhost kernel: NX (Execute Disable) protection: active
Oct 21 21:46:31 localhost kernel: APIC: Static calls initialized
Oct 21 21:46:31 localhost kernel: SMBIOS 2.4 present.
Oct 21 21:46:31 localhost kernel: DMI: Xen HVM domU, BIOS 4.19.5 10/14/2026
Oct 21 21:46:31 localhost kernel: DMI: Memory slots populated: 1/1
Oct 21 21:46:31 localhost kernel: Hypervisor detected: Xen HVM
Oct 21 21:46:31 localhost kernel: Xen version 4.19.
Oct 21 21:46:31 localhost kernel: platform_pci_unplug: Netfront and the Xen platform PCI driver have been compiled for this kernel: unplug emulated NICs.
Oct 21 21:46:31 localhost kernel: platform_pci_unplug: Blkfront and the Xen platform PCI driver have been compiled for this kernel: unplug emulated disks.
You might have to change the root device
from /dev/hd[a-d] to /dev/xvd[a-d]
in your root= kernel command line option
Oct 21 21:46:31 localhost kernel: HVMOP_pagetable_dying not supported
Oct 21 21:46:31 localhost kernel: tsc: Fast TSC calibration using PIT
Oct 21 21:46:31 localhost kernel: tsc: Detected 2802.934 MHz processor
Oct 21 21:46:31 localhost kernel: tsc: Detected 2803.194 MHz TSC
Oct 21 21:46:31 localhost kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Oct 21 21:46:31 localhost kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Oct 21 21:46:31 localhost kernel: last_pfn = 0x5cbff max_arch_pfn = 0x400000000
Oct 21 21:46:31 localhost kernel: MTRR map: 4 entries (3 fixed + 1 variable; max 19), built from 8 variable MTRRs
Oct 21 21:46:31 localhost kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Oct 21 21:46:31 localhost kernel: found SMP MP-table at [mem 0x000f5a40-0x000f5a4f]
Oct 21 21:46:31 localhost kernel: Using GB pages for direct mapping
Oct 21 21:46:31 localhost kernel: RAMDISK: [mem 0x5c4ce000-0x5cbeffff]
Oct 21 21:46:31 localhost kernel: ACPI: Early table checksum verification disabled
Oct 21 21:46:31 localhost kernel: ACPI: RSDP 0x00000000000F5990 000024 (v02 Xen )
Oct 21 21:46:31 localhost kernel: ACPI: XSDT 0x00000000FC00A660 000054 (v01 Xen HVM 00000000 HVML 00000000)
Oct 21 21:46:31 localhost kernel: ACPI: FACP 0x00000000FC00A370 0000F4 (v04 Xen HVM 00000000 HVML 00000000)
Oct 21 21:46:31 localhost kernel: ACPI: DSDT 0x00000000FC001040 0092A3 (v02 Xen HVM 00000000 INTL 20240322)
Oct 21 21:46:31 localhost kernel: ACPI: FACS 0x00000000FC001000 000040
Oct 21 21:46:31 localhost kernel: ACPI: APIC 0x00000000FC00A470 000080 (v02 Xen HVM 00000000 HVML 00000000)
Oct 21 21:46:31 localhost kernel: ACPI: HPET 0x00000000FC00A570 000038 (v01 Xen HVM 00000000 HVML 00000000)
Oct 21 21:46:31 localhost kernel: ACPI: WAET 0x00000000FC00A5B0 000028 (v01 Xen HVM 00000000 HVML 00000000)
Oct 21 21:46:31 localhost kernel: ACPI: SSDT 0x00000000FC00A5E0 000031 (v02 Xen HVM 00000000 INTL 20240322)
Oct 21 21:46:31 localhost kernel: ACPI: SSDT 0x00000000FC00A620 000031 (v02 Xen HVM 00000000 INTL 20240322)
Oct 21 21:46:31 localhost kernel: ACPI: Reserving FACP table memory at [mem 0xfc00a370-0xfc00a463]
Oct 21 21:46:31 localhost kernel: ACPI: Reserving DSDT table memory at [mem 0xfc001040-0xfc00a2e2]
Oct 21 21:46:31 localhost kernel: ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f]
Oct 21 21:46:31 localhost kernel: ACPI: Reserving APIC table memory at [mem 0xfc00a470-0xfc00a4ef]
Oct 21 21:46:31 localhost kernel: ACPI: Reserving HPET table memory at [mem 0xfc00a570-0xfc00a5a7]
Oct 21 21:46:31 localhost kernel: ACPI: Reserving WAET table memory at [mem 0xfc00a5b0-0xfc00a5d7]
Oct 21 21:46:31 localhost kernel: ACPI: Reserving SSDT table memory at [mem 0xfc00a5e0-0xfc00a610]
Oct 21 21:46:31 localhost kernel: ACPI: Reserving SSDT table memory at [mem 0xfc00a620-0xfc00a650]
Oct 21 21:46:31 localhost kernel: No NUMA configuration found
Oct 21 21:46:31 localhost kernel: Faking a node at [mem 0x0000000000000000-0x000000005cbfefff]
Oct 21 21:46:31 localhost kernel: NODE_DATA(0) allocated [mem 0x5c4a3280-0x5c4cdfff]
Oct 21 21:46:31 localhost kernel: Zone ranges:
Oct 21 21:46:31 localhost kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
Oct 21 21:46:31 localhost kernel: DMA32 [mem 0x0000000001000000-0x000000005cbfefff]
Oct 21 21:46:31 localhost kernel: Normal empty
Oct 21 21:46:31 localhost kernel: Device empty
Oct 21 21:46:31 localhost kernel: Movable zone start for each node
Oct 21 21:46:31 localhost kernel: Early memory node ranges
Oct 21 21:46:31 localhost kernel: node 0: [mem 0x0000000000001000-0x000000000009efff]
Oct 21 21:46:31 localhost kernel: node 0: [mem 0x0000000000100000-0x000000005cbfefff]
Oct 21 21:46:31 localhost kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000005cbfefff]
Oct 21 21:46:31 localhost kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Oct 21 21:46:31 localhost kernel: On node 0, zone DMA: 97 pages in unavailable ranges
Oct 21 21:46:31 localhost kernel: On node 0, zone DMA32: 13313 pages in unavailable ranges
Oct 21 21:46:31 localhost kernel: ACPI: PM-Timer IO Port: 0xb008
Oct 21 21:46:31 localhost kernel: IOAPIC[0]: apic_id 1, version 17, address 0xfec00000, GSI 0-47
Oct 21 21:46:31 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Oct 21 21:46:31 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 low level)
Oct 21 21:46:31 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 low level)
Oct 21 21:46:31 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 low level)
Oct 21 21:46:31 localhost kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Oct 21 21:46:31 localhost kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Oct 21 21:46:31 localhost kernel: TSC deadline timer available
Oct 21 21:46:31 localhost kernel: CPU topo: Max. logical packages: 1
Oct 21 21:46:31 localhost kernel: CPU topo: Max. logical dies: 1
Oct 21 21:46:31 localhost kernel: CPU topo: Max. dies per package: 1
Oct 21 21:46:31 localhost kernel: CPU topo: Max. threads per core: 1
Oct 21 21:46:31 localhost kernel: CPU topo: Num. cores per package: 4
Oct 21 21:46:31 localhost kernel: CPU topo: Num. threads per package: 4
Oct 21 21:46:31 localhost kernel: CPU topo: Allowing 4 present CPUs plus 0 hotplug CPUs
Oct 21 21:46:31 localhost kernel: [mem 0x5cc00000-0xfbffffff] available for PCI devices
Oct 21 21:46:31 localhost kernel: Booting paravirtualized kernel on Xen HVM
Oct 21 21:46:31 localhost kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
Oct 21 21:46:31 localhost kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
Oct 21 21:46:31 localhost kernel: percpu: Embedded 84 pages/cpu s221184 r8192 d114688 u524288
Oct 21 21:46:31 localhost kernel: pcpu-alloc: s221184 r8192 d114688 u524288 alloc=1*2097152
Oct 21 21:46:31 localhost kernel: pcpu-alloc: [0] 0 1 2 3
Oct 21 21:46:31 localhost kernel: xen: PV spinlocks enabled
Oct 21 21:46:31 localhost kernel: PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
Oct 21 21:46:31 localhost kernel: Kernel command line: systemd.machine_id=8e6c0906bae343bfb5e0b678e36b42b2 root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_privcmd.unrestricted xen_scrub_pages=0 apparmor=1 security=apparmor
Oct 21 21:46:31 localhost kernel: Booted with the nomodeset parameter. Only the system framebuffer will be available
Oct 21 21:46:31 localhost kernel: Unknown kernel command line parameters "rd_NO_PLYMOUTH", will be passed to user space.
Oct 21 21:46:31 localhost kernel: random: crng init done
Oct 21 21:46:31 localhost kernel: printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes
Oct 21 21:46:31 localhost kernel: Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Oct 21 21:46:31 localhost kernel: Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Oct 21 21:46:31 localhost kernel: Fallback order for Node 0: 0
Oct 21 21:46:31 localhost kernel: Built 1 zonelists, mobility grouping on. Total pages: 379805
Oct 21 21:46:31 localhost kernel: Policy zone: DMA32
Oct 21 21:46:31 localhost kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:on
Oct 21 21:46:31 localhost kernel: mem auto-init: clearing system memory may take some time...
Oct 21 21:46:31 localhost kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Oct 21 21:46:31 localhost kernel: ftrace: allocating 61949 entries in 244 pages
Oct 21 21:46:31 localhost kernel: ftrace: allocated 244 pages with 5 groups
Oct 21 21:46:31 localhost kernel: Dynamic Preempt: full
Oct 21 21:46:31 localhost kernel: rcu: Preemptible hierarchical RCU implementation.
Oct 21 21:46:31 localhost kernel: rcu: RCU event tracing is enabled.
Oct 21 21:46:31 localhost kernel: rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
Oct 21 21:46:31 localhost kernel: Trampoline variant of Tasks RCU enabled.
Oct 21 21:46:31 localhost kernel: Rude variant of Tasks RCU enabled.
Oct 21 21:46:31 localhost kernel: Tracing variant of Tasks RCU enabled.
Oct 21 21:46:31 localhost kernel: rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
Oct 21 21:46:31 localhost kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Oct 21 21:46:31 localhost kernel: RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Oct 21 21:46:31 localhost kernel: RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Oct 21 21:46:31 localhost kernel: RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Oct 21 21:46:31 localhost kernel: NR_IRQS: 524544, nr_irqs: 864, preallocated irqs: 16
Oct 21 21:46:31 localhost kernel: xen:events: Using FIFO-based ABI
Oct 21 21:46:31 localhost kernel: xen:events: Xen HVM callback vector for event delivery is enabled
Oct 21 21:46:31 localhost kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Oct 21 21:46:31 localhost kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
Oct 21 21:46:31 localhost kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
Oct 21 21:46:31 localhost kernel: Console: colour VGA+ 80x25
Oct 21 21:46:31 localhost kernel: printk: legacy console [hvc0] enabled
Oct 21 21:46:31 localhost kernel: ACPI: Core revision 20250807
Oct 21 21:46:31 localhost kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 30580167144 ns
Oct 21 21:46:31 localhost kernel: APIC: Switch to symmetric I/O mode setup
Oct 21 21:46:31 localhost kernel: x2apic enabled
Oct 21 21:46:31 localhost kernel: APIC: Switched APIC routing to: physical x2apic
Oct 21 21:46:31 localhost kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
Oct 21 21:46:31 localhost kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x28680a0def6, max_idle_ns: 440795345265 ns
Oct 21 21:46:31 localhost kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5606.38 BogoMIPS (lpj=2803194)
Oct 21 21:46:31 localhost kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Oct 21 21:46:31 localhost kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
Oct 21 21:46:31 localhost kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
Oct 21 21:46:31 localhost kernel: mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
Oct 21 21:46:31 localhost kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Oct 21 21:46:31 localhost kernel: Spectre V2 : Mitigation: Enhanced / Automatic IBRS
Oct 21 21:46:31 localhost kernel: ITS: Mitigation: Aligned branch/return thunks
Oct 21 21:46:31 localhost kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Oct 21 21:46:31 localhost kernel: Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
Oct 21 21:46:31 localhost kernel: Spectre V2 : Enabling IBPB for BPF
Oct 21 21:46:31 localhost kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Oct 21 21:46:31 localhost kernel: active return thunk: its_return_thunk
Oct 21 21:46:31 localhost kernel: Spectre V2 : Spectre BHI mitigation: SW BHB clearing on syscall and VM exit
Oct 21 21:46:31 localhost kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Oct 21 21:46:31 localhost kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Oct 21 21:46:31 localhost kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Oct 21 21:46:31 localhost kernel: x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
Oct 21 21:46:31 localhost kernel: x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
Oct 21 21:46:31 localhost kernel: x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
Oct 21 21:46:31 localhost kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Oct 21 21:46:31 localhost kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Oct 21 21:46:31 localhost kernel: x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
Oct 21 21:46:31 localhost kernel: x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
Oct 21 21:46:31 localhost kernel: x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
Oct 21 21:46:31 localhost kernel: x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
Oct 21 21:46:31 localhost kernel: x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
Oct 21 21:46:31 localhost kernel: Freeing SMP alternatives memory: 60K
Oct 21 21:46:31 localhost kernel: pid_max: default: 32768 minimum: 301
Oct 21 21:46:31 localhost kernel: LSM: initializing lsm=lockdown,capability,landlock,yama,apparmor,ima,evm
Oct 21 21:46:31 localhost kernel: landlock: Up and running.
Oct 21 21:46:31 localhost kernel: Yama: becoming mindful.
Oct 21 21:46:31 localhost kernel: AppArmor: AppArmor initialized
Oct 21 21:46:31 localhost kernel: Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Oct 21 21:46:31 localhost kernel: Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Oct 21 21:46:31 localhost kernel: clocksource: xen: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
Oct 21 21:46:31 localhost kernel: Xen: using vcpuop timer interface
Oct 21 21:46:31 localhost kernel: installing Xen timer for CPU 0
Oct 21 21:46:31 localhost kernel: smpboot: CPU0: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz (family: 0x6, model: 0x8c, stepping: 0x1)
Oct 21 21:46:31 localhost kernel: cpu 0 spinlock event irq 52
Oct 21 21:46:31 localhost kernel: Performance Events: unsupported CPU family 6 model 140 no PMU driver, software events only.
Oct 21 21:46:31 localhost kernel: signal: max sigframe size: 3632
Oct 21 21:46:31 localhost kernel: rcu: Hierarchical SRCU implementation.
Oct 21 21:46:31 localhost kernel: rcu: Max phase no-delay instances is 400.
Oct 21 21:46:31 localhost kernel: Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
Oct 21 21:46:31 localhost kernel: NMI watchdog: Perf NMI watchdog permanently disabled
Oct 21 21:46:31 localhost kernel: smp: Bringing up secondary CPUs ...
Oct 21 21:46:31 localhost kernel: installing Xen timer for CPU 1
Oct 21 21:46:31 localhost kernel: smpboot: x86: Booting SMP configuration:
Oct 21 21:46:31 localhost kernel: .... node #0, CPUs: #1
Oct 21 21:46:31 localhost kernel: installing Xen timer for CPU 2
Oct 21 21:46:31 localhost kernel: #2
Oct 21 21:46:31 localhost kernel: installing Xen timer for CPU 3
Oct 21 21:46:31 localhost kernel: #3
Oct 21 21:46:31 localhost kernel: cpu 1 spinlock event irq 65
Oct 21 21:46:31 localhost kernel: cpu 2 spinlock event irq 66
Oct 21 21:46:31 localhost kernel: cpu 3 spinlock event irq 67
Oct 21 21:46:31 localhost kernel: smp: Brought up 1 node, 4 CPUs
Oct 21 21:46:31 localhost kernel: smpboot: Total of 4 processors activated (22425.55 BogoMIPS)
Oct 21 21:46:31 localhost kernel: Memory: 1410996K/1519220K available (21715K kernel code, 4470K rwdata, 11080K rodata, 5660K init, 5200K bss, 96896K reserved, 0K cma-reserved)
Oct 21 21:46:31 localhost kernel: devtmpfs: initialized
Oct 21 21:46:31 localhost kernel: x86/mm: Memory block size: 128MB
Oct 21 21:46:31 localhost kernel: ACPI: PM: Registering ACPI NVS region [mem 0xfc000000-0xfc00afff] (45056 bytes)
Oct 21 21:46:31 localhost kernel: posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
Oct 21 21:46:31 localhost kernel: futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
Oct 21 21:46:31 localhost kernel: pinctrl core: initialized pinctrl subsystem
Oct 21 21:46:31 localhost kernel: PM: RTC time: 03:46:28, date: 2026-10-22
Oct 21 21:46:31 localhost kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Oct 21 21:46:31 localhost kernel: DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
Oct 21 21:46:31 localhost kernel: DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Oct 21 21:46:31 localhost kernel: DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Oct 21 21:46:31 localhost kernel: audit: initializing netlink subsys (disabled)
Oct 21 21:46:31 localhost kernel: audit: type=2000 audit(1792640788.444:1): state=initialized audit_enabled=0 res=1
Oct 21 21:46:31 localhost kernel: thermal_sys: Registered thermal governor 'fair_share'
Oct 21 21:46:31 localhost kernel: thermal_sys: Registered thermal governor 'bang_bang'
Oct 21 21:46:31 localhost kernel: thermal_sys: Registered thermal governor 'step_wise'
Oct 21 21:46:31 localhost kernel: thermal_sys: Registered thermal governor 'user_space'
Oct 21 21:46:31 localhost kernel: cpuidle: using governor menu
Oct 21 21:46:31 localhost kernel: PCI: Using configuration type 1 for base access
Oct 21 21:46:31 localhost kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Oct 21 21:46:31 localhost kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Oct 21 21:46:31 localhost kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Oct 21 21:46:31 localhost kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Oct 21 21:46:31 localhost kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Oct 21 21:46:31 localhost kernel: raid6: skipped pq benchmark and selected avx512x4
Oct 21 21:46:31 localhost kernel: raid6: using avx512x2 recovery algorithm
Oct 21 21:46:31 localhost kernel: ACPI: Added _OSI(Module Device)
Oct 21 21:46:31 localhost kernel: ACPI: Added _OSI(Processor Device)
Oct 21 21:46:31 localhost kernel: ACPI: Added _OSI(Processor Aggregator Device)
Oct 21 21:46:31 localhost kernel: ACPI: 3 ACPI AML tables successfully acquired and loaded
Oct 21 21:46:31 localhost kernel: ACPI: Interpreter enabled
Oct 21 21:46:31 localhost kernel: ACPI: PM: (supports S0 S3 S5)
Oct 21 21:46:31 localhost kernel: ACPI: Using IOAPIC for interrupt routing
Oct 21 21:46:31 localhost kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Oct 21 21:46:31 localhost kernel: PCI: Ignoring E820 reservations for host bridge windows
Oct 21 21:46:31 localhost kernel: ACPI: Enabled 2 GPEs in block 00 to 0F
Oct 21 21:46:31 localhost kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Oct 21 21:46:31 localhost kernel: acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI EDR HPX-Type3]
Oct 21 21:46:31 localhost kernel: acpi PNP0A03:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
Oct 21 21:46:31 localhost kernel: acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended configuration space under this bridge
Oct 21 21:46:31 localhost kernel: PCI host bridge to bus 0000:00
Oct 21 21:46:31 localhost kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
Oct 21 21:46:31 localhost kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
Oct 21 21:46:31 localhost kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Oct 21 21:46:31 localhost kernel: pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfbffffff window]
Oct 21 21:46:31 localhost kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Oct 21 21:46:31 localhost kernel: pci 0000:00:00.0: [8086:1237] type 00 class 0x060000 conventional PCI endpoint
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.0: [8086:7000] type 00 class 0x060100 conventional PCI endpoint
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.1: [8086:7010] type 00 class 0x010180 conventional PCI endpoint
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.1: BAR 4 [io 0x0000-0x000f]
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.1: BAR 0 [io 0x01f0-0x01f7]: legacy IDE quirk
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.1: BAR 1 [io 0x03f6]: legacy IDE quirk
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.1: BAR 2 [io 0x0170-0x0177]: legacy IDE quirk
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.1: BAR 3 [io 0x0376]: legacy IDE quirk
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.3: [8086:7113] type 00 class 0x068000 conventional PCI endpoint
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.3: quirk: [io 0xb000-0xb03f] claimed by PIIX4 ACPI
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.3: quirk: [io 0xb100-0xb10f] claimed by PIIX4 SMB
Oct 21 21:46:31 localhost kernel: pci 0000:00:02.0: [5853:0001] type 00 class 0xff8000 conventional PCI endpoint
Oct 21 21:46:31 localhost kernel: pci 0000:00:02.0: BAR 0 [io 0xc000-0xc0ff]
Oct 21 21:46:31 localhost kernel: pci 0000:00:02.0: BAR 1 [mem 0xf0000000-0xf0ffffff pref]
Oct 21 21:46:31 localhost kernel: pci 0000:00:04.0: [1234:1111] type 00 class 0x030000 conventional PCI endpoint
Oct 21 21:46:31 localhost kernel: pci 0000:00:04.0: BAR 0 [mem 0xf1000000-0xf1ffffff pref]
Oct 21 21:46:31 localhost kernel: pci 0000:00:04.0: BAR 2 [mem 0xf2016000-0xf2016fff]
Oct 21 21:46:31 localhost kernel: pci 0000:00:04.0: ROM [mem 0xf2000000-0xf200ffff pref]
Oct 21 21:46:31 localhost kernel: pci 0000:00:04.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Oct 21 21:46:31 localhost kernel: pci 0000:00:05.0: [8086:24cd] type 00 class 0x0c0320 conventional PCI endpoint
Oct 21 21:46:31 localhost kernel: pci 0000:00:05.0: BAR 0 [mem 0xf2017000-0xf2017fff]
Oct 21 21:46:31 localhost kernel: pci 0000:00:06.0: [8086:a0f0] type 00 class 0x028000 PCIe Root Complex Integrated Endpoint
Oct 21 21:46:31 localhost kernel: pci 0000:00:06.0: BAR 0 [mem 0x60f2010000-0x60f2013fff 64bit]
Oct 21 21:46:31 localhost kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 5
Oct 21 21:46:31 localhost kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 10
Oct 21 21:46:31 localhost kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 11
Oct 21 21:46:31 localhost kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 5
Oct 21 21:46:31 localhost kernel: xen:balloon: Initialising balloon driver
Oct 21 21:46:31 localhost kernel: iommu: Default domain type: Translated
Oct 21 21:46:31 localhost kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Oct 21 21:46:31 localhost kernel: SCSI subsystem initialized
Oct 21 21:46:31 localhost kernel: libata version 3.00 loaded.
Oct 21 21:46:31 localhost kernel: ACPI: bus type USB registered
Oct 21 21:46:31 localhost kernel: usbcore: registered new interface driver usbfs
Oct 21 21:46:31 localhost kernel: usbcore: registered new interface driver hub
Oct 21 21:46:31 localhost kernel: usbcore: registered new device driver usb
Oct 21 21:46:31 localhost kernel: pps_core: LinuxPPS API ver. 1 registered
Oct 21 21:46:31 localhost kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Oct 21 21:46:31 localhost kernel: PTP clock support registered
Oct 21 21:46:31 localhost kernel: EDAC MC: Ver: 3.0.0
Oct 21 21:46:31 localhost kernel: NetLabel: Initializing
Oct 21 21:46:31 localhost kernel: NetLabel: domain hash size = 128
Oct 21 21:46:31 localhost kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
Oct 21 21:46:31 localhost kernel: NetLabel: unlabeled traffic allowed by default
Oct 21 21:46:31 localhost kernel: mctp: management component transport protocol core
Oct 21 21:46:31 localhost kernel: NET: Registered PF_MCTP protocol family
Oct 21 21:46:31 localhost kernel: PCI: Using ACPI for IRQ routing
Oct 21 21:46:31 localhost kernel: PCI: pci_cache_line_size set to 64 bytes
Oct 21 21:46:31 localhost kernel: pci 0000:00:06.0: BAR 0 [mem 0x60f2010000-0x60f2013fff 64bit]: can't claim; no compatible bridge window
Oct 21 21:46:31 localhost kernel: e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
Oct 21 21:46:31 localhost kernel: e820: reserve RAM buffer [mem 0x5cbff000-0x5fffffff]
Oct 21 21:46:31 localhost kernel: pci 0000:00:04.0: vgaarb: setting as boot VGA device
Oct 21 21:46:31 localhost kernel: pci 0000:00:04.0: vgaarb: bridge control possible
Oct 21 21:46:31 localhost kernel: pci 0000:00:04.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Oct 21 21:46:31 localhost kernel: vgaarb: loaded
Oct 21 21:46:31 localhost kernel: hpet: 3 channels of 0 reserved for per-cpu timers
Oct 21 21:46:31 localhost kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
Oct 21 21:46:31 localhost kernel: hpet0: 3 comparators, 64-bit 62.500000 MHz counter
Oct 21 21:46:31 localhost kernel: clocksource: Switched to clocksource xen
Oct 21 21:46:31 localhost kernel: VFS: Disk quotas dquot_6.6.0
Oct 21 21:46:31 localhost kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Oct 21 21:46:31 localhost kernel: AppArmor: AppArmor Filesystem Enabled
Oct 21 21:46:31 localhost kernel: pnp: PnP ACPI init
Oct 21 21:46:31 localhost kernel: system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
Oct 21 21:46:31 localhost kernel: system 00:01: [io 0x08a0-0x08a3] has been reserved
Oct 21 21:46:31 localhost kernel: system 00:01: [io 0x0cc0-0x0ccf] has been reserved
Oct 21 21:46:31 localhost kernel: system 00:01: [io 0x04d0-0x04d1] has been reserved
Oct 21 21:46:31 localhost kernel: pnp 00:04: [dma 2]
Oct 21 21:46:31 localhost kernel: system 00:05: [io 0xae00-0xae0f] has been reserved
Oct 21 21:46:31 localhost kernel: system 00:05: [io 0xb044-0xb047] has been reserved
Oct 21 21:46:31 localhost kernel: pnp: PnP ACPI: found 6 devices
Oct 21 21:46:31 localhost kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Oct 21 21:46:31 localhost kernel: NET: Registered PF_INET protocol family
Oct 21 21:46:31 localhost kernel: IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
Oct 21 21:46:31 localhost kernel: tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
Oct 21 21:46:31 localhost kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Oct 21 21:46:31 localhost kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
Oct 21 21:46:31 localhost kernel: TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
Oct 21 21:46:31 localhost kernel: TCP: Hash tables configured (established 16384 bind 16384)
Oct 21 21:46:31 localhost kernel: MPTCP token hash table entries: 2048 (order: 4, 49152 bytes, linear)
Oct 21 21:46:31 localhost kernel: UDP hash table entries: 1024 (order: 4, 65536 bytes, linear)
Oct 21 21:46:31 localhost kernel: UDP-Lite hash table entries: 1024 (order: 4, 65536 bytes, linear)
Oct 21 21:46:31 localhost kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Oct 21 21:46:31 localhost kernel: NET: Registered PF_XDP protocol family
Oct 21 21:46:31 localhost kernel: pci 0000:00:06.0: BAR 0 [mem 0xf2000000-0xf2003fff 64bit]: assigned
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.1: BAR 4 [io 0x1000-0x100f]: assigned
Oct 21 21:46:31 localhost kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
Oct 21 21:46:31 localhost kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
Oct 21 21:46:31 localhost kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Oct 21 21:46:31 localhost kernel: pci_bus 0000:00: resource 7 [mem 0xf0000000-0xfbffffff window]
Oct 21 21:46:31 localhost kernel: pci 0000:00:01.0: PIIX3: Enabling Passive Release
Oct 21 21:46:31 localhost kernel: pci 0000:00:00.0: Limiting direct PCI/PCI transfers
Oct 21 21:46:31 localhost kernel: PCI: CLS 0 bytes, default 64
Oct 21 21:46:31 localhost kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x28680a0def6, max_idle_ns: 440795345265 ns
Oct 21 21:46:31 localhost kernel: clocksource: Switched to clocksource tsc
Oct 21 21:46:31 localhost kernel: Trying to unpack rootfs image as initramfs...
Oct 21 21:46:31 localhost kernel: Initialise system trusted keyrings
Oct 21 21:46:31 localhost kernel: Key type blacklist registered
Oct 21 21:46:31 localhost kernel: workingset: timestamp_bits=36 max_order=19 bucket_order=0
Oct 21 21:46:31 localhost kernel: integrity: Platform Keyring initialized
Oct 21 21:46:31 localhost kernel: integrity: Machine keyring initialized
Oct 21 21:46:31 localhost kernel: cryptd: max_cpu_qlen set to 1000
Oct 21 21:46:31 localhost kernel: NET: Registered PF_ALG protocol family
Oct 21 21:46:31 localhost kernel: xor: automatically using best checksumming function avx
Oct 21 21:46:31 localhost kernel: Key type asymmetric registered
Oct 21 21:46:31 localhost kernel: Asymmetric key parser 'x509' registered
Oct 21 21:46:31 localhost kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
Oct 21 21:46:31 localhost kernel: io scheduler mq-deadline registered
Oct 21 21:46:31 localhost kernel: io scheduler kyber registered
Oct 21 21:46:31 localhost kernel: io scheduler bfq registered
Oct 21 21:46:31 localhost kernel: atomic64_test: passed for x86-64 platform with CX8 and with SSE
Oct 21 21:46:31 localhost kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
Oct 21 21:46:31 localhost kernel: ACPI: button: Power Button [PWRF]
Oct 21 21:46:31 localhost kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSLPBN:00/input/input1
Oct 21 21:46:31 localhost kernel: ACPI: button: Sleep Button [SLPF]
Oct 21 21:46:31 localhost kernel: xen:grant_table: Grant tables using version 1 layout
Oct 21 21:46:31 localhost kernel: Grant table initialized
Oct 21 21:46:31 localhost kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Oct 21 21:46:31 localhost kernel: Freeing initrd memory: 7304K
Oct 21 21:46:31 localhost kernel: Non-volatile memory driver v1.3
Oct 21 21:46:31 localhost kernel: Linux agpgart interface v0.103
Oct 21 21:46:31 localhost kernel: ACPI: bus type drm_connector registered
Oct 21 21:46:31 localhost kernel: ata_piix 0000:00:01.1: enabling device (0000 -> 0001)
Oct 21 21:46:31 localhost kernel: scsi host0: ata_piix
Oct 21 21:46:31 localhost kernel: scsi host1: ata_piix
Oct 21 21:46:31 localhost kernel: ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0x1000 irq 14 lpm-pol 0
Oct 21 21:46:31 localhost kernel: ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0x1008 irq 15 lpm-pol 0
Oct 21 21:46:31 localhost kernel: usbcore: registered new interface driver usbserial_generic
Oct 21 21:46:31 localhost kernel: usbserial: USB Serial support registered for generic
Oct 21 21:46:31 localhost kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Oct 21 21:46:31 localhost kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Oct 21 21:46:31 localhost kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Oct 21 21:46:31 localhost kernel: mousedev: PS/2 mouse device common for all mice
Oct 21 21:46:31 localhost kernel: rtc_cmos PNP0B00:00: registered as rtc0
Oct 21 21:46:31 localhost kernel: rtc_cmos PNP0B00:00: setting system clock to 2026-10-22T03:46:29 UTC (1792640789)
Oct 21 21:46:31 localhost kernel: rtc_cmos PNP0B00:00: alarms up to one day, 114 bytes nvram
Oct 21 21:46:31 localhost kernel: device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
Oct 21 21:46:31 localhost kernel: device-mapper: uevent: version 1.0.3
Oct 21 21:46:31 localhost kernel: device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
Oct 21 21:46:31 localhost kernel: intel_pstate: CPU model not supported
Oct 21 21:46:31 localhost kernel: hid: raw HID events driver (C) Jiri Kosina
Oct 21 21:46:31 localhost kernel: usbcore: registered new interface driver usbhid
Oct 21 21:46:31 localhost kernel: usbhid: USB HID core driver
Oct 21 21:46:31 localhost kernel: drop_monitor: Initializing network drop monitor service
Oct 21 21:46:31 localhost kernel: Initializing XFRM netlink socket
Oct 21 21:46:31 localhost kernel: NET: Registered PF_INET6 protocol family
Oct 21 21:46:31 localhost kernel: Segment Routing with IPv6
Oct 21 21:46:31 localhost kernel: RPL Segment Routing with IPv6
Oct 21 21:46:31 localhost kernel: In-situ OAM (IOAM) with IPv6
Oct 21 21:46:31 localhost kernel: mip6: Mobile IPv6
Oct 21 21:46:31 localhost kernel: NET: Registered PF_PACKET protocol family
Oct 21 21:46:31 localhost kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
Oct 21 21:46:31 localhost kernel: IPI shorthand broadcast: enabled
Oct 21 21:46:31 localhost kernel: sched_clock: Marking stable (778004776, 91062367)->(1096841113, -227773970)
Oct 21 21:46:31 localhost kernel: registered taskstats version 1
Oct 21 21:46:31 localhost kernel: Loading compiled-in X.509 certificates
Oct 21 21:46:31 localhost kernel: Loaded X.509 cert 'Build time autogenerated kernel key: d2f740251455c8aca962e0f5c19ce4e61abce8ba'
Oct 21 21:46:31 localhost kernel: Demotion targets for Node 0: null
Oct 21 21:46:31 localhost kernel: page_owner is disabled
Oct 21 21:46:31 localhost kernel: Key type .fscrypt registered
Oct 21 21:46:31 localhost kernel: Key type fscrypt-provisioning registered
Oct 21 21:46:31 localhost kernel: Btrfs loaded, zoned=yes, fsverity=yes
Oct 21 21:46:31 localhost kernel: Key type big_key registered
Oct 21 21:46:31 localhost kernel: Key type encrypted registered
Oct 21 21:46:31 localhost kernel: AppArmor: AppArmor sha256 policy hashing enabled
Oct 21 21:46:31 localhost kernel: ima: No TPM chip found, activating TPM-bypass!
Oct 21 21:46:31 localhost kernel: Loading compiled-in module X.509 certificates
Oct 21 21:46:31 localhost kernel: ima: Allocated hash algorithm: sha256
Oct 21 21:46:31 localhost kernel: ima: No architecture policies found
Oct 21 21:46:31 localhost kernel: evm: Initialising EVM extended attributes:
Oct 21 21:46:31 localhost kernel: evm: security.selinux
Oct 21 21:46:31 localhost kernel: evm: security.SMACK64 (disabled)
Oct 21 21:46:31 localhost kernel: evm: security.SMACK64EXEC (disabled)
Oct 21 21:46:31 localhost kernel: evm: security.SMACK64TRANSMUTE (disabled)
Oct 21 21:46:31 localhost kernel: evm: security.SMACK64MMAP (disabled)
Oct 21 21:46:31 localhost kernel: evm: security.apparmor
Oct 21 21:46:31 localhost kernel: evm: security.ima
Oct 21 21:46:31 localhost kernel: evm: security.capability
Oct 21 21:46:31 localhost kernel: evm: HMAC attrs: 0x1
Oct 21 21:46:31 localhost kernel: alg: No test for 842 (842-scomp)
Oct 21 21:46:31 localhost kernel: xenbus_probe_frontend: Device with no driver: device/vbd/51712
Oct 21 21:46:31 localhost kernel: xenbus_probe_frontend: Device with no driver: device/vbd/51728
Oct 21 21:46:31 localhost kernel: xenbus_probe_frontend: Device with no driver: device/vbd/51744
Oct 21 21:46:31 localhost kernel: xenbus_probe_frontend: Device with no driver: device/vbd/51760
Oct 21 21:46:31 localhost kernel: PM: Magic number: 14:230:766
Oct 21 21:46:31 localhost kernel: acpi LNXCPU:5a: hash matches
Oct 21 21:46:31 localhost kernel: RAS: Correctable Errors collector initialized.
Oct 21 21:46:31 localhost kernel: clk: Disabling unused clocks
Oct 21 21:46:31 localhost kernel: PM: genpd: Disabling unused power domains
Oct 21 21:46:31 localhost kernel: Freeing unused decrypted memory: 2028K
Oct 21 21:46:31 localhost kernel: Freeing unused kernel image (initmem) memory: 5660K
Oct 21 21:46:31 localhost kernel: Write protecting the kernel read-only data: 34816k
Oct 21 21:46:31 localhost kernel: Freeing unused kernel image (text/rodata gap) memory: 812K
Oct 21 21:46:31 localhost kernel: Freeing unused kernel image (rodata/data gap) memory: 1208K
Oct 21 21:46:31 localhost kernel: Run /init as init process
Oct 21 21:46:31 localhost kernel: with arguments:
Oct 21 21:46:31 localhost kernel: /init
Oct 21 21:46:31 localhost kernel: rd_NO_PLYMOUTH
Oct 21 21:46:31 localhost kernel: with environment:
Oct 21 21:46:31 localhost kernel: HOME=/
Oct 21 21:46:31 localhost kernel: TERM=linux
Oct 21 21:46:31 localhost kernel: blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
Oct 21 21:46:31 localhost kernel: xvda: xvda1 xvda2 xvda3
Oct 21 21:46:31 localhost kernel: blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
Oct 21 21:46:31 localhost kernel: blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
Oct 21 21:46:31 localhost kernel: blkfront: xvdd: barrier or flush: disabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
Oct 21 21:46:31 localhost kernel: xvdc: xvdc1 xvdc3
Oct 21 21:46:31 localhost kernel: input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input4
Oct 21 21:46:31 localhost kernel: EXT4-fs (xvda3): mounted filesystem 2864b5f8-39b3-4502-a02f-42867dcb69de r/w with ordered data mode. Quota mode: none.
Oct 21 21:46:31 localhost kernel: EXT4-fs (xvdd): mounting ext3 file system using the ext4 subsystem
Oct 21 21:46:31 localhost kernel: EXT4-fs (xvdd): mounted filesystem 1c83f4ad-ff71-4a34-80aa-eb73fc32f22d ro with ordered data mode. Quota mode: none.
Oct 21 21:46:31 localhost systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
Oct 21 21:46:31 localhost systemd[1]: Detected virtualization xen.
Oct 21 21:46:31 localhost systemd[1]: Detected architecture x86-64.
Oct 21 21:46:31 localhost systemd[1]: No hostname configured, using default hostname.
Oct 21 21:46:31 localhost systemd[1]: Hostname set to <localhost>.
Oct 21 21:46:31 localhost systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
Oct 21 21:46:31 localhost systemd[1]: /usr/lib/systemd/system/qubes-gui-agent.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
Oct 21 21:46:31 localhost systemd[1]: Queued start job for default target multi-user.target.
Oct 21 21:46:31 localhost systemd[1]: Created slice system-getty.slice - Slice /system/getty.
Oct 21 21:46:31 localhost systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
Oct 21 21:46:31 localhost systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
Oct 21 21:46:31 localhost systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
Oct 21 21:46:31 localhost systemd[1]: Created slice user.slice - User and Session Slice.
Oct 21 21:46:31 localhost systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
Oct 21 21:46:31 localhost systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
Oct 21 21:46:31 localhost systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
Oct 21 21:46:31 localhost systemd[1]: Expecting device dev-hvc0.device - /dev/hvc0...
Oct 21 21:46:31 localhost systemd[1]: Expecting device dev-xvdb.device - /dev/xvdb...
Oct 21 21:46:31 localhost systemd[1]: Expecting device dev-xvdc1.device - /dev/xvdc1...
Oct 21 21:46:31 localhost systemd[1]: Reached target remote-fs.target - Remote File Systems.
Oct 21 21:46:31 localhost systemd[1]: Reached target slices.target - Slice Units.
Oct 21 21:46:31 localhost systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
Oct 21 21:46:31 localhost systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
Oct 21 21:46:31 localhost systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
Oct 21 21:46:31 localhost systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
Oct 21 21:46:31 localhost systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
Oct 21 21:46:31 localhost systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
Oct 21 21:46:31 localhost systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
Oct 21 21:46:31 localhost systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
Oct 21 21:46:31 localhost systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
Oct 21 21:46:31 localhost systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
Oct 21 21:46:31 localhost systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
Oct 21 21:46:31 localhost systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
Oct 21 21:46:31 localhost systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
Oct 21 21:46:31 localhost systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
Oct 21 21:46:31 localhost systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
Oct 21 21:46:31 localhost systemd[1]: Starting blk-availability.service - Availability of block devices...
Oct 21 21:46:31 localhost systemd[1]: Starting dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early...
Oct 21 21:46:31 localhost systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
Oct 21 21:46:31 localhost systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Oct 21 21:46:31 localhost systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
Oct 21 21:46:31 localhost systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
Oct 21 21:46:31 localhost systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
Oct 21 21:46:31 localhost systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
Oct 21 21:46:31 localhost systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-journald.service - Journal Service...
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
Oct 21 21:46:31 localhost systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
Oct 21 21:46:31 localhost systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
Oct 21 21:46:31 localhost systemd[1]: Finished blk-availability.service - Availability of block devices.
Oct 21 21:46:31 localhost systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
Oct 21 21:46:31 localhost systemd[1]: modprobe@configfs.service: Deactivated successfully.
Oct 21 21:46:31 localhost systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
Oct 21 21:46:31 localhost systemd[1]: modprobe@drm.service: Deactivated successfully.
Oct 21 21:46:31 localhost systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
Oct 21 21:46:31 localhost systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
Oct 21 21:46:31 localhost systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
Oct 21 21:46:31 localhost systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
Oct 21 21:46:31 localhost kernel: fuse: init (API version 7.45)
Oct 21 21:46:31 localhost systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
Oct 21 21:46:31 localhost kernel: Adding 1048572k swap on /dev/xvdc1. Priority:-2 extents:1 across:1048572k SS
Oct 21 21:46:31 localhost systemd[1]: Condition check resulted in dev-xvdc1.swap - /dev/xvdc1 being skipped.
Oct 21 21:46:31 localhost systemd[1]: Unnecessary job was removed for dev-xvdc1.device - /dev/xvdc1.
Oct 21 21:46:31 localhost systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
Oct 21 21:46:31 localhost systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
Oct 21 21:46:31 localhost systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
Oct 21 21:46:31 localhost systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
Oct 21 21:46:31 localhost systemd[1]: dev-xvdc1-swap.service: Deactivated successfully.
Oct 21 21:46:31 localhost systemd[1]: Finished dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early.
Oct 21 21:46:31 localhost systemd[1]: modprobe@fuse.service: Deactivated successfully.
Oct 21 21:46:31 localhost systemd-journald[251]: Collecting audit messages is disabled.
Oct 21 21:46:31 localhost systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
Oct 21 21:46:31 localhost systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
Oct 21 21:46:31 localhost systemd[1]: Reached target swap.target - Swaps.
Oct 21 21:46:31 localhost systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
Oct 21 21:46:31 localhost systemd[1]: systemd-fsck-root.service - File System Check on Root Device skipped, unmet condition check ConditionPathIsReadWrite=!/
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
Oct 21 21:46:31 localhost kernel: lp: driver loaded but no devices found
Oct 21 21:46:31 localhost systemd-journald[251]: Journal started
Oct 21 21:46:31 localhost systemd-journald[251]: Runtime Journal (/run/log/journal/8e6c0906bae343bfb5e0b678e36b42b2) is 3.4M, max 27.7M, 24.3M free.
Oct 21 21:46:31 localhost systemd-modules-load[252]: Inserted module 'lp'
Oct 21 21:46:31 localhost systemd[1]: Started systemd-journald.service - Journal Service.
Oct 21 21:46:31 localhost systemd-modules-load[252]: Inserted module 'ppdev'
Oct 21 21:46:31 localhost kernel: ppdev: user-space parallel port driver
Oct 21 21:46:31 localhost systemd-modules-load[252]: Inserted module 'parport_pc'
Oct 21 21:46:31 localhost systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
Oct 21 21:46:31 localhost kernel: EXT4-fs (xvda3): re-mounted 2864b5f8-39b3-4502-a02f-42867dcb69de.
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
Oct 21 21:46:31 localhost systemd-modules-load[252]: Inserted module 'xen_evtchn'
Oct 21 21:46:31 localhost kernel: xen:xen_evtchn: Event-channel device installed
Oct 21 21:46:31 localhost systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-journal-flush.service - Flush Journal to Persistent Storage...
Oct 21 21:46:31 localhost systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival skipped, unmet condition check ConditionDirectoryNotEmpty=/sys/fs/pstore
Oct 21 21:46:31 localhost systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
Oct 21 21:46:31 localhost systemd-modules-load[252]: Inserted module 'xen_blkback'
Oct 21 21:46:31 localhost systemd-modules-load[252]: Inserted module 'xen_gntalloc'
Oct 21 21:46:31 localhost systemd-modules-load[252]: Inserted module 'xen_gntdev'
Oct 21 21:46:31 localhost systemd-modules-load[252]: Inserted module 'xen_privcmd'
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully.
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
Oct 21 21:46:31 localhost systemd[1]: Starting qubes-db.service - Qubes DB agent...
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
Oct 21 21:46:31 localhost systemd[1]: systemd-sysusers.service - Create System Users skipped, no trigger condition checks were met.
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
Oct 21 21:46:31 localhost systemd[1]: Finished lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Oct 21 21:46:31 localhost systemd-journald[251]: Time spent on flushing to /var/log/journal/8e6c0906bae343bfb5e0b678e36b42b2 is 5.276ms for 563 entries.
Oct 21 21:46:31 localhost systemd-journald[251]: System Journal (/var/log/journal/8e6c0906bae343bfb5e0b678e36b42b2) is 8M, max 1.9G, 1.9G free.
Oct 21 21:46:31 localhost systemd-journald[251]: Received client request to flush runtime journal.
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
Oct 21 21:46:31 localhost systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
Oct 21 21:46:31 localhost systemd[1]: Set up automount efi.automount - EFI System Partition Automount.
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
Oct 21 21:46:31 localhost systemd-sysctl[295]: Couldn't write '1' to 'kernel/unprivileged_userns_clone', ignoring: No such file or directory
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-journal-flush.service - Flush Journal to Persistent Storage.
Oct 21 21:46:31 localhost systemd[1]: Started qubes-db.service - Qubes DB agent.
Oct 21 21:46:31 localhost systemd[1]: Starting qubes-sysinit.service - Init Qubes Services settings...
Oct 21 21:46:31 localhost systemd-udevd[300]: Using default interface naming scheme 'v257'.
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
Oct 21 21:46:31 localhost systemd[1]: Finished qubes-sysinit.service - Init Qubes Services settings.
Oct 21 21:46:31 localhost systemd[1]: Starting qubes-rootfs-resize.service - Adjust root filesystem size...
Oct 21 21:46:31 localhost systemd[1]: qubes-setup-minimal-vm.service - Apply minimal vm runtime configuration skipped, no trigger condition checks were met.
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-timesyncd.service - Network Time Synchronization...
Oct 21 21:46:31 localhost systemd-udevd[300]: /usr/lib/udev/rules.d/90-alsa-restore.rules:18 GOTO="alsa_restore_std" has no matching label, ignoring.
Oct 21 21:46:31 localhost systemd-udevd[300]: /usr/lib/udev/rules.d/90-alsa-restore.rules:18 The line has no effect any more, dropping.
Oct 21 21:46:31 localhost systemd-udevd[300]: /usr/lib/udev/rules.d/90-alsa-restore.rules:22 GOTO="alsa_restore_std" has no matching label, ignoring.
Oct 21 21:46:31 localhost systemd-udevd[300]: /usr/lib/udev/rules.d/90-alsa-restore.rules:22 The line has no effect any more, dropping.
Oct 21 21:46:31 localhost resize-rootfs-if-needed.sh[338]: dumpe2fs 1.47.2 (1-Jan-2025)
Oct 21 21:46:31 localhost systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
Oct 21 21:46:31 localhost systemd[1]: Started systemd-timesyncd.service - Network Time Synchronization.
Oct 21 21:46:31 localhost systemd[1]: Reached target time-set.target - System Time Set.
Oct 21 21:46:31 localhost systemd[1]: Found device dev-hvc0.device - /dev/hvc0.
Oct 21 21:46:31 localhost resize-rootfs-if-needed.sh[370]: dumpe2fs 1.47.2 (1-Jan-2025)
Oct 21 21:46:31 localhost systemd[1]: Found device dev-xvdb.device - /dev/xvdb.
Oct 21 21:46:31 localhost systemd[1]: Starting systemd-fsck@dev-xvdb.service - File System Check on /dev/xvdb...
Oct 21 21:46:31 localhost resize-rootfs-if-needed.sh[332]: root filesystem already at 41525248 blocks
Oct 21 21:46:31 localhost systemd[1]: Finished qubes-rootfs-resize.service - Adjust root filesystem size.
Oct 21 21:46:31 localhost systemd-fsck[385]: fsck.ext2: Bad magic number in super-block while trying to open /dev/xvdb
Oct 21 21:46:31 localhost systemd-fsck[385]: /dev/xvdb:
Oct 21 21:46:31 localhost systemd-fsck[385]: The superblock could not be read or does not describe a valid ext2/ext3/ext4
Oct 21 21:46:31 localhost systemd-fsck[385]: filesystem. If the device is valid and it really contains an ext2/ext3/ext4
Oct 21 21:46:31 localhost systemd-fsck[385]: filesystem (and not swap or ufs or something else), then the superblock
Oct 21 21:46:31 localhost systemd-fsck[385]: is corrupt, and you might try running e2fsck with an alternate superblock:
Oct 21 21:46:31 localhost systemd-fsck[385]: e2fsck -b 8193 <device>
Oct 21 21:46:31 localhost systemd-fsck[385]: or
Oct 21 21:46:31 localhost systemd-fsck[385]: e2fsck -b 32768 <device>
Oct 21 21:46:31 localhost systemd-fsck[377]: fsck failed with exit status 8.
Oct 21 21:46:31 localhost systemd-fsck[377]: Ignoring error.
Oct 21 21:46:31 localhost systemd[1]: Finished systemd-fsck@dev-xvdb.service - File System Check on /dev/xvdb.
Oct 21 21:46:31 localhost systemd[1]: Starting qubes-mount-dirs.service - Initialize and mount /rw and /home...
Oct 21 21:46:31 localhost kernel: input: PC Speaker as /devices/platform/pcspkr/input/input5
Oct 21 21:46:31 localhost kernel: piix4_smbus 0000:00:01.3: SMBus Host Controller not enabled!
Oct 21 21:46:31 localhost kernel: FDC 0 is a S82078B
Oct 21 21:46:31 localhost kernel: ehci-pci 0000:00:05.0: EHCI Host Controller
Oct 21 21:46:31 localhost kernel: ehci-pci 0000:00:05.0: new USB bus registered, assigned bus number 1
Oct 21 21:46:31 localhost kernel: ehci-pci 0000:00:05.0: irq 39, io mem 0xf2017000
Oct 21 21:46:31 localhost kernel: ehci-pci 0000:00:05.0: USB 2.0 started, EHCI 1.00
Oct 21 21:46:31 localhost kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
Oct 21 21:46:31 localhost kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Oct 21 21:46:31 localhost kernel: usb usb1: Product: EHCI Host Controller
Oct 21 21:46:31 localhost kernel: usb usb1: Manufacturer: Linux 6.18.55-1.qubes.fc41.x86_64 ehci_hcd
Oct 21 21:46:31 localhost kernel: usb usb1: SerialNumber: 0000:00:05.0
Oct 21 21:46:31 localhost kernel: hub 1-0:1.0: USB hub found
Oct 21 21:46:31 localhost kernel: hub 1-0:1.0: 6 ports detected
Oct 21 21:46:31 localhost mount-dirs.sh[388]: Virgin boot of the VM: creating private.img filesystem on /dev/xvdb
Oct 21 21:46:31 localhost systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
Oct 21 21:46:31 localhost mount-dirs.sh[388]: Private device management: checking /dev/xvdb
Oct 21 21:46:31 localhost mount-dirs.sh[388]: Private device management: fsck.ext4 of /dev/xvdb succeeded
Oct 21 21:46:31 localhost kernel: EXT4-fs (xvdb): mounted filesystem e7af063e-6c7a-4f79-95f8-c6661615de49 r/w without journal. Quota mode: none.
Oct 21 21:46:31 localhost mount-dirs.sh[409]: Checking /rw
Oct 21 21:46:31 localhost mount-dirs.sh[409]: Private device size management: enlarging /dev/xvdb
Oct 21 21:46:31 localhost mount-dirs.sh[409]: Private device size management: resize2fs of /dev/xvdb succeeded
Oct 21 21:46:31 localhost mount-dirs.sh[409]: Virgin boot of the VM: populating /rw/config
Oct 21 21:46:31 localhost mount-dirs.sh[409]: Virgin boot of the VM: populating /rw/usrlocal from /usr/local.orig
Oct 21 21:46:31 localhost mount-dirs.sh[409]: Finished checking /rw
Oct 21 21:46:31 localhost mount-dirs.sh[387]: initialize_home: populating /rw/home
Oct 21 21:46:31 localhost kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Oct 21 21:46:31 localhost kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Oct 21 21:46:31 localhost kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Oct 21 21:46:31 localhost kernel: cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
Oct 21 21:46:31 localhost kernel: Error: Driver 'pcspkr' is already registered, aborting...
Oct 21 21:46:31 localhost mount-dirs.sh[387]: initialize_home: populating ifneeded /rw/home/user from /etc/skel
Oct 21 21:46:31 localhost mount-dirs.sh[387]: initialize_home: adjusting permissions ifneeded on /rw/home/user
Oct 21 21:46:31 localhost systemd[1]: Reload requested from client PID 444 ('systemctl') (unit qubes-mount-dirs.service)...
Oct 21 21:46:31 localhost systemd[1]: Reloading...
