Actually the real question what I was trying to ask “Does sys-gui increase attack surface via covert channels.”
My impression is that it should not increase this but I rely on your wisdom for answering it as I obviously may be wrong.
Well, in the part that explains " Why make a GUI domain at all?" it does sound far from increasing attack surface.
Yes, I can confirm this. The dispvm is displayed in the dom0 Manager and it stays visible after shutting it down.
I mentioned this because an SR-IOV/GVT-g solution involves ‘splitting’ a single GPU up into as many sub-PCI devices as you want, then assign the split GPUs to VMs that require 2D/3D accel, this significantly increases risk of exploitation but would allow for hardware based video decoding (H264/HEVC and VP9) for example, meaning dat smooth smooth YouTube experience without CPU at 67823564%
Note: I understand most people don’t use Qubes for Media Consumption etc
I suspect the only real way to solve this is open GPU hardware that runs RISC-V or something, where the Qube’s team can inspect firmware.
Note: Below has nothing to do with SR-IOV/GVT-g
In the GUI Domain @marmarek mentions
In the perfect world, we could simply connect the graphics card to the VM as a PCI device and enjoy a new, more comfortable level of separation. Unfortunately, the world of computer hardware is very far from a perfect one. This solution works only very rarely.
I somewhat disagree, indeed there are many, many GPUs on the market, but I would argue most Qubes users are running on Laptops with 1 single integrated GPU, seeing as though there are only 2 major CPU Manufacturers (Intel and AMD), a GPU Pass-through solution that supported only these 2 manufacturers would suffice.
I ain’t running Qubes on laptop with integrated GPU. Even I have 4 colleagues with somewhat like my configuration for running Qubes. So your thought may be biased here.
Things which are broken for me after 4-5 days of testing-
While operating from dom0 command line-
qubes.ClipboardPaste
qubes-manager while using dispVM only
While operating from sys-gui session-
Playing Audio and Video files
Although I think It’s not yet ready, so these will be handled in future PR maybe. Thought that I should provide feedback @fepitre.
xss-lock and qubes-manager crashes are also there sometimes by using either method.
( My policy file can not be implemented with proper functioning but that’s user specific issue
Thank you for all for your feedback. Please note that we follow threads but not replying all the time. Mostly it’s like “qubes-issues”. We know it’s here
@panati, there is now a new category for discussions of the upcoming 4.1 release. I’ve moved this topic there.
Good to know!
I have a test setup where I set sys-gui as global but can only use it from dom0 and not when logging in to a GuiVM session only.
I guess you have enough to do already but if you find the time and if you are willing to share some insight it would be welcome.
Also, I am curious about sys-gui-gpu as well.
I recently tried sys-gui. I am having same issues like @panati. But I think no development have been done since last time.
What happen since then ? Did something change since the last post ? Is everything working normally now ?
@adw this link is now broken. Can you add a redirect to Xfce templates | Qubes OS (which I’m guessing is the correct link)?
Fixed. Thanks!
