Sys-gui-gpu blackscreen
Hello, I’ve been working on sys-gui-gpu for a while now, however, I’m not sure if I’m doing it wrong. During my setup, I faced a black screen issue every time I try to boot up sys-gui-gpu. My solution was to block i915 using kernel parameter module_blacklist=i915. Is there any other way to make sys-gui-gpu work without blocking the graphics driver? or is this a necessary undocumented step?
This and two other topics were started and not answered. I have the same problem, so I’m reviving.
I’m on an X230 with a new install of 4.2.2*. I followed the exact instructions for installing sys-gui-gpu, but I’m getting a black screen. I had to prevent autostart to recover the machine. Anyone currently using sys-gui-gpu that has it working?
*I did update and install a couple minimal templates. Nothing else.
