I have issue with Sweethome3D, i have tried running it in multi App Qubes & tried running it on its own yet all with the same result.
Running 4VCPU and 3000 to 8000memory yet still i have blackout issues where the screen looks like darkmode yet messed up no can read stuff etc, very weird, any help much appreciated please?
Latest App Qube currently used is Debian 13 and i have tried downloading Sweethome3d via the CLI and using the software package both with same results.
Try to see if you can change rendering options. It may be due to the lack of GPU rendering, the fallback is using a virtual GPU called “llvmpipe” which uses the CPU, but it may not have all the GPU capabilities and may produce artifacts.
how can i do that please as when i open up the sweethome3d its close to impossible to navigate around?
Also if i did by miracle find such an option then where would the option be located & what would i change it to?
Also i note that in the app qube settings i dont see sweethome3d existing, however if i go to Terminal and type in sweethome3d then if spins up straight away which confuse me as i never see that before method?
