Try enabling balancing, and lowering the max and init memory. I was playing around with the memory settings, they might have been lower than default.
Disabling memory balancing does more for me. I can achieve an average of 3.2s with memory balancing turned off. However, I think the OPās test scenario should be with memory balancing turned on.
Iām fine with variations as long as theyāre clearly marked so people can compare, like what @51lieal did with SSD-4k.
In fact, itās nice to see this topic slowly morph into a thread on how to min-max qube startup times. I think as Qubes evolves, this metric will become increasingly important, since the logical conclusion of its compartmentalization-via-VM approach to security is to have a fresh VM for every little taskāso how quickly a computer can spin up a new instance will be key. Even without this extreme, the usability of Qubes (as your daily driver at least) is strongly connected to how fast your computer can spin up VMs.
So a big thank you to all who have contributed so farāplease keep at it! Iād contribute if I had anything to give, but this isnāt my field
I got interesting results running R4.2 Alpha on BTRFS and 4kn drive. The installer of R4.2 has new enough cryptsetup that can automatically select appropriate sector size. So I just need to switch my NVMe drive to 4kn mode ( using another LBA format sector size ).
So, booting debian-11-minimal without memory balancing, with its memory set to 400MB, takes ~2.5s. This is better than any previous results with different NVMe drives on my machine. Specifically, itās ~0.6s faster than another BTRFS R4.2, which is installed on an identical drive, but without 4kn.
Now, the time between me clicking on the application launcher and chromiumās window showing up, is less than 5 seconds. And my laptopās specs are far from āpowerfulā!
So for anyone interested in testing R4.2 and BTRFS, enabling 4kn mode perhaps will speed up your VMs booting!
There will be BTRFS optimization landing in kernel 6.3, and Iām hoping for another leap in performance.
try also 4kn template, i made the guide somewhere here, it should speed up vm by some ![]()
also since this fresh install, can you try 4kn drive with lvm ? is it still not fixed ?
i also found that amd is way faster than intel (boot speed), my current i7-10750h vs ryzen 5 5600h.
i havent do any benchmark
Thanks for your guide! Iād love to try 4kn+lvm, but I just restored a ton of VMs ( to fully transit from 4.1 to 4.2, to enjoy the lightning speed
), so maybe Iāll try 4kn+lvm when I get a spare nvme drive.
Anyway, my previous install was lvm without 4kn, and VM boot time is 1.5 seconds longer than my install of btrfs without 4kn. So I doubt whether 4kn+lvm will have performance gains conpared to 4kn+brtfs.
Iāll build 4kn templates to test if they will boot even faster. I read somewhere that btrfs treats the underlying fsās sector size differently from lvm does. Given that 4kn templates do help in booting faster on lvm ( from your posts ) , itās really worth investigating whether 4kn templates will boot faster than legacy templates, on brtfs.
I did some benchmarks on my main laptop before I converted it from tLVM to Btrfs-on-4k-luks. They are crude in that the only startup time measured is for Debian VM start + Firefox. However, I did also record VM shutdown times, and my experience is these really affect system performance when you are busily working on your system⦠the tLVM snapshot operations at shutdown hammer the dom0 storage layer often for 7+ seconds for medium sized volumes.
My plan is to re-do the benchmarks before long, so the restored VM volumes are still similar enough to make a fair comparison.
@tasket Great to see you again! Sorry for (temporarily) hijacking the thread, but Iām a long-time user of the tools youāve written for Qubesāe.g. halt-vm-by-window, system-stats-xen, and more importantly, vm-boot-protect. I recommend the various scripts in this Github repo to just about anyone looking to have a more fluid Qubes experienceāespecially halt-vm-by-window.
Thank you very much for making tools that I use tensāmaybe hundreds of times a day.
Ā
Anyways, the reason Iām reaching out is because Iāve noticed that since R4.1, vm-boot-protect tends to fail when booting up. I know Iām not supposed to use it with disposables, but I have since R4.0 without issue⦠until R4.1. Now, thereās a high probability that a terminal window appears with a warning that vm-boot-protect was triggered and that the bad private files are in /mnt/xdvb (not accurate; recalling from memory).
Iād hugely appreciate it if you updated your tools for R4.1 (or even R4.2).
With the work you and others are doing, a sub-1-second boot seems to be a fast-approaching reality. Hopefully with some template-side-tweaks (or even a native specialized template like debian-15-quick) this should be attainable within a few years.
Maybe I should start a thread asking people for ideas about what could be done with thisāi.e. how to leverage the almost-negligible cost of booting (and shutting down) a VM to make Qubes more secure and more usable.
@fiftyfourthparallel Hi FFP! Feel free to open an issue when something like this happens. FWIW, when I upgraded to 4.1, I just kept using the same tools that are already there. Qubes-VM-hardening did get an update to the dom0 instructions.
Perhaps these two possibilities are relevant:
The idea of preloaded-dispVMs are nice, but both threads seem to indicate that the idea isnāt actively being worked on.
Either way, the thread Iām proposing is another one of my idea threads where people just throw things out there and hopefully something inspires someone. Kind of like my āNow youāre thinking with Qubesā thread. Might as well just go ahead and post it instead of navel-gazing.
Thanks, Iāll be sure to look at the changes once I have time.
I think my findings that I separately published in Speeing up VM startups will also be interesting to people here.
The āhave minimal RAM to speed-up startupā is because thereās wasteful (cpu-time wise) clearing of already clear VM pages. I filed a ticket: Wasteful memory clearing at start of every (standard) qube kernel Ā· Issue #8228 Ā· QubesOS/qubes-issues Ā· GitHub
Add kernel option init_on_free=off to your vm kernel options with something like this (this rewrites the options, but I imagine nobody has them set nowadays anyway):
qvm-prefs -s YOUR-VM-NAME kernelopts "init_on_free=off"
I measured 3+ seconds savings in the boot time on gen8 i7 cpu using the default 4G maxmem qube. slower CPUs will benefit more than faster ones.
The ādonāt include in memory balancingā seems to be related to this:
[ 2.327810] xen:balloon: Waiting for initial ballooning down having finished.
[ 3.058150] xen:balloon: Initial ballooning down finished.
so you basically donāt load this balloon driver and get the savings from its init. Somebody could look into what the init does and actually optimize it I guess. Again slower CPUs benefit more here. but other factors seem to have big impact too. free xen ram?
[ 1.309210] xen:balloon: Waiting for initial ballooning down having finished.
[ 7.153167] xen:balloon: Initial ballooning down finished.
There are preset kernelopts for sys-gui and I set them for all qubes (zswap.enabled=0, for example while using zram-tools), but itās not a problem to actually add your option to existing ones. Disabling balooning indeed dramatically increases overall performance., including boot time.
My best debian-11-minimal boot time so far is 4.05s
while hero numbers are good, for day to day usability the normal times should be consistently low too.
Disabling balloon (if you donāt increase the initial RAM) also cuts your memory to init from 4G to 400M, but thatās not very realistic amount to run something like e.g. firefox nowadays I imagine.
Of course. Manually setting each qubeās RAM is a part of Qubesā setting routine. My services run with 300-800MB, while browser qubes runs on 2048MB. Nothing more than that except Win11 qube with 2118MB.
Sys-gui-gpu runs with 1000MB.
well, manually setting RAM is quite limiting in many cases. Sharing memory in general is good as that makes things faster.
Now of course every VM running their own kernel they cannot share crucial stuff like caches, so itās quite a bit of waste, though with fast NVMe may be the cache is not all that much needed and could be dialed down substantially inside the VMs (I just looked into a random sampling of my VMs and I have substantial pagecaches there, sometimes in gigabytes, which probably means Xen balloon driver assumes the VM really needs a lot more memory than it actually does?), despite the āfree ram is wasted ramā adage, it might not apply as well in case of qubes situation and keeping healthy amount of Xen RAM free comes a long way to speed up VMs startup. Iāll probably have to experiment some in this area, and thisis is probably getting somewhat offtopic for this particular thread.
Is it the Snapshot operation or the blkdiscard? Or both?
B
What Tasketās describing matches what I experience whenever I shut down a large VM (>100GB). The time for the shutdown operation to end is multiples longer than VMs with negligble storage (e.g. sys-net). However I think this can be sidestepped by compartmentalizing VMs or treating larger VMs as exceptions.
@kindagreen I donāt think your theses and experiments are off-topic at all (see this post)āI eagerly await your experiment results!
Also, this thread has reached 100 posts after 2.5 yearsāThatās a staggering 40 posts per year! Hopefully, with a combination of hardware advances, optimizations, and ingenuity, we can get boot times down to 1 second within the next hundred posts, and show the moderators what a good return on moderating investment looks like.
