I’m using Corsairs 8k polling mouse and keyboard and the experience is less than normal. The mouse has hard time moving across the screen moving at a few pixels at a time. The keyboard wont input normally it takes a half second for each keystroke to register. This happens after doing any updates or using dom0 for a little while. At startup this problem doesn’t exist. Also restarting sys-usb solves the issue for a couple minutes. IDK if is something im doing, im new at qubes. Thanks for the fun learning experience and security.
Any related messages in the logs of sys-usb?
Would not be surprised if it is the same “control queue full” bug
Where are the logs for sys-usb. I do notice the cpu and ram usage skyrocket.
Try right click on the qube in Qube Manager.
