Starting Qubes fails during resize
I resized first private and then system storage. Before starting the qube I did an update which failed for the same reason the qube does not start anymore. Does anyone has an idea what to do.
Log below
[2024-11-29 10:36:42] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@dm_mod.service.[0m - Load Kernel Module dm_mod.
[2024-11-29 10:36:42] [ 3.734475] audit: type=1130 audit(1732873001.991:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=modprobe@dm_mod comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
[2024-11-29 10:36:42] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@efi_pstore.service.[0m - Load Kernel Module efi_pstore.
[2024-11-29 10:36:42] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@loop.service.[0m - Load Kernel Module loop.
[2024-11-29 10:36:42] [ 3.896293] EXT4-fs (xvdb): mounted filesystem 378ec956-1a52-41f3-91d9-5ddf0868b184 r/w with ordered data mode. Quota mode: none.
[2024-11-29 10:36:42] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-mount-dirs.service.[0m …Initialize and mount /rw and /home.
[2024-11-29 10:36:44] [.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (4s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (4s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (5s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (5s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (6s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (6s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (7s / no limit)
.[K[ .[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (8s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (8s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (9s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (9s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (10s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (11s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (11s / no limit)
.[K[.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (12s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (12s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (13s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (13s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (14s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (15s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (15s / no limit)
.[K[ .[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (16s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (16s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (17s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (18s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (19s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (19s / no limit)
.[K[.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (20s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (20s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (21s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (22s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (23s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (23s / no limit)
.[K[ .[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (24s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (25s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (25s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (26s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (27s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (27s / no limit)
.[K[.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (28s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (28s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (29s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (29s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (30s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (30s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (31s / no limit)
.[K[ .[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (31s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (32s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (32s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (33s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (34s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (34s / no limit)
.[K[.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (35s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (35s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (36s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (36s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (37s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (37s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (38s / no limit)
.[K[ .[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (38s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (39s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (39s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (40s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (41s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (41s / no limit)
.[K[.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (42s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (42s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (43s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (43s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (44s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (44s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (45s / no limit)
.[K[ .[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (45s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (46s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (46s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (47s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (48s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (48s / no limit)
.[K[.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (49s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (49s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (50s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (50s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (51s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (51s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (52s / no limit)
.[K[ .[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (52s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m] Job qubes-rootfs-resize.service/start running (53s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m*.[0m] Job qubes-rootfs-resize.service/start running (53s / no limit)
.[K[ .[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (54s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (55s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (55s / no limit)
.[K[.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (56s / no limit)
.[K[.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (56s / no limit)
.[K[.[0;31m*.[0;1;31m*.[0m.[0;31m* .[0m] Job qubes-rootfs-resize.service/start running (57s / no limit)
This is a known bug. Temporarily increase the qrexec_timeout. For more info:
