Can I use split gpg within a standalone VM? I have a standalone development VM. I need to check in code, develop, commit, sign, etc. I don’t see how to use the split gpg system from within the standalone VM. Or, maybe I’m approaching this wrong. Is there a better way I should set this up?
Split GPG can work in a standalone VM but you need to have the qubes os tools installed. If you make a standalone from a template available in Qubes OS, it should works.
I see. I didn’t do that but I will give that a shot. Thanks!
