Hello,
Trying to experiment with using a ProxyVM for VPN usage. The template is a standalone OS
and is set to provide the network. When attempting to connect to the ProxyVM using the correct
ip settings on the ClientVM, it returns destination host unreachable after calling the ping command.
not sure if this setup is even possible but when using a traditional template, it works fine.
