With a setup of
vault: fedora-43-minimal
client: debian-13/fedora-43-xfce
No KeePassXC.
This fails by default with The agent has no identities. in the client VM.
Any hints why? I can’t see any logs showing up in the vault VM (journalctl -f).
It seems that this needs an update as per this comment here.
I am having a similar problem as this user mentioned here.
I’ve described my problem here. It seems that troubleshooting requires an intimate knowledge of ssh-agent and how it interacts with GUI vs. command line.
Edit: I was able to find a temporary solution to my problem by modifying ~/.ssh/config as described in a comment on this guide. In short it was partially a connectivity issue as well as the communication with the VM having been affected (from what I can tell, most seem to be using the KeepassXC form of the setup, not the built-in password utility).
converted the SVG to PNG with white background. I realized that the transparent SVG didn’t work well with discourse’s dark mode (also I think it’s better to keep the data local to the forum in case the Git repo gets changed)
updated links to doc.qubes-os.org (for now, the old links auto-redirect but better to use the correct link target)
updated screenshots to reflect the “new” way of creating AppVMs in Qubes
rewrote the policy part to use the easier to use “Qubes OS Policy Editor” instead of the CLI approach
replaced gedit for file modifications because it isn’t preinstalled in the (default) XFCE variant of the templates
fixed the hyperlinks to different sections in the guide
fixed a bit of markdown syntax that broke numbering of enumeration items during edit
re-ordered the instruction steps. If you want the KeePassXC variant, there’s no need for ssh-askpass and configuration of it
changed ssh-askpass-gnome in Debian install instructions to ssh-askpass. Note that I neither use the variant without KeePassXC nor Debian templates at all, therefore I can’t easily check if everything works fine. However, there have been some comments in the past about this Gnome-specific package and it doesn’t make sense in the default XFCE-based templates.
Some of the recent comments state that the ssh-askpass-based approach might still be flawed.
I can however confirm that the KeePassXC variant still works in Qubes 4.3 using this guide.
