Hello.
After some tinkering with a Windows 7 template, I wanted to reclaim about 10 GBs of space, since Qube Manager and lvs were showing about 25 GBs of usage, whereas I actually have been using about 15 GB.
The first thought was to fill the free space with zeroes, remove the filler and --dig-holes with fallocate as the Community Docs suggest. There were two attempts for this:
- using Sysinternals SDelete directly in Windows
mounting the LV in a disposable VM, filling it with
dd if=/dev/zeroand removing the filler
Not only none of these methods worked but it looks like I made things worse - the LV appears to be completely occupied:
[user@dom0 ~]$ sudo lvs | grep -E 'vm-windows-7-root|Data%'
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
vm-windows-7-root qubes_dom0 Vwi-a-tz-- <74.51g vm-pool vm-windows-7-root-1676301574-back 99.90
vm-windows-7-root-1675851219-back qubes_dom0 Vwi-a-tz-- <74.51g vm-pool 35.72
vm-windows-7-root-1676301574-back qubes_dom0 Vwi-a-tz-- <74.51g vm-pool vm-windows-7-root-1675851219-back 35.72
Do we have a standard operating procedure for these situations that I missed?
There is a guide on that already but it covers only the case of sparsifying .img files.
I’d really appreciate some hints. Thank you in advance.
