Someone succesfully installed Qubes OS on a Surface Pro 9?
Hello members. Have someone successfully installed Qubes 4.3 on a Surface Pro 9, with Intel processor?
I successfully installed Qubes OS. Everything works well, but i can’t use the Surface keyboard to unlock my full disk encryption during boot. It is not working. I used an external keyboard to decrypt and then the Surface Keyboard works from login. Any solution to make the Surface Keyboard work before decryption?
Open Xfce4-terminal in Dom0 and do:
sudo nano /etc/dracut.conf.d/surface.conf
#Add this line to the file:
add_drivers+=" intel_lpss intel_lpss_pci surface_hid_core surface_hid surface_aggregator_registry surface_aggregator_hub surface_aggregator hid_multitouch "
Save and close the file.
In Dom0 run:
sudo dracut --force --regenerate-all
Now it should work after reboot.
