Hello, I want to install few programs through flatpak, but when I restart PC all of my flatpak packages are deleted. The same happened also for snaps but I stopped using them.
What can I do?
Thank you for help.
What can I do?
Thank you for help.
Hello, THANK YOU. I will try using --user and see if it will delete it.
For snaps, try installing it on both the template and appVM before installing individual apps.
Yes, I read it.
Paskalo helped me fix it. I had to always use flatpak –user. After that they don’t delete on restart.
Ah. Perfect! Then this may be something missing from the documentation.
The docs are user-contributed, meaning that if you spot something missing, you can submit a change and in turn that will help others not have to go though it.
If you think this is needed in the docs, I encourage you to fix them
