Hello community,
R4.1 has a nice little xterm(-like) terminal window whenever i work with qubes-dom0-update.
Unfortunately the font is really small. Is there a way i can switch to another terminal software or append something like ‘-fs 18 -fa Monospace’ to the ‘xterm’ call?
You can:
- use xfce4-terminal in dom0, or
- put
! Use a truetype font and size.
xterm*faceName: Monospace
xterm*faceSize: 18
in /home/user/.Xresources, save it and restart Xterm and/or reboot Qubes.
Thanks!
I’m already using the default dom0 terminal (xfce4-terminal), so that didn’t work.
But editing /home/user/.Xresources in the UpdateVM did the trick!
