Today I noticed that my internet is slow. I ran some speed tests. Instead of 100, I’m only getting about 10 Mbps.
I’ve ruled out all possible sources of error.
I restarted the router.
I restarted sys-firewall and sys-net.
I measured the speed using another computer. Everything is fine there.
I switched the router ports.
I also ran a speed test on sys-net. The problem exists directly on sys-net as well.
Where can I look for more information?
I saw with ip -s link show that there are a lot of dropped and missed entries.
I put the host into suspended mode and then brought it back online. Now the internet speed is working again. How can I figure out what caused this? Which log files should I check?
ip -s link show shows 0 again for missed. Only dropped is not 0. But that doesn’t seem to have any effect.
Could it be your network adapter doing strange things?
Perhaps use something like ethtool to check/control its connection speed. You can also see “Speed” in connection information - right click the NetworkManager Applet icon.
