Set up a ProxyVM as a VPN gateway using iptables and CLI scripts with ProtonVPN
I followed the second part of this guide: Contents/docs/configuration/vpn.md at master · Qubes-Community/Contents · GitHub , “Set up a ProxyVM as a VPN gateway using iptables and CLI scripts”.
As far as I know ProtonVPN provides its own DNS when a client is connected to their servers, and I thought that Qubes OS was trying to use another DNS provider, and I thought this was the source of the problem. I’m not sure :sweat_smile:
I used ping protonvpn.com and error ping: protonvpn.com: Temporary failure in name resolution occured. So I thought the issue was with DNS.
Sorry if something I say is inaccurate, I’m new to Qubes OS.
Thank you and all other Qubes OS team members.
That’s certainly an issue with DNS.
I don’t use ProtonVPN.
I’ll get back to you tomorrow.
OK,Thank you.
That’s very kind of you.
Bonjour,
sys-net → sys-vpn → Sys-firewall → Appvm
Créer une Appvm proxy nommer sys-vpn (cocher “provides network” et ajouter “network-manager” dans les services )
Installer dans le template de la sys-vpn la jolie interface de protonvpn :
Personnellement je préfére passer par le CLI
Si ça peut aider
Hello,
Create a proxy Appvm named sys-vpn (check “provides network” and add “network-manager” in services)
Install in the template of the sys-vpn the nice interface of protonvpn :
Personally I prefer to use the CLI
If it can help
