Set default compression level of backups
I have found that compression level of backups can be set using CLI. However is there any way to specify a default level, which is used every time when creating a backup? I didn’t find an option to specify compression level in “Qube Manager”.
The compression algorithm and Level could not be set via GUI tools at the moment. It is a work in progress.
if it helps, I made a benchmark to compare the size / time of different compression algorithms and level
I see, thank you for the information, I understand this, and is there any environment variable which I can change or some configuration to set some default / system - wide value for it, or not yet?
No. Not yet. The only option is the CLI argument method.
It has been on my TODO list. It was pending the decision on this patch which was merged 3 days ago. Hopefully I can start working on it this week.
