Yes I am paranoid, but can someone confirm if I have been compromised.
There is a qube I never created and isnt seen in my qube manager, disp-3495, here are some screenshots of the logfile.
Thanks
[2024-03-10 12:54:47] Logfile Opened [2024-03-10 12:54:47] [ 0.000000] Linux version 6.1.75-1.qubes.fc37.x86_64 (mockbuild@1f4ed5afad374392acdd235ec9b45589) (gcc (GCC) 12.3.1 20230508 (Red Hat 12.3.1-1), GNU ld version 2.38-27.fc37) #1 SMP PREEMPT_DYNAMIC Sun Jan 28 04:11:17 GMT 2024 [2024-03-10 12:54:47] [ 0.000000] Command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_scrub_pages=0 swiotlb=2048 selinux=1 security=selinux [2024-03-10 12:54:47] [ 0.000000] BIOS-provided physical RAM map: [2024-03-10 12:54:47] [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable [2024-03-10 12:54:47] [ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved [2024-03-10 12:54:47] [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000018ffffff] usable [2024-03-10 12:54:47] [ 0.000000] BIOS-e820: [mem 0x00000000fc000000-0x00000000fc00803f] ACPI data [2024-03-10 12:54:47] [ 0.000000] BIOS-e820: [mem 0x00000000feff8000-0x00000000feffffff] reserved [2024-03-10 12:54:47] [ 0.000000] NX (Execute Disable) protection: active [2024-03-10 12:54:47] [ 0.000000] DMI not present or invalid. [2024-03-10 12:54:47] [ 0.000000] Hypervisor detected: Xen HVM [2024-03-10 12:54:47] [ 0.000000] Xen version 4.17. [2024-03-10 12:54:47] [ 0.193639] tsc: Fast TSC calibration failed [2024-03-10 12:54:47] [ 0.193643] tsc: Detected 1895.999 MHz processor [2024-03-10 12:54:47] [ 0.193667] last_pfn = 0x19000 max_arch_pfn = 0x400000000 [2024-03-10 12:54:47] [ 0.193729] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT [2024-03-10 12:54:47] [ 0.201853] Using GB pages for direct mapping [2024-03-10 12:54:47] [ 0.202005] RAMDISK: [mem 0x05001000-0x0614efff] [2024-03-10 12:54:47] [ 0.202111] ACPI: Early table checksum verification disabled [2024-03-10 12:54:47] [ 0.202113] ACPI: RSDP 0x00000000FC008000 000024 (v02 Xen ) [2024-03-10 12:54:47] [ 0.202118] ACPI: XSDT 0x00000000FC007F60 000034 (v01 Xen HVM 00000000 HVML 00000000) [2024-03-10 12:54:47] [ 0.202124] ACPI: FACP 0x00000000FC007D60 00010C (v05 Xen HVM 00000000 HVML 00000000) [2024-03-10 12:54:47] [ 0.202129] ACPI: DSDT 0x00000000FC001040 006C9B (v05 Xen HVM 00000000 INTL 20220331) [2024-03-10 12:54:47] [ 0.202132] ACPI: FACS 0x00000000FC001000 000040 [2024-03-10 12:54:47] [ 0.202135] ACPI: FACS 0x00000000FC001000 000040 [2024-03-10 12:54:47] [ 0.202138] ACPI: APIC 0x00000000FC007E70 00003C (v02 Xen HVM 00000000 HVML 00000000) [2024-03-10 12:54:47] [ 0.202140] ACPI: Reserving FACP table memory at [mem 0xfc007d60-0xfc007e6b] [2024-03-10 12:54:47] [ 0.202142] ACPI: Reserving DSDT table memory at [mem 0xfc001040-0xfc007cda] [2024-03-10 12:54:47] [ 0.202143] ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f] [2024-03-10 12:54:47] [ 0.202144] ACPI: Reserving FACS table memory at [mem 0xfc001000-0xfc00103f] [2024-03-10 12:54:47] [ 0.202145] ACPI: Reserving APIC table memory at [mem 0xfc007e70-0xfc007eab] [2024-03-10 12:54:47] [ 0.202292] No NUMA configuration found [2024-03-10 12:54:47] [ 0.202293] Faking a node at [mem 0x0000000000000000-0x0000000018ffffff] [2024-03-10 12:54:47] [ 0.202303] NODE_DATA(0) allocated [mem 0x18fd5000-0x18ffffff] [2024-03-10 12:54:47] [ 0.203448] Zone ranges: [2024-03-10 12:54:47] [ 0.203450] DMA [mem 0x0000000000001000-0x0000000000ffffff] [2024-03-10 12:54:47] [ 0.203452] DMA32 [mem 0x0000000001000000-0x0000000018ffffff] [2024-03-10 12:54:47] [ 0.203453] Normal empty [2024-03-10 12:54:47] [ 0.203454] Device empty [2024-03-10 12:54:47] [ 0.203455] Movable zone start for each node [2024-03-10 12:54:47] [ 0.203457] Early memory node ranges [2024-03-10 12:54:47] [ 0.203458] node 0: [mem 0x0000000000001000-0x000000000009ffff] [2024-03-10 12:54:47] [ 0.203459] node 0: [mem 0x0000000000100000-0x0000000018ffffff] [2024-03-10 12:54:47] [ 0.203461] Initmem setup node 0 [mem 0x0000000000001000-0x0000000018ffffff] [2024-03-10 12:54:47] [ 0.203468] On node 0, zone DMA: 1 pages in unavailable ranges [2024-03-10 12:54:47] [ 0.203503] On node 0, zone DMA: 96 pages in unavailable ranges [2024-03-10 12:54:47] [ 0.204861] On node 0, zone DMA32: 28672 pages in unavailable ranges [2024-03-10 12:54:47] [ 0.204974] ACPI: No IOAPIC entries present [2024-03-10 12:54:47] [ 0.204975] ACPI: Using ACPI for processor (LAPIC) configuration information [2024-03-10 12:54:47] [ 0.204977] TSC deadline timer available [2024-03-10 12:54:47] [ 0.204986] smpboot: Allowing 2 CPUs, 0 hotplug CPUs [2024-03-10 12:54:47] [ 0.204993] [mem 0x19000000-0xfbffffff] available for PCI devices [2024-03-10 12:54:47] [ 0.204999] Booting kernel on Xen PVH [2024-03-10 12:54:47] [ 0.205000] Xen version: 4.17.3 [2024-03-10 12:54:47] [ 0.205002] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns [2024-03-10 12:54:47] [ 0.211157] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:2 nr_cpu_ids:2 nr_node_ids:1 [2024-03-10 12:54:47] [ 0.211266] percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u1048576 [2024-03-10 12:54:47] [ 0.211298] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear) [2024-03-10 12:54:47] [ 0.211302] Fallback order for Node 0: 0 [2024-03-10 12:54:47] [ 0.211304] Built 1 zonelists, mobility grouping on. Total pages: 100544 [2024-03-10 12:54:47] [ 0.211305] Policy zone: DMA32 [2024-03-10 12:54:47] [ 0.211306] Kernel command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_scrub_pages=0 swiotlb=2048 selinux=1 security=selinux [2024-03-10 12:54:47] [ 0.211340] Booted with the nomodeset parameter. Only the system framebuffer will be available [2024-03-10 12:54:47] [ 0.211448] Unknown kernel command line parameters “rd_NO_PLYMOUTH”, will be passed to user space. [2024-03-10 12:54:47] [ 0.211488] random: crng init done [2024-03-10 12:54:47] [ 0.211510] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [2024-03-10 12:54:47] [ 0.211522] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [2024-03-10 12:54:47] [ 0.211651] mem auto-init: stack:all(zero), heap alloc:on, heap free:on [2024-03-10 12:54:47] [ 0.211652] mem auto-init: clearing system memory may take some time… [2024-03-10 12:54:47] [ 0.243569] Memory: 319400K/409212K available (18441K kernel code, 3244K rwdata, 7552K rodata, 3560K init, 18132K bss, 89556K reserved, 0K cma-reserved) [2024-03-10 12:54:47] [ 0.243674] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [2024-03-10 12:54:47] [ 0.243686] Kernel/User page tables isolation: enabled [2024-03-10 12:54:47] [ 0.243711] ftrace: allocating 53625 entries in 210 pages [2024-03-10 12:54:47] [ 0.252868] ftrace: allocated 210 pages with 4 groups [2024-03-10 12:54:47] [ 0.253699] Dynamic Preempt: voluntary [2024-03-10 12:54:47] [ 0.253719] rcu: Preemptible hierarchical RCU implementation. [2024-03-10 12:54:47] [ 0.253720] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=2. [2024-03-10 12:54:47] [ 0.253721] Trampoline variant of Tasks RCU enabled. [2024-03-10 12:54:47] [ 0.253722] Rude variant of Tasks RCU enabled. [2024-03-10 12:54:47] [ 0.253722] Tracing variant of Tasks RCU enabled. [2024-03-10 12:54:47] [ 0.253723] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies. [2024-03-10 12:54:47] [ 0.253724] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [2024-03-10 12:54:47] [ 0.258417] NR_IRQS: 524544, nr_irqs: 48, preallocated irqs: 16 [2024-03-10 12:54:47] [ 0.258448] xen:events: Using FIFO-based ABI [2024-03-10 12:54:47] [ 0.258461] xen:events: Xen HVM callback vector for event delivery is enabled [2024-03-10 12:54:47] [ 0.258622] rcu: srcu_init: Setting srcu_struct sizes based on contention. [2024-03-10 12:54:47] [ 0.258733] kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval) [2024-03-10 12:54:47] [ 0.258758] Console: colour dummy device 80x25 [2024-03-10 12:54:47] [ 0.260102] printk: console [hvc0] enabled [2024-03-10 12:54:47] [ 0.260129] ACPI: Core revision 20220331 [2024-03-10 12:54:47] [ 0.260204] ACPI: setting ELCR to 0200 (from ffff) [2024-03-10 12:54:47] [ 0.260252] APIC: Switch to symmetric I/O mode setup [2024-03-10 12:54:47] [ 0.260281] x2apic enabled [2024-03-10 12:54:47] [ 0.260292] Switched APIC routing to physical x2apic. [2024-03-10 12:54:47] [ 0.260358] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x36a8d041f91, max_idle_ns: 881590460728 ns [2024-03-10 12:54:47] [ 0.260386] Calibrating delay loop (skipped), value calculated using timer frequency… 3791.99 BogoMIPS (lpj=1895999) [2024-03-10 12:54:47] [ 0.260569] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8 [2024-03-10 12:54:47] [ 0.260583] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4 [2024-03-10 12:54:47] [ 0.260602] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization [2024-03-10 12:54:47] [ 0.260625] Spectre V2 : Mitigation: IBRS [2024-03-10 12:54:47] [ 0.260635] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch [2024-03-10 12:54:47] [ 0.260654] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT [2024-03-10 12:54:47] [ 0.260670] RETBleed: Mitigation: IBRS [2024-03-10 12:54:47] [ 0.260682] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier [2024-03-10 12:54:47] [ 0.260704] Spectre V2 : User space: Mitigation: STIBP via prctl [2024-03-10 12:54:47] [ 0.260721] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl [2024-03-10 12:54:47] [ 0.260750] MDS: Mitigation: Clear CPU buffers [2024-03-10 12:54:47] [ 0.260763] MMIO Stale Data: Mitigation: Clear CPU buffers [2024-03-10 12:54:47] [ 0.260778] SRBDS: Unknown: Dependent on hypervisor status [2024-03-10 12:54:47] [ 0.260808] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’ [2024-03-10 12:54:47] [ 0.260828] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’ [2024-03-10 12:54:47] [ 0.260844] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’ [2024-03-10 12:54:47] [ 0.260861] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256 [2024-03-10 12:54:47] [ 0.260878] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using ‘compacted’ format. [2024-03-10 12:54:47] [ 0.261384] Freeing SMP alternatives memory: 48K [2024-03-10 12:54:47] [ 0.261384] pid_max: default: 32768 minimum: 301 [2024-03-10 12:54:47] [ 0.261384] LSM: Security Framework initializing [2024-03-10 12:54:47] [ 0.261384] Yama: becoming mindful. [2024-03-10 12:54:47] [ 0.261384] SELinux: Initializing. [2024-03-10 12:54:47] [ 0.261384] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear) [2024-03-10 12:54:47] [ 0.261384] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear) [2024-03-10 12:54:47] [ 0.261384] clocksource: xen: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns [2024-03-10 12:54:47] [ 0.261384] installing Xen timer for CPU 0 [2024-03-10 12:54:47] [ 0.261384] smpboot: CPU0: Intel(R) Core™ i5-8350U CPU @ 1.70GHz (family: 0x6, model: 0x8e, stepping: 0xa) [2024-03-10 12:54:47] [ 0.261384] cpu 0 spinlock event irq 20 [2024-03-10 12:54:47] [ 0.261384] cblist_init_generic: Setting adjustable number of callback queues. [2024-03-10 12:54:47] [ 0.261384] cblist_init_generic: Setting shift to 1 and lim to 1. [2024-03-10 12:54:47] [ 0.261384] cblist_init_generic: Setting adjustable number of callback queues. [2024-03-10 12:54:47] [ 0.261384] cblist_init_generic: Setting shift to 1 and lim to 1. [2024-03-10 12:54:47] [ 0.261384] cblist_init_generic: Setting adjustable number of callback queues. [2024-03-10 12:54:47] [ 0.261384] cblist_init_generic: Setting shift to 1 and lim to 1. [2024-03-10 12:54:47] [ 0.261384] Performance Events: unsupported p6 CPU model 142 no PMU driver, software events only. [2024-03-10 12:54:47] [ 0.261384] signal: max sigframe size: 1776 [2024-03-10 12:54:47] [ 0.261384] rcu: Hierarchical SRCU implementation. [2024-03-10 12:54:47] [ 0.261384] rcu: Max phase no-delay instances is 400. [2024-03-10 12:54:47] [ 0.261384] NMI watchdog: Perf NMI watchdog permanently disabled [2024-03-10 12:54:47] [ 0.261384] smp: Bringing up secondary CPUs … [2024-03-10 12:54:47] [ 0.261412] installing Xen timer for CPU 1 [2024-03-10 12:54:47] [ 0.261488] x86: Booting SMP configuration: [2024-03-10 12:54:47] [ 0.261499] … node #0, CPUs: #1 [2024-03-10 12:54:47] [ 0.261937] cpu 1 spinlock event irq 25 [2024-03-10 12:54:47] [ 0.261937] smp: Brought up 1 node, 2 CPUs [2024-03-10 12:54:47] [ 0.261937] smpboot: Max logical packages: 1 [2024-03-10 12:54:47] [ 0.261937] smpboot: Total of 2 processors activated (7583.99 BogoMIPS) [2024-03-10 12:54:47] [ 0.262496] devtmpfs: initialized [2024-03-10 12:54:47] [ 0.262496] x86/mm: Memory block size: 128MB [2024-03-10 12:54:47] [ 0.263653] memmap_init_zone_device initialised 32768 pages in 1ms [2024-03-10 12:54:47] [ 0.263877] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [2024-03-10 12:54:47] [ 0.263907] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [2024-03-10 12:54:47] [ 0.263981] pinctrl core: initialized pinctrl subsystem [2024-03-10 12:54:47] [ 0.264574] NET: Registered PF_NETLINK/PF_ROUTE protocol family [2024-03-10 12:54:47] [ 0.264615] xen:grant_table: Grant tables using version 1 layout [2024-03-10 12:54:47] [ 0.264655] Grant table initialized [2024-03-10 12:54:47] [ 0.264866] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [2024-03-10 12:54:47] [ 0.264892] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [2024-03-10 12:54:47] [ 0.264914] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [2024-03-10 12:54:47] [ 0.264946] audit: initializing netlink subsys (disabled) [2024-03-10 12:54:47] [ 0.265001] audit: type=2000 audit(1710089687.581:1): state=initialized audit_enabled=0 res=1 [2024-03-10 12:54:47] [ 0.265001] thermal_sys: Registered thermal governor ‘fair_share’ [2024-03-10 12:54:47] [ 0.265001] thermal_sys: Registered thermal governor ‘bang_bang’ [2024-03-10 12:54:47] [ 0.265001] thermal_sys: Registered thermal governor ‘step_wise’ [2024-03-10 12:54:47] [ 0.265001] thermal_sys: Registered thermal governor ‘user_space’ [2024-03-10 12:54:47] [ 0.265001] cpuidle: using governor menu [2024-03-10 12:54:47] [ 0.265403] PCI: Fatal: No config space access function found [2024-03-10 12:54:47] [ 0.267860] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible. [2024-03-10 12:54:47] [ 0.297414] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [2024-03-10 12:54:47] [ 0.297437] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page [2024-03-10 12:54:47] [ 0.297455] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [2024-03-10 12:54:47] [ 0.297471] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page [2024-03-10 12:54:47] [ 0.298270] cryptd: max_cpu_qlen set to 1000 [2024-03-10 12:54:47] [ 0.298389] raid6: skipped pq benchmark and selected avx2x4 [2024-03-10 12:54:47] [ 0.298389] raid6: using avx2x2 recovery algorithm [2024-03-10 12:54:47] [ 0.298389] ACPI: Added _OSI(Module Device) [2024-03-10 12:54:47] [ 0.298389] ACPI: Added _OSI(Processor Device) [2024-03-10 12:54:47] [ 0.298389] ACPI: Added _OSI(3.0 _SCP Extensions) [2024-03-10 12:54:47] [ 0.298389] ACPI: Added _OSI(Processor Aggregator Device) [2024-03-10 12:54:47] [ 0.303501] ACPI: 1 ACPI AML tables successfully acquired and loaded [2024-03-10 12:54:47] [ 0.303837] ACPI: OSL: SCI (ACPI GSI 9) not registered [2024-03-10 12:54:47] [ 0.306979] ACPI: Interpreter enabled [2024-03-10 12:54:47] [ 0.306999] ACPI: PM: (supports S0) [2024-03-10 12:54:47] [ 0.307010] ACPI: Using platform specific model for interrupt routing [2024-03-10 12:54:47] [ 0.307048] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug [2024-03-10 12:54:47] [ 0.307072] PCI: Using E820 reservations for host bridge windows [2024-03-10 12:54:47] [ 0.307642] ACPI: Enabled 1 GPEs in block 00 to 0F [2024-03-10 12:54:47] [ 0.307671] ACPI Error: No handler or method for GPE 00, disabling event (20220331/evgpe-839) [2024-03-10 12:54:47] [ 0.307705] ACPI Error: No handler or method for GPE 01, disabling event (20220331/evgpe-839) [2024-03-10 12:54:47] [ 0.307750] ACPI Error: No handler or method for GPE 03, disabling event (20220331/evgpe-839) [2024-03-10 12:54:47] [ 0.307783] ACPI Error: No handler or method for GPE 04, disabling event (20220331/evgpe-839) [2024-03-10 12:54:47] [ 0.307815] ACPI Error: No handler or method for GPE 05, disabling event (20220331/evgpe-839) [2024-03-10 12:54:47] [ 0.307848] ACPI Error: No handler or method for GPE 06, disabling event (20220331/evgpe-839) [2024-03-10 12:54:47] [ 0.307882] ACPI Error: No handler or method for GPE 07, disabling event (20220331/evgpe-839) [2024-03-10 12:54:47] [ 0.313824] xen:balloon: Initialising balloon driver [2024-03-10 12:54:47] [ 0.317409] acpi LNXCPU:03: Still not present [2024-03-10 12:54:47] [ 0.317444] acpi LNXCPU:04: Still not present [2024-03-10 12:54:47] [ 0.317480] acpi LNXCPU:06: Still not present [2024-03-10 12:54:47] [ 0.317505] acpi LNXCPU:07: Still not present [2024-03-10 12:54:47] [ 0.317530] acpi LNXCPU:08: Still not present [2024-03-10 12:54:47] [ 0.317555] acpi LNXCPU:09: Still not present [2024-03-10 12:54:47] [ 0.317579] acpi LNXCPU:0a: Still not present [2024-03-10 12:54:47] [ 0.317604] acpi LNXCPU:0b: Still not present [2024-03-10 12:54:47] [ 0.317628] acpi LNXCPU:0c: Still not present [2024-03-10 12:54:47] [ 0.317652] acpi LNXCPU:0d: Still not present [2024-03-10 12:54:47] [ 0.317677] acpi LNXCPU:0e: Still not present [2024-03-10 12:54:47] [ 0.317701] acpi LNXCPU:0f: Still not present [2024-03-10 12:54:47] [ 0.317725] acpi LNXCPU:10: Still not present [2024-03-10 12:54:47] [ 0.317750] acpi LNXCPU:11: Still not present [2024-03-10 12:54:47] [ 0.317774] acpi LNXCPU:12: Still not present [2024-03-10 12:54:47] [ 0.317799] acpi LNXCPU:13: Still not present [2024-03-10 12:54:47] [ 0.317824] acpi LNXCPU:14: Still not present [2024-03-10 12:54:47] [ 0.317848] acpi LNXCPU:15: Still not present [2024-03-10 12:54:47] [ 0.317872] acpi LNXCPU:16: Still not present [2024-03-10 12:54:47] [ 0.317896] acpi LNXCPU:17: Still not present [2024-03-10 12:54:47] [ 0.317921] acpi LNXCPU:18: Still not present [2024-03-10 12:54:47] [ 0.317946] acpi LNXCPU:1a: Still not present [2024-03-10 12:54:47] [ 0.317970] acpi LNXCPU:1b: Still not present [2024-03-10 12:54:47] [ 0.317995] acpi LNXCPU:1c: Still not present [2024-03-10 12:54:47] [ 0.318019] acpi LNXCPU:1d: Still not present [2024-03-10 12:54:47] [ 0.318044] acpi LNXCPU:1e: Still not present [2024-03-10 12:54:47] [ 0.318068] acpi LNXCPU:1f: Still not present [2024-03-10 12:54:47] [ 0.318092] acpi LNXCPU:20: Still not present [2024-03-10 12:54:47] [ 0.318117] acpi LNXCPU:22: Still not present [2024-03-10 12:54:47] [ 0.318142] acpi LNXCPU:23: Still not present [2024-03-10 12:54:47] [ 0.318166] acpi LNXCPU:24: Still not present [2024-03-10 12:54:47] [ 0.318190] acpi LNXCPU:25: Still not present [2024-03-10 12:54:47] [ 0.318217] acpi LNXCPU:26: Still not present [2024-03-10 12:54:47] [ 0.318243] acpi LNXCPU:27: Still not present [2024-03-10 12:54:47] [ 0.318267] acpi LNXCPU:28: Still not present [2024-03-10 12:54:47] [ 0.318291] acpi LNXCPU:29: Still not present [2024-03-10 12:54:47] [ 0.318316] acpi LNXCPU:2a: Still not present [2024-03-10 12:54:47] [ 0.318340] acpi LNXCPU:2b: Still not present [2024-03-10 12:54:47] [ 0.318365] acpi LNXCPU:2c: Still not present [2024-03-10 12:54:47] [ 0.318394] acpi LNXCPU:2e: Still not present [2024-03-10 12:54:47] [ 0.318419] acpi LNXCPU:2f: Still not present [2024-03-10 12:54:47] [ 0.318444] acpi LNXCPU:31: Still not present [2024-03-10 12:54:47] [ 0.318468] acpi LNXCPU:32: Still not present [2024-03-10 12:54:47] [ 0.318493] acpi LNXCPU:33: Still not present [2024-03-10 12:54:47] [ 0.318517] acpi LNXCPU:34: Still not present [2024-03-10 12:54:47] [ 0.318541] acpi LNXCPU:35: Still not present [2024-03-10 12:54:47] [ 0.318566] acpi LNXCPU:36: Sti
Blockquote
al_generic [2024-03-10 12:54:48] [ 0.389734] usbserial: USB Serial support registered for generic [2024-03-10 12:54:48] [ 0.389789] i8042: PNP: No PS/2 controller found. [2024-03-10 12:54:48] [ 0.389922] mousedev: PS/2 mouse device common for all mice [2024-03-10 12:54:48] [ 0.389989] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log. [2024-03-10 12:54:48] [ 0.390041] device-mapper: uevent: version 1.0.3 [2024-03-10 12:54:48] [ 0.390194] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com [2024-03-10 12:54:48] [ 0.390361] intel_pstate: CPU model not supported [2024-03-10 12:54:48] [ 0.390414] hid: raw HID events driver (C) Jiri Kosina [2024-03-10 12:54:48] [ 0.390468] usbcore: registered new interface driver usbhid [2024-03-10 12:54:48] [ 0.390483] usbhid: USB HID core driver [2024-03-10 12:54:48] [ 0.390745] drop_monitor: Initializing network drop monitor service [2024-03-10 12:54:48] [ 0.390857] Initializing XFRM netlink socket [2024-03-10 12:54:48] [ 0.390995] NET: Registered PF_INET6 protocol family [2024-03-10 12:54:48] [ 0.393929] Segment Routing with IPv6 [2024-03-10 12:54:48] [ 0.393943] RPL Segment Routing with IPv6 [2024-03-10 12:54:48] [ 0.393962] In-situ OAM (IOAM) with IPv6 [2024-03-10 12:54:48] [ 0.393996] mip6: Mobile IPv6 [2024-03-10 12:54:48] [ 0.394011] NET: Registered PF_PACKET protocol family [2024-03-10 12:54:48] [ 0.394490] IPI shorthand broadcast: enabled [2024-03-10 12:54:48] [ 0.394514] AVX2 version of gcm_enc/dec engaged. [2024-03-10 12:54:48] [ 0.394858] AES CTR mode by8 optimization enabled [2024-03-10 12:54:48] [ 0.395362] sched_clock: Marking stable (393563156, 1759937)->(732893094, -337570001) [2024-03-10 12:54:48] [ 0.395605] registered taskstats version 1 [2024-03-10 12:54:48] [ 0.395730] Loading compiled-in X.509 certificates [2024-03-10 12:54:48] [ 0.407658] Loaded X.509 cert ‘Build time autogenerated kernel key: 745a75c152ebc2dc9d27c3df1e6fd4cff781a8fa’ [2024-03-10 12:54:48] [ 0.407982] zswap: loaded using pool lzo/zbud [2024-03-10 12:54:48] [ 0.408300] page_owner is disabled [2024-03-10 12:54:48] [ 0.408480] Key type .fscrypt registered [2024-03-10 12:54:48] [ 0.408494] Key type fscrypt-provisioning registered [2024-03-10 12:54:48] [ 0.524058] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes [2024-03-10 12:54:48] [ 0.524102] Key type big_key registered [2024-03-10 12:54:48] [ 0.527206] Key type encrypted registered [2024-03-10 12:54:48] [ 0.527234] ima: No TPM chip found, activating TPM-bypass! [2024-03-10 12:54:48] [ 0.527253] Loading compiled-in module X.509 certificates [2024-03-10 12:54:48] [ 0.527796] Loaded X.509 cert ‘Build time autogenerated kernel key: 745a75c152ebc2dc9d27c3df1e6fd4cff781a8fa’ [2024-03-10 12:54:48] [ 0.527829] ima: Allocated hash algorithm: sha256 [2024-03-10 12:54:48] [ 0.527854] ima: No architecture policies found [2024-03-10 12:54:48] [ 0.527881] evm: Initialising EVM extended attributes: [2024-03-10 12:54:48] [ 0.527896] evm: security.selinux [2024-03-10 12:54:48] [ 0.527907] evm: security.SMACK64 (disabled) [2024-03-10 12:54:48] [ 0.527921] evm: security.SMACK64EXEC (disabled) [2024-03-10 12:54:48] [ 0.527935] evm: security.SMACK64TRANSMUTE (disabled) [2024-03-10 12:54:48] [ 0.527949] evm: security.SMACK64MMAP (disabled) [2024-03-10 12:54:48] [ 0.527963] evm: security.apparmor [2024-03-10 12:54:48] [ 0.527974] evm: security.ima [2024-03-10 12:54:48] [ 0.527985] evm: security.capability [2024-03-10 12:54:48] [ 0.527996] evm: HMAC attrs: 0x1 [2024-03-10 12:54:48] [ 0.578932] alg: No test for 842 (842-scomp) [2024-03-10 12:54:48] [ 0.579273] alg: No test for 842 (842-generic) [2024-03-10 12:54:48] [ 0.716843] xenbus_probe_frontend: Device with no driver: device/vbd/51712 [2024-03-10 12:54:48] [ 0.716867] xenbus_probe_frontend: Device with no driver: device/vbd/51728 [2024-03-10 12:54:48] [ 0.716884] xenbus_probe_frontend: Device with no driver: device/vbd/51744 [2024-03-10 12:54:48] [ 0.716901] xenbus_probe_frontend: Device with no driver: device/vbd/51760 [2024-03-10 12:54:48] [ 0.717034] RAS: Correctable Errors collector initialized. [2024-03-10 12:54:48] [ 0.718861] Freeing unused decrypted memory: 2036K [2024-03-10 12:54:48] [ 0.719430] Freeing unused kernel image (initmem) memory: 3560K [2024-03-10 12:54:48] [ 0.720813] Write protecting the kernel read-only data: 28672k [2024-03-10 12:54:48] [ 0.721517] Freeing unused kernel image (text/rodata gap) memory: 2036K [2024-03-10 12:54:48] [ 0.721743] Freeing unused kernel image (rodata/data gap) memory: 640K [2024-03-10 12:54:48] [ 0.721823] rodata_test: all tests were successful [2024-03-10 12:54:48] [ 0.721849] Run /init as init process [2024-03-10 12:54:48] Qubes initramfs script here: [2024-03-10 12:54:48] [ 0.726216] Invalid max_queues (4), will use default max: 2. [2024-03-10 12:54:48] [ 0.744578] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled [2024-03-10 12:54:48] [ 0.751222] xvda: xvda1 xvda2 xvda3 [2024-03-10 12:54:48] [ 0.756644] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled [2024-03-10 12:54:48] [ 0.759945] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled [2024-03-10 12:54:48] [ 0.762840] blkfront: xvdd: barrier or flush: disabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled [2024-03-10 12:54:48] Waiting for /dev/xvda* devices… [2024-03-10 12:54:48] Qubes: Doing R/W setup for TemplateVM… [2024-03-10 12:54:48] [ 1.252475] xvdc: xvdc1 xvdc3 [2024-03-10 12:54:48] Setting up swapspace version 1, size = 1073737728 bytes [2024-03-10 12:54:48] UUID=621f0ebf-0023-41a8-a9ec-e25d88f612b6 [2024-03-10 12:54:48] Qubes: done. [2024-03-10 12:54:48] [ 1.265892] EXT4-fs (xvda3): mounted filesystem with ordered data mode. Quota mode: none. [2024-03-10 12:54:48] Waiting for /dev/xvdd device… [2024-03-10 12:54:48] [ 1.271317] /dev/xvdd: Can’t open blockdev [2024-03-10 12:54:48] [ 1.274040] EXT4-fs (xvdd): mounting ext3 file system using the ext4 subsystem [2024-03-10 12:54:48] [ 1.276590] EXT4-fs (xvdd): mounted filesystem with ordered data mode. Quota mode: none. [2024-03-10 12:54:48] mount: can’t read ‘/proc/mounts’: No such file or directory [2024-03-10 12:54:49] [ 1.466024] audit: type=1404 audit(1710089688.781:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 enabled=1 old-enabled=1 lsm=selinux res=1 [2024-03-10 12:54:49] [ 1.511469] SELinux: policy capability network_peer_controls=1 [2024-03-10 12:54:49] [ 1.511493] SELinux: policy capability open_perms=1 [2024-03-10 12:54:49] [ 1.511507] SELinux: policy capability extended_socket_class=1 [2024-03-10 12:54:49] [ 1.511524] SELinux: policy capability always_check_network=0 [2024-03-10 12:54:49] [ 1.511541] SELinux: policy capability cgroup_seclabel=1 [2024-03-10 12:54:49] [ 1.511555] SELinux: policy capability nnp_nosuid_transition=1 [2024-03-10 12:54:49] [ 1.511571] SELinux: policy capability genfs_seclabel_symlinks=1 [2024-03-10 12:54:49] [ 1.511588] SELinux: policy capability ioctl_skip_cloexec=0 [2024-03-10 12:54:49] [ 1.550419] audit: type=1403 audit(1710089688.865:3): auid=4294967295 ses=4294967295 lsm=selinux res=1 [2024-03-10 12:54:49] [ 1.553025] systemd[1]: Successfully loaded SELinux policy in 88.490ms. [2024-03-10 12:54:49] [ 1.639683] systemd[1]: Relabelled /dev, /dev/shm, /run, /sys/fs/cgroup in 11.596ms. [2024-03-10 12:54:49] [ 1.655402] systemd[1]: systemd 253.15-2.fc38 running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA +SMACK +SECCOMP -GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN -IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [2024-03-10 12:54:49] [ 1.655486] systemd[1]: Detected virtualization xen. [2024-03-10 12:54:49] [ 1.655505] systemd[1]: Detected architecture x86-64. [2024-03-10 12:54:49] [2024-03-10 12:54:49] Welcome to .[0;38;2;60;110;180mFedora Linux 38 (Thirty Eight).[0m! [2024-03-10 12:54:49] [2024-03-10 12:54:49] [ 1.659514] systemd[1]: No hostname configured, using default hostname. [2024-03-10 12:54:49] [ 1.659674] systemd[1]: Hostname set to . [2024-03-10 12:54:49] [ 1.722594] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported [2024-03-10 12:54:49] [ 1.941406] systemd[1]: /usr/lib/systemd/system/qubes-gui-agent.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [2024-03-10 12:54:49] [ 2.003704] systemd[1]: Queued start job for default target multi-user.target. [2024-03-10 12:54:49] [ 2.015387] systemd[1]: Created slice system-getty.slice - Slice /system/getty. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-getty.slice.[0m - Slice /system/getty. [2024-03-10 12:54:49] [ 2.016380] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-modprlice.[0m - Slice /system/modprobe. [2024-03-10 12:54:49] [ 2.017038] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Created slice .[0;1;39msystem-seria.[0m - Slice /system/serial-getty. [2024-03-10 12:54:49] [ 2.017518] systemd[1]: Created slice user.slice - User and Session Slice. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Created slice .[0;1;39muser.slice.[0m - User and Session Slice. [2024-03-10 12:54:49] [ 2.017873] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Started .[0;1;39msystemd-ask-passwoquests to Console Directory Watch. [2024-03-10 12:54:49] [ 2.018102] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Started .[0;1;39msystemd-ask-passwo Requests to Wall Directory Watch. [2024-03-10 12:54:49] [ 2.018987] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Set up automount .[0;1;39mproc-sys-rmats File System Automount Point. [2024-03-10 12:54:49] [ 2.019112] systemd[1]: Expecting device dev-hvc0.device - /dev/hvc0… [2024-03-10 12:54:49] Expecting device .[0;1;39mdev-hvc0.device.[0m - /dev/hvc0… [2024-03-10 12:54:49] [ 2.019197] systemd[1]: Expecting device dev-xvdc1.device - /dev/xvdc1… [2024-03-10 12:54:49] Expecting device .[0;1;39mdev-xvdc1.device.[0m - /dev/xvdc1… [2024-03-10 12:54:49] [ 2.019286] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Reached target .[0;1;39mcryptsetup.get.[0m - Local Encrypted Volumes. [2024-03-10 12:54:49] [ 2.019380] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Reached target .[0;1;39mintegrityseLocal Integrity Protected Volumes. [2024-03-10 12:54:49] [ 2.019528] systemd[1]: Reached target paths.target - Path Units. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Reached target .[0;1;39mpaths.target.[0m - Path Units. [2024-03-10 12:54:49] [ 2.019629] systemd[1]: Reached target remote-cryptsetup.target - Remote Encrypted Volumes. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Reached target .[0;1;39mremote-crypet.[0m - Remote Encrypted Volumes. [2024-03-10 12:54:49] [ 2.019716] systemd[1]: Reached target remote-fs.target - Remote File Systems. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Reached target .[0;1;39mremote-fs.target.[0m - Remote File Systems. [2024-03-10 12:54:49] [ 2.019825] systemd[1]: Reached target slices.target - Slice Units. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Reached target .[0;1;39mslices.target.[0m - Slice Units. [2024-03-10 12:54:49] [ 2.019922] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Reached target .[0;1;39mveritysetup - Local Verity Protected Volumes. [2024-03-10 12:54:49] [ 2.023552] systemd[1]: Listening on systemd-coredump.socket - Process Core Dump Socket. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-coredet.[0m - Process Core Dump Socket. [2024-03-10 12:54:49] [ 2.023913] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-initc initctl Compatibility Named Pipe. [2024-03-10 12:54:49] [ 2.024500] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journsocket.[0m - Journal Audit Socket. [2024-03-10 12:54:49] [ 2.025289] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [2024-03-10 12:54:49] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journt.[0m - Journal Socket (/dev/log). [2024-03-10 12:54:49] [ 2.025868] systemd[1]: Listening on systemd-journald.socket - Journal Socket. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-journald.socket.[0m - Journal Socket. [2024-03-10 12:54:49] [ 2.026677] systemd[1]: Listening on systemd-oomd.socket - Userspace Out-Of-Memory (OOM) Killer Socket. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-oomd.Out-Of-Memory (OOM) Killer Socket. [2024-03-10 12:54:49] [ 2.029114] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-udevd.socket.[0m - udev Control Socket. [2024-03-10 12:54:49] [ 2.029534] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-udevdl.socket.[0m - udev Kernel Socket. [2024-03-10 12:54:49] [ 2.030052] systemd[1]: Listening on systemd-userdbd.socket - User Database Manager Socket. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Listening on .[0;1;39msystemd-userd0m - User Database Manager Socket. [2024-03-10 12:54:49] [ 2.149906] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System… [2024-03-10 12:54:49] Mounting .[0;1;39mdev-hugepages.mount.[0m - Huge Pages File System… [2024-03-10 12:54:49] [ 2.152709] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System… [2024-03-10 12:54:49] Mounting .[0;1;39mdev-mqueue.mount.POSIX Message Queue File System… [2024-03-10 12:54:49] [ 2.155671] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System… [2024-03-10 12:54:49] Mounting .[0;1;39msys-kernel-debug…[0m - Kernel Debug File System… [2024-03-10 12:54:49] [ 2.158449] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System… [2024-03-10 12:54:49] Mounting .[0;1;39msys-kernel-tracin.[0m - Kernel Trace File System… [2024-03-10 12:54:49] [ 2.161396] systemd[1]: Starting dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early… [2024-03-10 12:54:49] Starting .[0;1;39mdev-xvdc1-swap.seEnable swap on /dev/xvdc1 early… [2024-03-10 12:54:49] [ 2.164716] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes… [2024-03-10 12:54:49] Starting .[0;1;39mkmod-static-nodesate List of Static Device Nodes… [2024-03-10 12:54:49] [ 2.168876] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs… [2024-03-10 12:54:49] Starting .[0;1;39mmodprobe@configfsm - Load Kernel Module configfs… [2024-03-10 12:54:49] [ 2.172262] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod… [2024-03-10 12:54:49] Starting .[0;1;39mmodprobe@dm_mod.s[0m - Load Kernel Module dm_mod… [2024-03-10 12:54:49] [ 2.175265] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm… [2024-03-10 12:54:49] Starting .[0;1;39mmodprobe@drm.service.[0m - Load Kernel Module drm… [2024-03-10 12:54:49] [ 2.178077] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore… [2024-03-10 12:54:49] Starting .[0;1;39mmodprobe@efi_psto- Load Kernel Module efi_pstore… [2024-03-10 12:54:49] [ 2.180854] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse… [2024-03-10 12:54:49] Starting .[0;1;39mmodprobe@fuse.sere.[0m - Load Kernel Module fuse… [2024-03-10 12:54:49] [ 2.183858] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop… [2024-03-10 12:54:49] Starting .[0;1;39mmodprobe@loop.sere.[0m - Load Kernel Module loop… [2024-03-10 12:54:49] [ 2.187153] Adding 1048572k swap on /dev/xvdc1. Priority:-2 extents:1 across:1048572k SSFS [2024-03-10 12:54:49] [ 2.189639] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules… [2024-03-10 12:54:49] Starting .[0;1;39msystemd-modules-lrvice.[0m - Load Kernel Modules… [2024-03-10 12:54:49] [ 2.192693] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line… [2024-03-10 12:54:49] Starting .[0;1;39msystemd-network-g units from Kernel command line… [2024-03-10 12:54:49] [ 2.192898] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f). [2024-03-10 12:54:49] [ 2.195958] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices… [2024-03-10 12:54:49] Starting .[0;1;39msystemd-udev-trig[0m - Coldplug All udev Devices… [2024-03-10 12:54:49] [ 2.206023] systemd[1]: Condition check resulted in dev-xvdc1.swap - /dev/xvdc1 being skipped. [2024-03-10 12:54:49] [ 2.206098] systemd[1]: Unnecessary job was removed for dev-xvdc1.device - /dev/xvdc1. [2024-03-10 12:54:49] [ 2.207292] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Mounted .[0;1;39mdev-hugepages.mount.[0m - Huge Pages File System. [2024-03-10 12:54:49] [ 2.207524] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Mounted .[0;1;39mdev-mqueue.mount.[- POSIX Message Queue File System. [2024-03-10 12:54:49] [ 2.207713] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-debug.mnt.[0m - Kernel Debug File System. [2024-03-10 12:54:49] [ 2.207929] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Mounted .[0;1;39msys-kernel-tracingnt.[0m - Kernel Trace File System. [2024-03-10 12:54:49] [ 2.208481] systemd[1]: dev-xvdc1-swap.service: Deactivated successfully. [2024-03-10 12:54:49] [ 2.208693] systemd[1]: Finished dev-xvdc1-swap.service - Enable swap on /dev/xvdc1 early. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Finished .[0;1;39mdev-xvdc1-swap.se- Enable swap on /dev/xvdc1 early. [2024-03-10 12:54:49] [ 2.209312] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Finished .[0;1;39mkmod-static-nodesreate List of Static Device Nodes. [2024-03-10 12:54:49] [ 2.209700] systemd[1]: modprobe@configfs.service: Deactivated successfully. [2024-03-10 12:54:49] [ 2.343679] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@configfs[0m - Load Kernel Module configfs. [2024-03-10 12:54:49] [ 2.344309] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [2024-03-10 12:54:49] [ 2.344506] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@dm_mod.se.[0m - Load Kernel Module dm_mod. [2024-03-10 12:54:49] [ 2.344988] systemd[1]: modprobe@drm.service: Deactivated successfully. [2024-03-10 12:54:49] [ 2.345185] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [2024-03-10 12:54:49] [.[0;32m OK .[0m] Finished .[0;1;39mmodprobe@drm.service.[0m - Load Kernel Module drm. [2024-03-10 12:54:49] [ 2.345592] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [2024-03-10 12:54:49] [ 2.345814] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [2024-03-10 12:54:49] [.[0;32m Ostemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes). [2024-03-10 12:54:50] [ 2.458338] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc). [2024-03-10 12:54:50] [ 2.458442] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [2024-03-10 12:54:50] [ 2.458706] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met. [2024-03-10 12:54:50] [ 2.472400] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev… [2024-03-10 12:54:50] Starting .[0;1;39msystemd-tmpfiles-ate Static Device Nodes in /dev… [2024-03-10 12:54:50] [ 2.566363] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-udev-trige.[0m - Coldplug All udev Devices. [2024-03-10 12:54:50] [ 2.603199] Rounding down aligned max_sectors from 4294967295 to 4294967288 [2024-03-10 12:54:50] [ 2.603449] db_root: cannot open: /etc/target [2024-03-10 12:54:50] [ 2.619197] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-modules-lservice.[0m - Load Kernel Modules. [2024-03-10 12:54:50] [ 2.628537] systemd[1]: Starting qubes-db.service - Qubes DB agent… [2024-03-10 12:54:50] Starting .[0;1;39mqubes-db.service.[0m - Qubes DB agent… [2024-03-10 12:54:50] [ 2.631797] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables… [2024-03-10 12:54:50] Starting .[0;1;39msystemd-sysctl.sece.[0m - Apply Kernel Variables… [2024-03-10 12:54:50] [ 2.632644] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-reate Static Device Nodes in /dev. [2024-03-10 12:54:50] [ 2.632950] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Reached target .[0;1;39mlocal-fs-prreparation for Local File Systems. [2024-03-10 12:54:50] [ 2.635925] systemd[1]: Started haveged.service - Entropy Daemon based on the HAVEGE algorithm. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Started .[0;1;39mhaveged.service.[0mon based on the HAVEGE algorithm. [2024-03-10 12:54:50] [ 2.644074] systemd[1]: Starting systemd-journald.service - Journal Service… [2024-03-10 12:54:50] Starting .[0;1;39msystemd-journald.service.[0m - Journal Service… [2024-03-10 12:54:50] [ 2.651951] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files… [2024-03-10 12:54:50] Starting .[0;1;39msystemd-udevd.serger for Device Events and Files… [2024-03-10 12:54:50] [ 2.702895] systemd-journald[284]: Collecting audit messages is enabled. [2024-03-10 12:54:50] [ 2.726819] systemd[1]: Started qubes-db.service - Qubes DB agent. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Started .[0;1;39mqubes-db.service.[0m - Qubes DB agent. [2024-03-10 12:54:50] [ 2.727862] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-sysctl.service.[0m - Apply Kernel Variables. [2024-03-10 12:54:50] [ 2.728790] audit: type=1130 audit(1710089690.042:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=qubes-db comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:54:50] [ 2.728853] audit: type=1130 audit(1710089690.043:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-sysctl comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:54:50] [ 2.739551] systemd[1]: Starting qubes-sysinit.service - Init Qubes Services settings… [2024-03-10 12:54:50] Starting .[0;1;39mqubes-sysinit.ser - Init Qubes Services settings… [2024-03-10 12:54:50] [ 2.747430] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed… [2024-03-10 12:54:50] Starting .[0;1;39msystemd-random-se.[0m - Load/Save OS Random Seed… [2024-03-10 12:54:50] [ 2.769199] systemd[1]: Started systemd-journald.service - Journal Service. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Started .[0;1;39msystemd-journald.service.[0m - Journal Service. [2024-03-10 12:54:50] [ 2.771701] audit: type=1130 audit(1710089690.085:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-journald comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:54:50] Starting .[0;1;39msystemd-journal-fh Journal to Persistent Storage… [2024-03-10 12:54:50] [ 2.832446] systemd-journald[284]: Received client request to flush runtime journal. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-sysinit.ser0m - Init Qubes Services settings. [2024-03-10 12:54:50] [ 2.855715] audit: type=1130 audit(1710089690.170:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=qubes-sysinit comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:54:50] Starting .[0;1;39mqubes-mount-dirs.tialize and mount /rw and /home… [2024-03-10 12:54:50] Starting .[0;1;39mqubes-rootfs-resim - Adjust root filesystem size… [2024-03-10 12:54:50] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-random-sece.[0m - Load/Save OS Random Seed. [2024-03-10 12:54:50] [ 2.889985] audit: type=1130 audit(1710089690.205:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-random-seed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:54:50] [ 2.904621] systemd-journald[284]: /var/log/journal/7e8d53e5ea0448dd9af0fd73bc6b1a5d/system.journal: Monotonic clock jumped backwards relative to last journal entry, rotating. [2024-03-10 12:54:50] [ 2.904673] systemd-journald[284]: Rotating system journal. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Started .[0;1;39msystemd-udevd.servnager for Device Events and Files. [2024-03-10 12:54:50] [ 3.185032] audit: type=1130 audit(1710089690.501:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-udevd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:54:50] [.[0;32m OK .[0m] Found device .[0;1;39mdev-hvc0.device.[0m - /dev/hvc0. [2024-03-10 12:54:50] [ 3.302491] EXT4-fs (xvdb): mounted filesystem without journal. Quota mode: none. [2024-03-10 12:54:50] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-rootfs-resi[0m - Adjust root filesystem size. [2024-03-10 12:54:50] [ 3.333455] audit: type=1130 audit(1710089690.648:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=qubes-rootfs-resize comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:54:51] Starting .[0;1;39msystemd-userdbd.sice.[0m - User Database Manager… [2024-03-10 12:54:51] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-journal-fush Journal to Persistent Storage. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39msystemd-userdbd.service.[0m - User Database Manager. [2024-03-10 12:54:51] [ 3.668616] input: PC Speaker as /devices/platform/pcspkr/input/input0 [2024-03-10 12:54:51] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-mount-dirs.nitialize and mount /rw and /home. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Reached target .[0;1;39mlocal-fs.target.[0m - Local File Systems. [2024-03-10 12:54:51] Starting .[0;1;39mqubes-early-vm-coe.[0m - Early Qubes VM settings… [2024-03-10 12:54:51] Starting .[0;1;39msystemd-tmpfiles- Volatile Files and Directories… [2024-03-10 12:54:51] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-early-vm-coice.[0m - Early Qubes VM settings. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-tmpfiles-te Volatile Files and Directories. [2024-03-10 12:54:51] Starting .[0;1;39msystemd-oomd.servpace Out-Of-Memory (OOM) Killer… [2024-03-10 12:54:51] Starting .[0;1;39msystemd-resolved.e.[0m - Network Name Resolution… [2024-03-10 12:54:51] [.[0;32m OK .[0m] Reached target .[0;1;39mtime-set.target.[0m - System Time Set. [2024-03-10 12:54:51] Starting .[0;1;39msystemd-update-utrd System Boot/Shutdown in UTMP… [2024-03-10 12:54:51] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-update-utcord System Boot/Shutdown in UTMP. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39msystemd-oomd.servirspace Out-Of-Memory (OOM) Killer. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39msystemd-resolved.sice.[0m - Network Name Resolution. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Reached target .[0;1;39mnss-lookup.m - Host and Network Name Lookups. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Reached target .[0;1;39msysinit.target.[0m - System Initialization. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mfstrim.timer.[0m - Discard unused blocks once a week. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mlogrotate.timer.[0m - Daily rotation of log files. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mqubes-sync-time.ti.[0m - Update system time each 6h. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mqubes-update-check - Periodically check for updates. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mraid-check.timer.[ - Weekly RAID setup health check. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39msystemd-tmpfiles-c Cleanup of Temporary Directories. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39munbound-anchor.tim the root trust anchor for DNSSEC. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Reached target .[0;1;39mtimers.target.[0m - Timer Units. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Listening on .[0;1;39mdbus.socket.[- D-Bus System Message Bus Socket. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Listening on .[0;1;39mpcscd.socket.art Card Daemon Activation Socket. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Reached target .[0;1;39msockets.target.[0m - Socket Units. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Reached target .[0;1;39mbasic.target.[0m - Basic System. [2024-03-10 12:54:51] Starting .[0;1;39mabrtd.service.[0m - ABRT Daemon… [2024-03-10 12:54:51] Starting .[0;1;39mdracut-shutdown.store /run/initramfs on shutdown… [2024-03-10 12:54:51] Starting .[0;1;39mpolkit.service.[0m - Authorization Manager… [2024-03-10 12:54:51] Starting .[0;1;39mqubes-antispoof.ses anti-spoofing firewall rules… [2024-03-10 12:54:51] Starting .[0;1;39mqubes-meminfo-wribes memory information reporter… [2024-03-10 12:54:51] Starting .[0;1;39mqubes-network-upl[0m - Qubes network uplink wait… [2024-03-10 12:54:51] Starting .[0;1;39msystemd-homed.service.[0m - Home Area Manager… [2024-03-10 12:54:51] Starting .[0;1;39msystemd-logind.seice.[0m - User Login Management… [2024-03-10 12:54:51] Starting .[0;1;39mxendriverdomain.sXen driver domain device daemon… [2024-03-10 12:54:51] [.[0;32m OK .[0m] Finished .[0;1;39mdracut-shutdown.sestore /run/initramfs on shutdown. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mqubes-meminfo-writQubes memory information reporter. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-network-uple.[0m - Qubes network uplink wait. [2024-03-10 12:54:51] Starting .[0;1;39mdbus-broker.servi.[0m - D-Bus System Message Bus… [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mxendriverdomain.se- Xen driver domain device daemon. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-antispoof.subes anti-spoofing firewall rules. [2024-03-10 12:54:51] Starting .[0;1;39mqubes-iptables.se - Qubes base firewall settings… [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39msystemd-logind.service.[0m - User Login Management. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mdbus-broker.service.[0m - D-Bus System Message Bus. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39msystemd-homed.service.[0m - Home Area Manager. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-homed-actervice.[0m - Home Area Activation. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mabrtd.service.[0m - ABRT Daemon. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mabrt-journal-core. ABRT coredumpctl message creator. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mabrt-oops.service.[0m - ABRT kernel log watcher. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mabrt-xorg.service.[0m - ABRT Xorg log watcher. [2024-03-10 12:54:51] [.[0;32m OK .[0m] Started .[0;1;39mpolkit.service.[0m - Authorization Manager. [2024-03-10 12:54:52] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-iptables.se0m - Qubes base firewall settings. [2024-03-10 12:54:52] [.[0;32m OK .[0m] Reached target .[0;1;39mnetwork-preget.[0m - Preparation for Network. [2024-03-10 12:54:52] [.[0;32m OK .[0m] Reached target .[0;1;39mnetwork.target.[0m - Network. [2024-03-10 12:54:52] Starting .[0;1;39mqubes-misc-post.s - Qubes misc post-boot actions… [2024-03-10 12:54:52] Starting .[0;1;39msystemd-user-sessvice.[0m - Permit User Sessions… [2024-03-10 12:54:52] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-user-sesservice.[0m - Permit User Sessions. [2024-03-10 12:54:52] [.[0;32m OK .[0m] Started .[0;1;39mgetty@tty1.service.[0m - Getty on tty1. [2024-03-10 12:54:52] Starting .[0;1;39mqubes-gui-agent.service.[0m - Qubes GUI Agent… [2024-03-10 12:54:52] Starting .[0;1;39mqubes-qrexec-agene.[0m - Qubes remote exec agent… [2024-03-10 12:54:52] [.[0;32m OK .[0m] Started .[0;1;39mserial-getty@hvc0.service.[0m - Serial Getty on hvc0. [2024-03-10 12:54:52] [.[0;32m OK .[0m] Reached target .[0;1;39mgetty.target.[0m - Login Prompts. [2024-03-10 12:54:52] [.[0;32m OK .[0m] Started .[0;1;39mqubes-gui-agent.service.[0m - Qubes GUI Agent. [2024-03-10 12:54:52] [.[0;32m OK .[0m] Started .[0;1;39mqubes-qrexec-agentice.[0m - Qubes remote exec agent. [2024-03-10 12:54:52] [.[0;32m OK .[0m] Finished .[0;1;39mqubes-misc-post.s0m - Qubes misc post-boot actions. [2024-03-10 12:54:52] [.[0;32m OK .[0m] Reached target .[0;1;39mmulti-user.target.[0m - Multi-User System. [2024-03-10 12:54:52] Starting .[0;1;39msystemd-update-ut Record Runlevel Change in UTMP… [2024-03-10 12:54:52] [.[0;32m OK .[0m] Finished .[0;1;39msystemd-update-ut - Record Runlevel Change in UTMP. [2024-03-10 12:54:52] [ 4.708896] fbcon: Taking over console [2024-03-10 12:54:52] [ 5.042003] Fallback order for Node 0: 0 [2024-03-10 12:54:52] [ 5.042007] Built 1 zonelists, mobility grouping on. Total pages: 85580 [2024-03-10 12:54:52] [ 5.042040] Policy zone: Normal [2024-03-10 12:54:52] [ 5.366974] kauditd_printk_skb: 55 callbacks suppressed [2024-03-10 12:54:52] [ 5.366977] audit: type=1100 audit(1710089692.683:59): pid=583 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:xdm_t:s0-s0:c0.c1023 msg=‘op=PAM:authentication grantors=pam_rootok acct=“user” exe=“/usr/bin/qubes-gui-runuser” hostname=disp3495 addr=? terminal=/dev/tty7 res=success’ [2024-03-10 12:54:52] [ 5.369177] audit: type=1100 audit(1710089692.683:60): pid=582 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:local_login_t:s0-s0:c0.c1023 msg=‘op=PAM:authentication grantors=pam_rootok acct=“user” exe=“/usr/lib/qubes/qrexec-agent” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:54:52] [ 5.369997] audit: type=1103 audit(1710089692.684:61): pid=582 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:local_login_t:s0-s0:c0.c1023 msg=‘op=PAM:setcred grantors=pam_rootok acct=“user” exe=“/usr/lib/qubes/qrexec-agent” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:54:52] [ 5.370330] audit: type=1006 audit(1710089692.684:62): pid=582 uid=0 subj=system_u:system_r:local_login_t:s0-s0:c0.c1023 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [2024-03-10 12:54:52] [ 5.370435] audit: type=1300 audit(1710089692.684:62): arch=c000003e syscall=1 success=yes exit=4 a0=3 a1=7ffe66f38c00 a2=4 a3=0 items=0 ppid=579 pid=582 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm=“qrexec-agent” exe=“/usr/lib/qubes/qrexec-agent” subj=system_u:system_r:local_login_t:s0-s0:c0.c1023 key=(null) [2024-03-10 12:54:52] [ 5.370642] audit: type=1327 audit(1710089692.684:62): proctitle=“/usr/lib/qubes/qrexec-agent” [2024-03-10 12:54:52] [ 5.371413] audit: type=1103 audit(1710089692.687:63): pid=583 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:xdm_t:s0-s0:c0.c1023 msg=‘op=PAM:setcred grantors=pam_rootok acct=“user” exe=“/usr/bin/qubes-gui-runuser” hostname=disp3495 addr=? terminal=/dev/tty7 res=success’ [2024-03-10 12:54:52] [ 5.371705] audit: type=1006 audit(1710089692.687:64): pid=583 uid=0 subj=system_u:system_r:xdm_t:s0-s0:c0.c1023 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 [2024-03-10 12:54:52] [ 5.371884] audit: type=1300 audit(1710089692.687:64): arch=c000003e syscall=1 success=yes exit=4 a0=3 a1=7ffe5f6016d0 a2=4 a3=0 items=0 ppid=553 pid=583 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm=“qubes-gui-runus” exe=“/usr/bin/qubes-gui-runuser” subj=system_u:system_r:xdm_t:s0-s0:c0.c1023 key=(null) [2024-03-10 12:54:52] [ 5.372054] audit: type=1327 audit(1710089692.687:64): proctitle=2F7573722F62696E2F71756265732D6775692D72756E757365720075736572002F62696E2F7368002D6C002D630065786563202F7573722F62696E2F78696E6974202F6574632F5831312F78696E69742F78696E69747263202D2D202F7573722F6C69622F71756265732F71756265732D786F72672D77726170706572203A30 [2024-03-10 12:54:53] [2024-03-10 12:54:53] Fedora Linux 38 (Thirty Eight) [2024-03-10 12:54:53] Kernel 6.1.75-1.qubes.fc37.x86_64 on an x86_64 (hvc0) [2024-03-10 12:54:53] [2024-03-10 12:54:53] disp3495 login: [2024-03-10 12:54:53] [ 5.804770] systemd-journald[284]: /var/log/journal/7e8d53e5ea0448dd9af0fd73bc6b1a5d/user-1000.journal: Monotonic clock jumped backwards relative to last journal entry, rotating. [2024-03-10 12:55:26] [ 39.348786] kauditd_printk_skb: 20 callbacks suppressed [2024-03-10 12:55:26] [ 39.348789] audit: type=1131 audit(1710089726.664:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=systemd-hostnamed comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:55:27] [ 39.379881] audit: type=1334 audit(1710089726.696:84): prog-id=34 op=UNLOAD [2024-03-10 12:55:28] [ 41.063785] audit: type=1130 audit(1710089728.820:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=qubes-sync-time comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’ [2024-03-10 12:55:28] [ 41.063848] audit: type=1131 audit(1710089728.820:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=qubes-sync-time comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
