Hello,
I noticed that sdwdate has been disabled in the kicksecure template due to lack of support. What alternative should I use? Would it be sufficient to install chronyd and configure it with NTS servers?
Thank you!
Hello,
Thank you!
What are you aiming to do? What level of time precision do you want/need?
I don’t have any specific goals or needs. I initially thought sdwdate was important because it was included with Kicksecure. Is it necessary to have an NTP/NTS server running within the template(s)? I noticed that dom0 synchronizes the time with the Qubes.
sdwdate generally works in Kicksecure.
These are 2 non-obvious assumptions, statements without stating or referencing how these have been concluded.
It’s possible to use to have a Kicksecure based ClockVM which is using sdwdate. Documented just now:
Ah, It’s disabled in the template and enabled in the AppVM. I thought everything would be copied from the template to the AppVM.
By the way, I also can’t see Kicksecure in the sdwdate logo on the tray bar when running the AppVM. Not sure if that’s already been reported. I can see anon-whonix etc though.
It’s great to know that the clockVM can be set to sdwdate! How can we test if it it’s working?
Inside a Kicksecure based App Qube the Qubes sdwdate watcher [1] is functional. But there is no App Qube with sdwdate-gui-qubes to report it to by default.
In case of Whonix App Qubes, the sdwdate watcher uses qrexec to notify sys-whonix but in case of Kicksecure App Qubes it’s not clear yet which App Qube to send the sdwdate status to. Qrexec policy [2] will need some changes. [3]
I doubt any progress will be made before build Kicksecure Qubes Template · Issue #9573 · QubesOS/qubes-issues · GitHub is done.
Alternatively, meanwhile you could start from terminal:
sdwdate-gui-qubes
Or.
sdwdate-gui
Or.
sudo sdwdate-log-viewer
The indirect way to reply to this is: Unspecific to Kicksecure / sdwdate. Same as for verification of a default Qubes ClockVM.
Quote The Challenge of System Audits:
Performing system audits is beyond the reach of non-technical users.
Similarly, expecting a non-technical user to conduct a system audit is unrealistic.
Users aren’t expected to audit that part or any other part of the system. Out-of-scope for support.
[1] Technical information for developers:
/etc/xdg/autostart/sdwdate-gui.desktop/usr/libexec/sdwdate-gui/start-maybe/usr/libexec/sdwdate-gui/sdwdate-watcher/usr/lib/python3/dist-packages/sdwdate_gui/sdwdate_watcher.py[2]
[3]
# service arg source target action params
whonix.SdwdateStatus + @tag:anon-gateway @tag:anon-vm allow autostart=no notify=no
whonix.SdwdateStatus + @tag:anon-gateway @default allow target=sys-whonix autostart=no
whonix.SdwdateStatus + @anyvm @anyvm allow autostart=no
whonix.NewStatus * @tag:anon-vm @tag:anon-gateway allow autostart=no
whonix.NewStatus * @anyvm @anyvm allow autostart=no
whonix.GatewayCommand +restart @tag:anon-gateway @tag:anon-vm allow autostart=no
whonix.GatewayCommand +stop @tag:anon-gateway @tag:anon-vm allow autostart=no
whonix.GatewayCommand +showlog @tag:anon-gateway @tag:anon-vm allow autostart=no
whonix.GatewayCommand * @anyvm @anyvm allow autostart=no
Is there any reason besides using kicksecure as a clockvm to leave sdwdate enabled?
I stopped the notification by adding a custom tag to the policy file, should I now run sys-whonix 24/7 in the background?
The only advantage from what I can tell is the Time Replay Protection and Clock Randomization as well as the fact that the time is pulled over tor.
But IDK if that justifies running sys-whonix always in the bg.
What happens if the App-VM cannot reach sys-whonix for swdate?
