This script grabs the last modified file in your defined directory, makes it executable, and then runs it in a new terminal window.
…Not sure this was the best way to solve the Qubes Vscode bottleneck… but hey, it works.
Save as: run_last_modified.sh.
Cheers
#!/bin/bash
# Runs last modified script in new Terminal window tab in dev qube.
# Requires xdotools to be installed in the dev qube.
# (debian) sudo apt install xdotool / (fedora) sudo dnf install xdotool
# Add hotkey to custom shortcuts. Change 'dev' to match your development qube name.
# qvm-run dev '/home/user/Documents/run_last_modified.sh'
# Global vars
qube_name='dev' # Change 'dev' to match your development qube name.
code_directory='/home/user/Documents/' # change to match your working code directory.
last_modified='' # Last modified file in code directory.
file_path='' # Full file path of last modified file.
# Saves current focused window.
save_file(){
# Simulates ctr+s keystrokes in window with focus.
# Requires xdotools installed.
xdotool key ctrl+s
# Stops script if there is no code directory.
no_code_directory_error(){
msg="There was a problem accessing $code_directory in $qube_name qube.\
Check your code directory setting and try again."
notify-send "$msg";echo "$msg"
exit
# Gets the last modified file in the code directory.
get_filename(){
cd "$code_directory" || no_code_directory_error # Stop script if directory doesn't exist.
last_modified=$(ls -t | head -n1)
echo "$last_modified"
# Returns full file path.
get_full_path(){
# $1=filename
file_path="$code_directory$1"
echo "$file_path"
# Stops script if last modified file is this one.
check_filename(){
# $1=file name
# Guard clause to prevent recursive call.
if [ "$1" == 'run_last_modified.sh' ]; then
msg='Last modified file is run_last_modified.sh.
Stopping execution...'
exit
fi
echo "$1"
# Makes file executable if it isn't already.
make_executable(){
#$1=file_path
msg="Making $file_path executable..."
# notify-send "$msg";echo "$msg"
echo "$msg"
sudo chmod +x "$1"
echo "$1"
# Opens a new terminal window and runs the file.
run_in_terminal(){
# $1=file_path
msg="Running $1
in $qube_name Terminal..."
sudo gnome-terminal --tab --wait --active --geometry=120X60 \
--title="$1" --working-directory="$code_directory" \
-- bash -c "$1; exec bash"
run(){
# Pipeline
save_file # Emulates ctrl+s in the current active window.
last_modified=$(get_filename)
file_path=$(get_full_path "$last_modified")
check_filename "$last_modified"
make_executable "$file_path"
run_in_terminal "$file_path"
run
################## TESTS #################
# Note to self: Comment out run ^^^ before running tests.
tests(){
set -x # for debugging.
# Save current file in active window test.
# save_file
# get filename test.
msg="Last modified: $last_modified"
# get filepath test.
msg="File path: $file_path"
# Make executable tests.
# Run in Terminal test.
# Note. Sample script called test.sh
# Must be placed in code directory before running test.
last_modified='test.sh'
# Check filename test.
# Comment out when running other tests.
last_modified='run_last_modified.sh'
# check_filename "$last_modified" # Should stop execution.
# tests
