Screen Brightness problems NovaCustom NV41
NovaCustom NV41 is a certified laptop for Qubes OS
I found a problem. Fn + F8/F9 does not works at all. And i cant increase or decrease screen / display brightness in any ways. How to manage this problem?
@NovaCustom
Hello,
I’m sorry for my late reply, I didn’t see your post until now.
I assume you installed Qubes OS yourself? It looks like you did not select kernel-latest (last Grub option) while installing Qubes OS. Can that be the case?
It might be the easiest solution to just reinstall Qubes OS that way.
Hello!)) Thanks for answer. Can I somehow upgrade kernel? Will it be upgraded in next dom0 updates?
Witch version of kernel is required for this? I have 5.15.103
sudo qubes-dom0-update kernel-latest
Kernel 6.1. The command to install is provided in the command above. Thank you for mentioning this, @disp6252.
I did kernel upgrade. Now 6.1 But problem still exists. Sound control (fn + f5/f6) works. But screen brightness (fn + F8/F9) control dont work =((
Thank you for getting back to me.
I’m sorry to say that I do not have an easy solution.
If you ordered your laptop with Qubes OS certified, you can apply for warranty.
If you installed Qubes OS yourself, the only suggestion I have is to perform a reinstallation while using the kernel-latest Grub option when booting to the installation pen drive.
Also, please make sure that you are using the latest Dasharo firmware, which is v1.6.0 for now.
For anyone reading this, please note that kernel-latest should no longer be selected, starting from Qubes OS version R4.2.0 (and higher).
@novacustom,
Could you please clarify whether you are saying that it is not necessary to install or not advised to do so (i.e. because it would cause breakage)?
Not advised. Customers have reported stability issues with the current kernel-latest option, although we do not have clear reports. The kernel latest option for R4.1 was adopted by R4.2 as a stable kernel, which is why the option doesn’t need to be selected anymore.
That’s interesting; I run kernel latest with QubesOS 4.2 on my NV41. What stability issues were reported?
There was an issue with network connectivity after resuming from suspend, although that seems to be related to Heads only. At first, we were suspecting that the issue was caused by the kernel-latest option, but it hasn’t been confirmed.
kernel-latest has received much less testing which is why it shouldn’t be used if it’s not necessary. And it’s no longer necessary starting from Qubes OS R4.2.
