Like:
- Reaching a state means requesting something and also making sure things are really done.
- Pillar helps me to avoid hard-coding secrets in the code
Dislike:
- jinja mixed with yaml. It is like mixing macros and .ini config files. You see a bunch of
% {{ things that look semi-python }} %and- name: {{ variable }}. You can also make for loops within yaml. I think those are actually macros… - it is not python. Why do I need to mix yaml for config and jinja for logic? Can I keep data and logic as separated as possible?
- Pillar holds both user’s arguments and secrets and internal non-local variables…
– It seems that pillar is the way to pass (global) variables between two parts of a workflow.
– But that pillar thing also allows the user to pass arguments into the workflow, like ‘do you want to install fedora/debian’?
– Mixing the internal and front-end seems wrong. It is like having a TV controller were some buttons are normal buttons but you have a hundred extra buttons that controls the internals: buttons that say 'connect/disconnect the power to transistor #113`. - how to document this thing?
- how to test this thing without learning a bunch of other stuff?
- ‘execution modules’ are pure python function / libraries. But I can’t find how can my custom function take yaml style arguments (e.g. ‘- name: install_tripwire’).
Since I don’t have a million qubes, I don’t need parallel execution/execution graph/out of order execution. I can use 1 function per step in the workflow and each step would call only 1 other step.
What do you think about Salt?
So far it leaves a bitter taste in my mouth.
