Sabotaged? Or just a simple case of for-idiots-by-idiots?
You are a journalist working with sensitive information. You heard so much about the mighty thing called Qubes OS. You don’t have money for the latest gear so you kept using an old laptop. You saw Qubes OS 4.3.2 and downloaded it. You checked its integrity, all good.
You burned the 8GB iso file and checked the DVD afterward. Every bit matched. So far so good.
You popped the DVD in the laptop and rebooted. Boot menu appeared. You selected the first menu item, hit Enter to install the thing. You waited almost 90 seconds watching a black screen and wondered what was going on…
until you saw this:
Firmware bug? WTF! You used this laptop for years and no Windows, no Linux had ever complained about firmware bug. Whatever, who cares. But then: Unsupported parameter ‘huge’? Looked like some idiots did not even know what correct parameter for tmpfs should be.
The screen scrolled fast and soon enough you were welcomed with Anaconda’s first graphical beauty, politely asking you to select a language. You reached out for the mouse (not cat!), but before you could click on English, there was this:
You were offered three options: Report this crap, debug it yourself, or f… off. You chose the third.
The machine rebooted from DVD again. You hoped miracle would happen this time, but it did not. You waited another 90 seconds, saw the same errors, and were offered the same set of options. You chose the third again. You wasted the DVD. It became totally useless, but you didn’t care.
Maybe God just switched a light bulb in you, and you took the 8GB iso file and dd-d it to a USB flash drive. You were lucky to find a 16GB one lying around because the iso file was in fact bigger than 8GB.
And miracle happened. You still had to wait 90 seconds, saw the nonsense error messages, but this time you could click English, providing the usual stuffs, and watched the progress bar slowly moved forward. It was so slow and you decided to have a coffee. By the time you finished it and came back, Anaconda overjoyedly informed you that you could restart the computer and used Qubes OS right away. You clicked the Restart button and Anaconda went away. But Restart did not work. You patiently waited, sometimes you moved the still-alive mouse on the absolute black screen, and waited, and waited, and waited. But enough was enough. After 10 minutes of waiting, you pressed the Power button to shutdown the laptop.
Of course, you powered the laptop back immediately. Qubes OS booted up. But the “start using Qubes OS immediately” promise was a little lie from Anaconda’s part. You had to continue the second phase of setup process which was long enough for a nap.
The waited moment arrived. You entered the password and logged in. For a test, you plugged in a USB flash drive on which there were two partitions, recognized by sys-usb as sda1 and sda2. There was also sda in case you need to attach the whole USB to some VM. That was sane, as expected.
You attached sda1 to sys-net. Kind of stupidity, but why not? It was just a test.
Looking at the device applet, Qubes OS informed you that sda1 was being attached to sys-net, sda2 was free and ready for being attached to any VM. sda was gone. It was logical to prevent you from attaching the whole USB to some VM when one of its partitions is being used. That was thoughtful.
Then you detached sda1 from sys-net.
You looked at the device applet again but then there was no sda. It did not come back. Logically it should have. But you were not surprised. You knew it. It was an error and it had been on GitHub for years. The hidden block devices due to attachment are not restored after detachment · Issue #9566 · QubesOS/qubes-issues · GitHub
And for the shake of a complete test, you attached sda1 to sys-net again. You saw this error, but once more time, no surprise. This error had been on GitHub for months if not years too. Strange behavior of Qubes Devices widget when attaching and detaching block devices · Issue #10180 · QubesOS/qubes-issues · GitHub
You power off the laptop, took the hard drive out to another computer and reformat it. So much about the mighty Qubes OS. It was just a piece of junk. You wasted a DVD, and above all, you wasted a lot of time testing it.
Now that you were calm, you analyzed what was happening with this project. You had been using Qubes OS for many years by now. You remembered when it was really good. 4.1 series perhaps? Then came 4.2 series when things started to fall apart: Old bugs not fixed, needed features never worked properly, useless features introduced, more bugs discovered. User interface became huge and colorful. You felt like you were kindergarten. User support was a kind of joke. Developers were quick to dismiss new bug report claiming it was a replica of another unfixed one, or simply logged to wrong place or in wrong format. They tried really hard to keep the error figure down instead of fixing any.
The recent 4.3 series was a real catastrophe. The iso of previous 4.3.1 release was above 6.5GB, this iso was 8GB+. 1.5GB of junks was added while a simple and obvious error with attaching block device has still not been addressed. Fixing it shouldn’t be rocket science. It worked fine in 4.1 series. Some idiots just f…ed it up, other idiots just didn’t care…
Once there was a girl worked in this project. What was her name? You don’t remember. Joanna Rutkowska? Anyway, she was smart. But she left the project for God knows why. Maybe she left for a reason. Since her departure, you, the end user, could experience the plummeting of Qubes OS in term of quality. You wonder where the bottom would be, but there seems no sign of it.
The project website still displays “A reasonably secure operating system” text with testimonials from experts. Where are you now, mister Snowden? Are you still using this? Is this project being sabotaged from inside? Or is this just a classic case of for-idiots-by-idiots? - You wonder.
You ditched this new 4.3.2 release and continue using the now unsupported version. Being supported meant you were forced to throw away what worked well for you in exchange of junks and bloatware. You felt like a dog running after a fake bone in a track to never get it. You felt tired and probably now is the time to quit. You just don’t know.
Is there hope?
