sudo -u user xmodmap -e "keycode 123 = NoSymbol"
Why doesn’t this work in rc.local?
I want to disable a key, 123 is just place holder
if I run in terminal it works, but not in rc.local
Because it is called before X is started. Try xprofile or xsession(rc): xprofile - ArchWiki.
Hi thomas85135 - and welcome to the forum. ![]()
Even if X was started, I believe that you would still need to know the name of the $DISPLAY and the MIT-MAGIC-COOKIE for the DISPLAY you want to change. ![]()
You can have a look at command like:
xauth list
in various terminals/qubes.
Thanks for your comment
I added xmodmap -e "keycode 123 = NoSymbol"
to .xsessionrc and .xprofile and restarted the Qube, but it did nothing. Executing manually with sh .xsessionrc applies the command
Hi
I know about $DISPLAY and tried export DISPLAY=:0 before the command in my rc.local, it did not work
xauth list says this:
xauth: file /home/user/.Xauthority does not exist
Hi thomas85135
What does xauth list show in a terminal from dom0? – is XAUTHORITY defined? ![]()
Does it change, if you use:
xauth -f /some/where list
Note: The path to /some/where should be shown by echo $XAUTHORITY in a dom0 terminal.
So it shows in dom0 terminal, but important detail, I’m trying to do this only in AppVM so it doesn’t apply everywhere
Will I still need this from dom0?
Hi thomas85135
Sorry – I didn’t see the fact/detail, that you would like to keep it in/for a only AppVM.
Looking at the processes started in an AppVM, it doesn’t look like the processes are started like usual by the Display Manager – and then it makes sense that .xsessionrc and .xprofile isn’t executed like a normal setup. So I don’t know the best way to resolve your issue … ![]()
Hi
so it works with DISPLAY=:0 sudo -u user xmodmap -e "your command here", but it has to be run at the right time
it takes a few seconds before command works, so i waited for xorg to run in appvm
then i run it, but it only works sometimes, very unreliable
i tried to do this, run in loop xmodmap command, then read back xmodmap -pk and if change was done then stop, but still unreliable every 3rd boot it wouldn’t apply
In the end I just run my command in a loop for 60 seconds after appvm boot, I don’t like it but it works
