Rpc + qrexec issue
i’m trying for first time RPC + QREXEC, but not works. when i do command “qrexec-client-vm vault restic.Password” from targetvm (vault-backup-restic) nothing happen, no error, nothing.
I followed the steps below. is there something wrong?
Is it right to put rcp script into “/rw/config/qubes-rpc”? qubes copy it automatically to etc at startup?
thank you
  1. Into the AppVM vault (offline):
    a. Create file that contains Restic password:
    sudo nano /rw/config/restic-pass
    herewritesecretpassword
    sudo chmod 600 /rw/config/restic-pass
    b. Create script RPC that reads the password file:
    sudo mkdir -p /rw/config/qubes-rpc
    sudo nano /rw/config/qubes-rpc/restic.Password
    Inside:
    #!/bin/sh
    exec sudo /bin/cat /rw/config/restic-pass
    c. Make script executable:
    sudo chmod 755 /rw/config/qubes-rpc/restic.Password
    d. Test:
    sudo cat /rw/config/restic-pass
    deve stampare esattamente la tua password segreta
    sudo /rw/config/qubes-rpc/restic.Password
    deve stampare la stessa password tramite lo script RPC.
  2. Into Dom0:
    e. Define the policy:
     sudo nano /etc/qubes/policy.d/30-restic-password.policy
     Inside:
     restic.Password + vault-backup-restic vault allow
     restic.Password + @anyvm @anyvm deny
    f. Test if policy works. If its works, output will be “Allowed”.
     qrexec-policy-exec vault-backup-restic vault restic.Password+
  3. Into AppVM vault-backup-restic(offline):
    f. Test if policy works. If its works, output will be the restic-pass.
Why did you create your RPC program in /rw/config/qubes-rpc?
/etc/qubes-rpc/RPC_ACTION_NAME when you make it in the template qube;
/usr/local/etc/qubes-rpc/RPC_ACTION_NAME for making it only in an app qube.
Qrexec: secure communication across domains — Qubes OS Documentation
Change + to *.
But I’m not sure if it’s needed. Maybe + could be treated as an empty argument and you’ll need to call qrexec-client-vm vault restic.Password+ instead of qrexec-client-vm vault restic.Password.
