Sometime I encounter a bug that happen a lot of time and it can happen with every different template that i’m using (debian,fedora, whonix …) where when i’m doing a right click on a application (All application can be affected) the windows of the right click will pop-up is under the current windows and not above as it’s should be. And it can do that for one application for whatever reason, without effecting other application of the same AppVM. To fix this, I need to close the application and open it again to be able to see the right click working.
Qubes OS 4.0.3 with awesomeVM with everything updated.
