In Windows, there is an option to “Reset this PC” which reinstalls Windows and keeps your personal files. Is there a way to do something like this in Qubes?
Is it normal for Qubes to get slower over time?
no
Sort of yes. You make a backup of all your qubes. You reinstall the OS. Then you restore the qubes from the backup. You system is reset and all your files are still here.
it not truly a reset but it worth mentioning (i forgot to say that)
