I’m running on a Librem. Every time the battery drains completely the internal clock is blanked.
I have to reset the clock manually in recovery mode using: date -s (manually imputing date/time)
and then hwclock --systohc
This gets the network working so long as I can get the time accurate to the second. But my 2 factors don’t work. I can imagine it is because of a time sync issue.
Is there another command that will resync the time with network time across all qubes?
My last laptop had no battery left at all and the internal clock resets with the date of 2013 everytime i start the laptop! but, once I was connected to the internet, By simply doing a
sudo qvm-sync-clock
the date and time would resynchronize directly with the network and everything was correct for the different qubes. I don’t know if it will change anything but is ntp sevice enabled?..
2f is from password managers. Using date -s, I’ve set the time to the computer timezone setting.
Networks works afterward. 2 factors are still off. What does that suggest?
@Emily Maybe it’s a stupid question (sorry but my native language is not English so I may not have understood correctly) but Is your sys-net have the right time when connected to the internet?
Strange…but it seems to have fixed itself.
This is the pattern. It dies… network goes down…I reset…sometimes network works…sometimes it doesn’t… I reboot… sometimes that works…sometimes it doesn’t…then it randomly fixes itself.
I always thought it could be the internal battery that was dead. Maybe it could come from there? Your problem happens when your battery is empty, a bit like me who couldn’t get a battery anymore…
