Since a few weeks I experience crashes caused by overheating when using more the 2 vcups for a dedicated qubes whilst having high CPU load. Thoose crashes accrue for high cpu load jobs like zoom or compiling lager programs. For a crash to happen, high CPU load (98%-100%) is required for something between 5 and 30 minutes.
I had this issue some time ago on one of my two T430’s. Replacing the delta-fan with a non-delta one fixed it. But I still have a delta one (less loud) in the second T430 without issue.
Basically: when it’s too hot it’s too hot. Ambient room temperature is a factor (I live in Texas). So I positioned my machine to be on a desk directly under the AC outlet in the ceiling.
Keep in mind: the T430 is designed for 35W CPUs. The i7–3840QM which you and I are using is a 45W CPU, so we are pushing it across it’s design limits from the start. It works, but no question you need to keep this machine cool.
