Hello
How to remove it correctly?
Thanks
Hello
Thanks
Can’t you delete it from Qube Manager?
I can, but maybe it will break something (?)
Maybe need to delete “tails” on the system?
I deleted a lot of templates that way and got no issues, so I assume it will be fine for you too.
Please remember that some users wont see images that you post.
It would take you a few seconds to report the actual error - probably
less time than it takes to take an image and attach it to your message.
The correct way in 4.1 is to use the Qubes Template Manager -
qvm-template or qvm-template-gui in dom0.
You should use this tool for all operations on templates -
install/reinstall/removal.
