I try to create ssh key using
ssh-keygen
when i read file of private key, it is key for a user in a Qubes name (such as sxyle33@QubeforRemminaonly). It shows both username and qubes name as owner of key.
when I put public key on server and try to connect using private key, i put in username of “root” and it does not connect
is trouble with connecting because qube creates key just for user “sxyl33@QubesforRemminaonly” instead of using root as username? If I edit file and replace that with root, will fix?
I keep fail to connects with Remmina using the SSH created by the Qubes.
