Reinstalling templates?
How do I reinstall a template in 2023? the documentation i read says to type a package name in a specific way, but i have no package with that name.
if i list all my installed packages with dnf, there are no packages following the name of my templates.
any help?
what you mean by 2023?
  1. if you have sys net and firewall working, you can just run qvm-template-gui in dom0 then install new template.
  2. if you dont have have those sys running, download qubes iso somewhere, flash it to your drive, attach the drine in dom0, mount the drive to /mnt, copy template from /mnt to dom0, then install template.
If the automatic method doesn’t work for you, try the manual method.
