Hi everyone!
I have encountered the error “VG qubes_dom0 metadata too large for circular buffer” upon starting a VM previously. That time, I was able to extent the partition size for meta data with this command:
sudo lvextend --poolmetadatasize +500M qubes_dom0/pool00
Now I have encountered the same problem again, the above command helped to start one more VM, but starting the second VM triggered the same error again.
sudo lvs -a gives the following output:
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
[lvol0_pmspare] qubes_dom0 ewi------- 360.00m
pool00 qubes_dom0 twi-aotz-- 349.18g 85.10 24.47
[pool00_tdata] qubes_dom0 Twi-ao---- 349.18g
[pool00_tmeta] qubes_dom0 ewi-ao---- 1.33g
root qubes_dom0 Vwi-aotz-- 349.18g pool00 4.33
swap qubes_dom0 -wi-ao---- 30.86g
Do you have any idea what I could try to fix this? Thanks!
