@phceac
qubesd.service
Dez 27 09:18:01 dom0 systemd[1]: Starting qubesd.service - Qubes OS daemon...
Dez 27 09:18:03 dom0 qubesd[4463]: libvirt: XML-RPC error : Cannot recv data: Connection reset by peer
Dez 27 09:18:03 dom0 qubesd[4463]: ERROR: Task was destroyed but it is pending!
Dez 27 09:18:03 dom0 qubesd[4463]: task: <Task pending name='Task-1' coro=<virEventAsyncIOImpl._ff_callback() running at /usr/lib64/python3.13/site-packages/libvirtaio.py:329>>
Dez 27 09:18:03 dom0 qubesd[4463]: /usr/lib64/python3.13/asyncio/base_events.py:750: RuntimeWarning: coroutine 'virEventAsyncIOImpl._ff_callback' was never awaited
Dez 27 09:18:03 dom0 qubesd[4463]: self._ready.clear()
Dez 27 09:18:03 dom0 qubesd[4463]: RuntimeWarning: Enable tracemalloc to get the object allocation traceback
Dez 27 09:18:03 dom0 qubesd[4463]: Traceback (most recent call last):
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/bin/qubesd", line 5, in <module>
Dez 27 09:18:03 dom0 qubesd[4463]: sys.exit(main())
Dez 27 09:18:03 dom0 qubesd[4463]: ~~~~^^
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/tools/qubesd.py", line 46, in main
Dez 27 09:18:03 dom0 qubesd[4463]: args = parser.parse_args(args)
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/tools/__init__.py", line 426, in parse_args
Dez 27 09:18:03 dom0 qubesd[4463]: namespace.app = qubes.Qubes(
Dez 27 09:18:03 dom0 qubesd[4463]: ~~~~~~~~~~~^
Dez 27 09:18:03 dom0 qubesd[4463]: namespace.app, offline_mode=namespace.offline_mode
Dez 27 09:18:03 dom0 qubesd[4463]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Dez 27 09:18:03 dom0 qubesd[4463]: )
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/app.py", line 1040, in __init__
Dez 27 09:18:03 dom0 qubesd[4463]: self.load(lock=lock)
Dez 27 09:18:03 dom0 qubesd[4463]: ~~~~~~~~~^^^^^^^^^^^
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/app.py", line 1164, in load
Dez 27 09:18:03 dom0 qubesd[4463]: vm.fire_event("domain-load")
Dez 27 09:18:03 dom0 qubesd[4463]: ~~~~~~~~~~~~~^^^^^^^^^^^^^^^
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/events.py", line 200, in fire_event
Dez 27 09:18:03 dom0 qubesd[4463]: sync_effects, async_effects = self._fire_event(
Dez 27 09:18:03 dom0 qubesd[4463]: ~~~~~~~~~~~~~~~~^
Dez 27 09:18:03 dom0 qubesd[4463]: event, kwargs, pre_event=pre_event
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/events.py", line 169, in _fire_event
Dez 27 09:18:03 dom0 qubesd[4463]: effect = func(self, event, **kwargs)
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/ext/block.py", line 327, in on_domain_init_load
Dez 27 09:18:03 dom0 qubesd[4463]: device_attachments = self.get_device_attachments(vm)
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/ext/block.py", line 357, in get_device_attachments
Dez 27 09:18:03 dom0 qubesd[4463]: xml_desc = lxml.etree.fromstring(vm.libvirt_domain.XMLDesc())
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/vm/adminvm.py", line 147, in libvirt_domain
Dez 27 09:18:03 dom0 qubesd[4463]: self._libvirt_domain = self.app.vmm.libvirt_conn.lookupByID(0)
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/app.py", line 219, in libvirt_conn
Dez 27 09:18:03 dom0 qubesd[4463]: self.init_vmm_connection()
Dez 27 09:18:03 dom0 qubesd[4463]: ~~~~~~~~~~~~~~~~~~~~~~~~^^
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/app.py", line 210, in init_vmm_connection
Dez 27 09:18:03 dom0 qubesd[4463]: self._libvirt_conn = VirConnectWrapper(
Dez 27 09:18:03 dom0 qubesd[4463]: ~~~~~~~~~~~~~~~~~^
Dez 27 09:18:03 dom0 qubesd[4463]: qubes.config.defaults["libvirt_uri"],
Dez 27 09:18:03 dom0 qubesd[4463]: reconnect_cb=self._libvirt_reconnect_cb,
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib/python3.13/site-packages/qubes/app.py", line 122, in __init__
Dez 27 09:18:03 dom0 qubesd[4463]: self._conn = libvirt.open(uri)
Dez 27 09:18:03 dom0 qubesd[4463]: ~~~~~~~~~~~~^^^^^
Dez 27 09:18:03 dom0 qubesd[4463]: File "/usr/lib64/python3.13/site-packages/libvirt.py", line 335, in open
Dez 27 09:18:03 dom0 qubesd[4463]: raise libvirtError('virConnectOpen() failed')
Dez 27 09:18:03 dom0 qubesd[4463]: libvirt.libvirtError: Cannot recv data: Connection reset by peer
Dez 27 09:18:03 dom0 systemd[1]: qubesd.service: Main process exited, code=exited, status=1/FAILURE
Dez 27 09:18:03 dom0 systemd[1]: qubesd.service: Failed with result 'exit-code'.
Dez 27 09:18:03 dom0 systemd[1]: Failed to start qubesd.service - Qubes OS daemon.
Dez 27 09:18:04 dom0 systemd[1]: qubesd.service: Scheduled restart job, restart counter is at 1.
libvirtd.service
○ libvirtd.service - libvirt legacy monolithic daemon
Loaded: loaded (/usr/lib/systemd/system/libvirtd.service; enabled; preset: disabled)
Drop-In: /usr/lib/systemd/system/service.d
└─10-timeout-abort.conf, 50-keep-warm.conf
Active: inactive (dead)
TriggeredBy: ○ libvirtd-ro.socket
○ libvirtd-admin.socket
× libvirtd.socket
Docs: man:libvirtd(8)
https://libvirt.org/
libvirtd.socket
× libvirtd.socket - libvirt legacy monolithic daemon socket
Loaded: loaded (/usr/lib/systemd/system/libvirtd.socket; enabled; preset: disabled)
Active: failed (Result: resources) since Sat 2025-12-27 09:18:03 CET; 5min ago
Duration: 2.493s
Invocation: 3d8d69693ca44814ba5868a0059506f0
Triggers: ● libvirtd.service
Listen: /run/libvirt/libvirt-sock (Stream)
Dez 27 09:18:01 dom0 systemd[1]: Listening on libvirtd.socket - libvirt legacy monolithic daemon socket.
Dez 27 09:18:03 dom0 systemd[1]: libvirtd.socket: Failed to queue service startup job: Unit virtlogd.socket not found.
Dez 27 09:18:03 do
I can’t start virtlogd.service or .socket, just found this, sounds similar:
○ virtlockd.service - libvirt locking daemon
Loaded: loaded (/usr/lib/systemd/system/virtlockd.service; disabled; preset: disabled)
TriggeredBy: ● virtlockd.socket
● virtlockd-admin.socket
Docs: man:virtlockd(8)
