Thanks, marmarek. Here are my findings.
First, I’d like to point out that dmesg in dom0 and in sys-audio with audio device attached have the following apparent difference:
In dom0:
[ 5.678019] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 5.678020] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 5.678022] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 5.678023] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 5.678023] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 5.678024] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 5.678024] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 5.725769] input: PC Speaker as /devices/platform/pcspkr/input/input17
But the above messages didn’t show up in sys-audio. Module snd_hda_codec_realtek has been installed in sys-audio.
Secondly, pulseaudio control panel in dom0 shows that my audio card is named “Family 17h (Models 10h-1fh) HD Audio Controller”, but in sys-audio it is named “Built-in Analog Stereo”. However, alsamixer shows that it has successfully identified its model “ALC257”.
Also, pulseaudio doesn’t autostart in sys-audio. But I think this is a trivial thing and fixes easily.
Other results are nothing special.
lspci -v in sys-audio:
00:06.0 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
Subsystem: Lenovo Device 382c
Physical Slot: 6
Flags: bus master, fast devsel, latency 0, IRQ 69
Memory at f2010000 (32-bit, non-prefetchable) [size=32K]
Capabilities: <access denied>
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:07.0 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
Subsystem: Lenovo Device 381b
Physical Slot: 7
Flags: bus master, fast devsel, latency 0, IRQ 70
Memory at f2018000 (32-bit, non-prefetchable) [size=16K]
lspci -v in dom0:
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 39
Memory at d04c8000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: pciback
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 36
Memory at d04c0000 (32-bit, non-prefetchable) [size=32K]
Almost the same.
dmesg | grep MSI in sys audio:
[ 0.367757] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
The same in dom0.
dmesg | grep INT in sys audio:
[ 0.011927] ACPI: DSDT 0x00000000FC001040 0092A3 (v02 Xen HVM 00000000 INTL 20190509)
[ 0.011937] ACPI: SSDT 0x00000000FC00A5D0 000031 (v02 Xen HVM 00000000 INTL 20190509)
[ 0.011938] ACPI: SSDT 0x00000000FC00A610 000031 (v02 Xen HVM 00000000 INTL 20190509)
[ 0.016797] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.016799] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 low level)
[ 0.016799] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 low level)
[ 0.016800] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 low level)
in dom0:
[ 0.464470] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.464474] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
Nothing special.
dmesg | grep interrupt in sys audio:
[ 0.362651] ACPI: Using IOAPIC for interrupt routing
in dom0:
[ 0.655022] ACPI: EC: interrupt blocked
[ 0.655186] ACPI: Using IOAPIC for interrupt routing
[ 0.698781] ACPI: EC: interrupt unblocked
