Because of this bug I had given up on Windows HVMs for a while - but now I have more reasons to want to run Win7 HVMs and there have been many updates to Xen etc so thought I’d give it a shot. Sadly, I see no marked improvement:
> Assigning my Win7 HVM more than 3GB of RAM makes it unable to
start:
> [alex@dom0 ~]$ qvm-start --debug win7
> --> Loading the VM (type = HVM)...
> xc: error: panic: xc_dom_bzimageloader.c:634:
xc_dom_probe_bzimage_kernel:
> kernel is not a bzImage: Invalid kernel
Ignore this message.
> libxl: error: libxl_device.c:479:libxl__wait_for_device_model
Device Model
> not ready
But this can be a problem. Perhaps the result of zombie win7-dm
from previous
failed boot. But the first one failed for some other reason.
Here is what happens after a fresh boot:
xc_dom_probe_bzimage_kernel: kernel is not a bzImage: Invalid kernel
xc: error: panic: xc_dom_boot.c:159: xc_dom_boot_mem_init: can't
allocate low memory for domain: Out of memory
libxl: error: libxl_dom.c:207:libxl__build_pv xc_dom_boot_mem_init
failed: Device or resource busy
xl: fatal error: libxl_create.c:499, rc=-3:
libxl__create_device_model
libxl: error: libxl_dm.c:763:libxl__destroy_device_model Couldn't
find device model's pid: No such file or directory
libxl: error: libxl.c:740:libxl_domain_destroy
libxl__destroy_device_model failed for 3
ERROR: Failed to load VM config
[alex@dom0 ~]$ xl list
Name ID Mem VCPUs
State Time(s)
dom0 0 6166 4
r----- 88.5
netvm 1 200 4
-b---- 17.4
firewallvm 2 1512 4
-b---- 11.2
win7-dm 4 17 0
--p--- 0.0
[alex@dom0 ~]$
> xl: fatal error: libxl_create.c:536, rc=-1:
> libxl__confirm_device_model_startup
> [alex@dom0 ~]
Check this logs:
/var/log/xen/console/guest-win7*
/var/log/xen/console/hypervisor.log
/var/log/xen/xl-win7.log*
This is the same problem that I reported in the thread "intermittent
error starting HVM" to which nobody replied. Basically, if you assign a
lot of memory to an HVM, it will not always start. If it fails, type
"sync", wait about 10 seconds, and try again. It will often succeed on
the second or third try. It has something to do with memory
fragmentation in xen (so I am told.) I guess maybe xen needs to find
contiguous memory for the HVM?
Not sure it's the same, because my Win7 HVM will simply *not start* for
days now, across reboots etc.
Hope the above provide some hint as to what's going on, as this is turning
out to be a functionality killer
Alex
to Xen etc so thought I'd give it a shot. Sadly, I see no marked
improvement:
populating video RAM at ff000000
Failed to populate video ram
close(0)
GPF rip: 0xff114, error_code=0
Thread: main
It seems the video RAM bug is still there - even with this new HVM with
only 2GB of RAM given to the HVM. Please note there are no zombie VMs -
they've all been killed with xl destroy.
Anything new we can try?
I'm trying to reproduce this. HVM with 4GB works perfectly for me... It fails
with 6GB, but this can be real out of memory.
But found another problem - stubdom output isn't logged to
/var/log/xen/console/*.log. So check timestamp of this logfile - is those
entries the fresh one?
If not - edit /etc/sysconfig/xencommons, add "XENCONSOLED_TRACE=all" and
reboot the system.
start:
Device Model
> not ready
from previous
Name ID Mem VCPUs
State Time(s)
dom0 0 6166 4
r----- 88.5
netvm 1 200 4
-b---- 17.4
firewallvm 2 1512 4
-b---- 11.2
win7-dm 4 17 0
--p--- 0.0
[alex@dom0 ~]$
> [alex@dom0 ~]
Check this logs:
Alex
improvement:
close(0)
Thread: main
I think I found something. When trying to start HVM with 6GB, this appears in
xl dmesg:
(XEN) memory.c:134:d0 Could not allocate order=9 extent: id=43 memflags=0 (2 of 4)
(XEN) memory.c:134:d0 Could not allocate order=9 extent: id=43 memflags=0 (0 of 4)
id=43 is XID of just created HVM, order=9 is 2MB (2^9*4kB). So this basically
means that there isn't enough free 2MB super pages in the system. Perhaps
memory is too fragmented...
Some time ago I tried to find a way to force to use only 2MB memory chunks (to
not split them to individual 4kB pages), but without success.
reboot the system.
Actually "service xencommons restart" is enough, full reboot not needed.
