Michael Singer:
I am looking for a really secure way to use Qubes for searching not
only a hard drive for file names, but for text that is in files.The goal is to avoid an exploit in the searched files leading to a
takeover of the hard drive by malware.The total size of all my files is too large for me to put them all
in one qube before searching for text in them.Would it perhaps be possible to mount only a single partition of the
hard drive into a qube, but not with write permissions, only read
permissions?Yes, e.g. like this:
$ qvm-block attach --ro destinationvm sys-usb:sda1
Then you can decrypt and mount the read-only /dev/xvdi in the
destination VM.I would do the search on command line, using "grep" for plain text
files, "pdfgrep" for PDFs, and something for table files, databases,
etc.Is my idea feasible? And how secure would it be?
Sounds fine to me. But malicious content could still exploit the
destination VM, so consider attaching to a DisposableVM (after
switching off its networking).If your partition is LUKS1[1] encrypted, Split dm-crypt[2] might be
convenient. Its default behavior is to attach the decrypted partition
to an offline DisposableVM:$ qvm-block-split attach --ro sys-usb:sda1
[1] TODO: LUKS2 support
[2] GitHub - rustybird/qubes-split-dm-crypt: Isolate secondary storage dm-crypt and LUKS1 header processing to Qubes DisposableVMs>
Dear Rusty Bird,
thank you very much for your advice. I had to find a way to mount the read-only volume in the destination qube. I discovered the page Redirecting… But it doesn't say how to mount it either. The normal way with "$ sudo mount /dev/xvdi /mnt" does not seem to work for read-only. You have to tell the mount tool that it is a read-only device: "$ sudo mount -o ro,noload /dev/xvdi /mnt" This way it works. Perhaps this should be added to the documentation.
I read the notes about your split-dmcrypt-tool. Good work! Let's assume I would not work with LUKS. Suppose I mount sda1 with read-only option set in a DispVM (after switching off its network), decrypt it there and search in the files. An exploit bug occurs and the VM is taken. Now it could happen that someone leaks the partition password to the internet via a covered channel. So would it be safer to mount the decrypted volume again in another DispVM before we search it? And how would that be done? With the loopdevice method? What commands would you use in the terminal?
Many thanks
Michael Singer
