I wanted to document the stuffs i did, but starting over fresh the RDP service dies right away. To replicate:
Install QubesOS 2.4.2 normally. For easier potential troubleshooting, i did not to encrypt the hard drive.
in dom0 install ssh and rdp:
sudo qubes-dom0-update xrdp openssh-server
Enable ssh and rdp in dom0:
sudo systemctl enable --now xrdp
sudo systemctl enable --now sshd
Go into policy editor and create 30-remote-admin. Allow the ssh port.
qubes.ConnectTCP +22 sys-net @default allow target=dom0
Connect to dom0 in sys-net:
qvm-connect-tcp 22:@default:22
Install tools in sys-net:
sudo dnf install xfreerdp
In sys-net connect via SSH to dom0 and do local port forwarding:
ssh -L 3389:127.0.0.1:3389 user@127.0.0.1
Try connecting to RDP on sys-net for troubleshooting:
xfreerdp /v:127.0.0.1 /u:user /p:YourPassword
A RDP window will open and disconnect instantly.
This creates the following logs in dom0:
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC connecting to 127.0.0.1 5910
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: [INFO ] Starting X server on display 10: Xvnc :10 -auth .Xauthority -geometry 1024x768 -depth 32 -rfbauth /home/user/.vnc/sesman_passwd-user@dom0:10 -bs -nolisten tcp -localhost -dpi 96
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: Xvnc TigerVNC 1.13.1 - built Nov 2 2023 00:00:00
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: Copyright (C) 1999-2022 TigerVNC Team and many others (see README.rst)
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: See https://www.tigervnc.org for information on TigerVNC.
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: Underlying X server release 12014000
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: Thu Jul 17 17:37:31 2025
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: vncext: VNC extension running!
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: vncext: Listening for VNC connections on local interface(s), port 5910
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: vncext: created VNC server for screen 0
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: Connections: accepted: 127.0.0.1::47548
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC tcp connected
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: SConnection: Client needs protocol version 3.3
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC security level is 2 (1 = none, 2 = standard)
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: VNCSConnST: Server default pixel format depth 32 (32bpp) little-endian rgb
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: max 255,255,255 shift 16,8,0
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC password ok
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC sending share flag
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC receiving server init
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC receiving pixel format
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC receiving name length
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC sending pixel format
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC sending cursor
Jul 17 17:37:31 dom0 xrdp-sesman[6285]: VNCSConnST: Client pixel format depth 24 (32bpp) little-endian rgb888
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC connection complete, connected ok
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] VNC: Clipboard (if available) is provided by chansrv facility
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] connected ok
Jul 17 17:37:31 dom0 xrdp-sesman[6284]: [INFO ] Found X server running at /tmp/.X11-unix/X10
Jul 17 17:37:31 dom0 xrdp-sesman[6283]: [INFO ] Found X server running at /tmp/.X11-unix/X10
Jul 17 17:37:31 dom0 xrdp-sesman[6283]: [INFO ] Session started successfully for user user on display 10
Jul 17 17:37:31 dom0 xrdp-sesman[6288]: [INFO ] Starting the xrdp channel server for display 10
Jul 17 17:37:31 dom0 xrdp-sesman[6284]: [INFO ] Starting the default window manager on display 10: /usr/libexec/xrdp/startwm-bash.sh
Jul 17 17:37:31 dom0 xrdp-sesman[6283]: [INFO ] Session in progress on display 10, waiting until the window manager (pid 6284) exits to end the session
Jul 17 17:37:31 dom0 audit: BPF prog-id=90 op=LOAD
Jul 17 17:37:31 dom0 audit: BPF prog-id=91 op=LOAD
Jul 17 17:37:31 dom0 audit: BPF prog-id=92 op=LOAD
Jul 17 17:37:31 dom0 kernel: audit: type=1334 audit(1752773851.807:660): prog-id=90 op=LOAD
Jul 17 17:37:31 dom0 kernel: audit: type=1334 audit(1752773851.807:661): prog-id=91 op=LOAD
Jul 17 17:37:31 dom0 kernel: audit: type=1334 audit(1752773851.807:662): prog-id=92 op=LOAD
Jul 17 17:37:31 dom0 systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
Jul 17 17:37:31 dom0 xrdp[6281]: [INFO ] Layout from OldLayout (geom=1024x768 #screens=1) : 1804289383:(1024x768+0+0)
Jul 17 17:37:31 dom0 xrdp-chansrv[6288]: [INFO ] Socket 12: AF_UNIX connection received
Jul 17 17:37:31 dom0 xrdp-sesman[6295]: fuse: failed to exec fusermount: No such file or directory
Jul 17 17:37:31 dom0 systemd[1]: Started systemd-hostnamed.service - Hostname Service.
Jul 17 17:37:31 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 17 17:37:31 dom0 kernel: audit: type=1130 audit(1752773851.882:663): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 17 17:37:31 dom0 xrdp-sesman[6297]: fuse: failed to exec fusermount: No such file or directory
Jul 17 17:37:31 dom0 xrdp-sesman[6300]: fuse: failed to exec fusermount: No such file or directory
Jul 17 17:37:31 dom0 xrdp-chansrv[6288]: [INFO ] sound_process_output_format:
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] wFormatNo 0
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] wFormatTag WAVE_FORMAT_PCM
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] nChannels 2
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] nSamplesPerSec 44100
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] nAvgBytesPerSec 176400
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] nBlockAlign 4
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] wBitsPerSample 16
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] cbSize 0
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] sound_process_output_format:
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] wFormatNo 1
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] nSamplesPerSec 22050
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] nAvgBytesPerSec 88200
Jul 17 17:37:32 dom0 xrdp-chansrv[6288]: [INFO ] sound_process_training: round trip time 4
Jul 17 17:37:32 dom0 xrdp-sesman[6283]: [WARN ] Window manager (pid 6284, display 10) exited quickly (1 secs). This could indicate a window manager config problem
Jul 17 17:37:32 dom0 xrdp-sesman[6283]: [INFO ] Calling auth_stop_session and auth_end from pid 6283
Jul 17 17:37:32 dom0 xrdp-sesman[6283]: pam_unix(xrdp-sesman:session): session closed for user user
Jul 17 17:37:32 dom0 xrdp-sesman[6283]: [INFO ] Terminating X server (pid 6285) on display 10
Jul 17 17:37:32 dom0 audit[6283]: USER_END pid=6283 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix acct="user" exe="/usr/sbin/xrdp-sesman" hostname=? addr=? terminal=:10 res=success'
Jul 17 17:37:32 dom0 audit[6283]: CRED_DISP pid=6283 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_localuser,pam_unix acct="user" exe="/usr/sbin/xrdp-sesman" hostname=? addr=? terminal=:10 res=success'
Jul 17 17:37:32 dom0 kernel: audit: type=1106 audit(1752773852.352:664): pid=6283 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix acct="user" exe="/usr/sbin/xrdp-sesman" hostname=? addr=? terminal=:10 res=success'
Jul 17 17:37:32 dom0 kernel: audit: type=1104 audit(1752773852.353:665): pid=6283 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_localuser,pam_unix acct="user" exe="/usr/sbin/xrdp-sesman" hostname=? addr=? terminal=:10 res=success'
Jul 17 17:37:32 dom0 xrdp-sesman[6283]: [INFO ] Terminating the xrdp channel server (pid 6288) on display 10
I guess it is bootstrapping the wm incorrectly, but
