I don’t understand this.
Why have you not answered my questions?
@CenUriPaa3378 How did you manage to install andox ? Any tutorial to recommend ?
I tried a while back ago, and was a pretty painful experience
What happens if you run
sudo qubes-dom0-updatefrom command line in dom0?
Do you see the 3isec Qubes dom0 repository being updated?
Are there any errors?
I don’t get any errors, just a white page that download things, the page close itself, then I got a new line in the terminal.
I actually didn’t setup my Anbox yet because i’m already killing my brain trying to install pi-hole
Again, you have not answered the question(s).
SO:
Did you follow the instructions at https://qubes.3isec.org/tasks.html?
Specifically:
qubes-task list - observe resultqubes-task install pihole - observe resultLet us know answers to 1-3, and result output from 4 and 5.
I never presume to speak for the Qubes team. When I comment in the Forum or in the mailing lists I speak for myself.hello, finally I downloaded Pi-hole with success on a StandaloneVM. The problem is that I can’t modify the qubes firewall user script file because it’s in read only, same for unbound, I can’t create the pi hole conf file. Any thought? I can’t find a way to write new things.
“The second identity is actually ( Working trough basic app such as Telegram, Discord & Snapchat. ) :”
how did you manage to get snap to work?!
best way to install librewolf?
Well, this is pretty straight forward.
When you are using a Debian template then follow the official instruction here: Installation instructions for Debian or if you prefer Fedora.
did you update you opsec any better ? would love yo hear to do the same woth my setup
what added benefit does pi-hole give if you are already using a strong vpn?
edit: how does it compare to dnscrypt
