On my W530, when using qubes, I get random reboots/power failures, and I can’t find any useful logs, and I am kind of at a loss, but I figured I
Seemingly at random, it will randomly power off and on again, but sometimes it will stay on for hours even while using various qubes and software. I have not had the issue yet today, and it ran from yesterday afternoon to this evening without powering off, but it was just idle, and I anticipate it happening again.
Tried updating/rolling back stock bios, and I flashed 1vyrain again but the issue persisted through all of it. Also tried repasting my cpu, and testing each memory stick.
I had a long installation bios trying to get my encryption configuration to work, and I don’t believe it ever shut down on the installer, nor the bios screen, but I think it happened once immediately after booting and loading initramfs for decryption.
Try memtest86 or memtest86+. I would let it run for 24 hours. Also, you can try a live CD distro to see if you get the same issue. I would suspect hardware issues. Make sure your power supply is good. Try another power supply if you have a spare. Pretty much what user “apparatus” wrote in post above.
