According to Volume backup and revert | Qubes OS , if I run qvm-volume info vmname:private , I should be able to see the above list of “Available revisions (for revert)”, where the last item on the list with the largest integer is the most recent snapshot.
However, this is not the case on btrfs. I can only get how many revisions does the volume have, but I cannot get the exact revision version numbers that can be used for reverting.
[augsch@dom0 whonix-gw-16]$ qvm-volume info whonix-gw-16:root
pool varlibqubes
vid vm-templates/whonix-gw-16/root
rw True
source
save_on_stop True
snap_on_start False
size 21474836480
usage 2338689024
revisions_to_keep 1
ephemeral False
is_outdated False
Available revisions (for revert):
4
So, here’s my question: How can I specify one revision for qvm-volume revert on btrfs? Thanks.
