QubesOS test media always fails
I have now done the same again with a Fedora-Workstation-Live-x86_64-40-1.14.iso USB stick and have found that this USB stick has NOT been changed… it only happens with the mentioned QubesOS iso’s.
fedora_stick_before.txt:
fdisk output:
Disk /dev/sda: 28,48 GiB, 30579621888 bytes, 59725824 sectors
Disk model: Transcend 32GB
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: BD0CE27D-A6E0-4C37-BEEC-AB4B6F9B6A73
First usable LBA: 64
Last usable LBA: 4484024
Alternative LBA: 4484087
Partition entries starting LBA: 2
Allocated partition entries: 248
Partition entries ending LBA: 63
Device       Start     End Sectors Type-UUID                            UUID                                 Name      Attrs
/dev/sda1       64 4457875 4457812 EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 BD0CE27D-A6E0-4C37-BEED-AB4B6F9B6A73 ISO9660   RequiredPartition GUID:60
/dev/sda2  4457876 4483423   25548 C12A7328-F81F-11D2-BA4B-00A0C93EC93B BD0CE27D-A6E0-4C37-BEEE-AB4B6F9B6A73 Appended2
/dev/sda3  4483424 4484023     600 EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 BD0CE27D-A6E0-4C37-BEEF-AB4B6F9B6A73 Gap1      RequiredPartition GUID:60
hash values:
41018ba9a13676587c2257fe79a060e3e84a8d870b1293f8c4e8b86489659b6e  /dev/sda
1e0b1d3fcd72745fb9161caa7583c7735a41f8db0a32edda3d3377e7031a5536  /dev/sda1
168495da4363d64e162d6966059bcf3a2c889adb7f66e20bd055426b07c92ad0  /dev/sda2
7818f5542a0404157573be6cffc0e0c8e68ce3c0f5d17d07ccdd9313fb700baf  /dev/sda3
fedora_stick_afterwards.txt:
fdisk output:
Disklabel type: gpt
hash values:
It seems that the BIOS (?) in PC-A changes the bootable partition from second one to first one in legacy MBR reserved space in GPT:
Based on the fdisk output the first partition should be bootable (LegacyBIOSBootable), but in the legacy MBR it’s set to second partition.
Maybe the BIOS in PC-A is trying to fix the partition table forcefully.
Maybe related issues:
Document workarounds for installing Qubes on legacy BIOS systems · Issue #8732 · QubesOS/qubes-issues · GitHub
Qubes R4.2-rc4 does not work with UEFI boot · Issue #8717 · QubesOS/qubes-issues · GitHub
Qubes R4.2.0-rc2 cannot be installed on legacy BIOS system · Issue #8462 · QubesOS/qubes-issues · GitHub
Installation image doesn't boot in legacy mode on some systems · Issue #8058 · QubesOS/qubes-issues · GitHub
So it is setting the bootable flag for special (EFI) partition and clearing the bootable flag for 2nd partition. This is really bizarre.
Qubes ISOs are using a regular parition table. Whereas Fedora ISOs (as well as Archlinux) are using ISO9660 El Torito, emulating a DVD disk. So the Fedora flash is not modified.
I don’t understand why it does that, but at least it’s not harmful, at least not if you don’t want to install QubesOS in Legancy mode.
But that doesn’t quite explain why only Qubes-R4.2.1-x86_64.iso - Qubes-R4.2.2-x86_64.iso is affected and Fedora-Workstation-Live-x86_64-40-1.14.iso and Qubes-R4.2.0-x86_64.iso e.g. is not.
I guess this is the related change:
This coversation was started on Nov 24, 2023 but the Qubes-R4.1.0-x86_64.iso i used for testing is from 2022-02-04 19:44.
Check the Qubes-R4.2.0-rc1-x86_64.iso and Qubes-R4.2.0-rc2-x86_64.iso images:
https://mirrors.edge.kernel.org/qubes/iso/
Or Qubes-R4.2.0-rc4-x86_64.iso and Qubes-R4.2.0-rc5-x86_64.iso images.
i’m sorry that i’m only replying now i only had a little time.
I have tested both, Qubes-R4.2.0-rc1-x86_64.iso and Qubes-R4.2.0-rc2-x86_64.iso with CSM support activated and both have passed and are not changed.
Can you try newer images to know which release introduced this issue and try to narrow it down?
yes, but that will take some time :slight_smile:
I have similar problem.
Turns out my InsydeH2O BIOS making some empty folders in the EFI Partition of a bootable USB sticks, presumably because it auto-checks for BIOS recovery files and this can’t be disabled.
I am really sorry for the late reply, but I have had some bigger problems in the last time.
I re-tested all the images under the same conditions and these are the results, if anyone is still interested:
iso state
Qubes-R4.1.2-x86_64.iso N/A
Qubes-R4.2.0-rc1-x86_64.iso PASS
Qubes-R4.2.0-rc2-x86_64.iso PASS
Qubes-R4.2.0-rc3-x86_64.iso N/A
Qubes-R4.2.0-rc4-x86_64.iso N/A
Qubes-R4.2.0-rc5-x86_64.iso FAIL
Qubes-R4.2.0-x86_64.iso PASS
Qubes-R4.2.1-rc1-x86_64.iso FAIL
Qubes-R4.2.1-x86_64.iso FAIL
Qubes-R4.2.2-rc1-x86_64.iso FAIL
Qubes-R4.2.2-x86_64.iso FAIL
