Hello. After doing a fresh install of QubesOS 4.1, I decided to follow the documentation’s “How to Update” page. I also wanted to do the update using the Command-line interface, as described here.
However, running the first ever command, which is:
$ sudo qubesctl --show-output state.sls update.qubes-dom0
returns a [WARNING ], regarding a library with python3, and specifies “Runtime warning: line buffering (buffering=1) isn’t supported in binary mode, the default buffer size will be used”
The command takes a few minutes to execute, and during execution there occurs 4 or 5 notifications on the XFCE notification upper right hand side of the screen about some of the qubes (whonix, and some other I guess).
After that the command finishes executing with the state:
Summary for local
Succeeded: 4 (changed=1)
Failed: 0
Total states run: 4
Total run time: 380 s
My question is, is that [WARNING ] that the terminal spits out right after issuing the comand normal, benign? Also, are the flashing XFCE notification boxes during execution warning something about some of the qubes OK/nothing to be worried about?
Thanks.
