Qubes won't decrypt if the password was not typed correctly on the first try
When I boot up Qubes OS and enter my password, if I don’t type it correctly on the first try, I receive a common error related to regenerating the initram. The logs indicate that there is an exception thrown due to mismatched credentials. What could be causing this issue, and how can I resolve it?
To clarify, if password typed in correctly from the first time, it will decrypt fine, otherwise error mentioned above, so I basically have to reboot each time I enter a wrong password.
You could report this on the GitHub repository as an issue if it does not exist yet.
You could, but we would need far more information.
On none of the machines I administer is this an issue - there is always
a chance of retyping the password. Sometimes 2 or 3 times.
Is it dependent on timing? Possible.
I will collect additional information and share the logs. For now, it seems that the timing is not related to the problem. I have been experiencing this issue consistently for a long time, and it continues to occur even after performing clean installations of Qubes OS. The behavior is exactly as I have described.
Thanks - I wonder if it is a hardware issue?
If you hit Esc at password prompt you should drop to console input.
What happens if you type the pw incorrectly there?
