Qubes-Whonix RDP & Another question
I tried to use Remmina RDP with Qubes-Whonix and only SSH and SFTP show up.
Second question, I originally used Debian template and qubes-whonix as the network connection, and it worked for RDP. But i did an IP test and it showed my home IP on Firefox (what the fuck!!!). I thought since i used qubes-whonix networking all my traffic was sent through Tor?
I need to be able to access a non-Tor IP, but still be anonymous.
All answers appreciated.
What do you mean by “only SSH and SFTP show up”?
I never used Remmina so I don’t know much about it.
Did you set the net qube for app qubes based on a Debian template to sys-whonix?
There is a drop down menu, with the different protocols you can use, this time only SSH and SFTP showed up.
“Did you set the net qube for app qubes based on a Debian template to sys-whonix?”
I do not know what this means, can you please elaborate more? Thanks.
The qube connect to the network using the net qube configured in its Settings.
For example, if you open the personal qube’s Settings (Q → APPS tab → personal → Settings) → Basic tab and the “Net qube:” is set to the sys-firewall or sys-net then your personal qube will connect to the network through clearnet. If you change the net qube to sys-whonix, then it’ll connect to the network through Tor in Whonix Gateway qube.
Read the guides about Qubes OS first:
Introduction | Qubes OS
Getting started | Qubes OS
How to organize your qubes | Qubes OS
It says the net qube is sys-whonix. There was a yellow cautin triangle warning me of something, but I changed it in advanced and now it is gone, basically default disposable template. I changed them to sys-whonix for both.
And if you do the IP test in these qubes with sys-whonix net qube now you’ll see your home IP?
Think its fixed. Also seeing RDP on Remmina. Do you know why that yellow triangle was there? Could that have caused IP leaks?
I don’t know where did you see it or what did it warn you about.
If you point the mouse cursor at the yellow triangle and wait a bit then it’ll show you a hint with a message.
Its gone now, but it said something along the lines of default disposable template being different.
