Maybe it's related to recent updates, or my computer is starting to die: Anyway: Today I had plugged in my USB stick and attached it successfully to "vault". I had opened a file from it. The suddenly within one second, I saw the stick being disconnected and reconnected, and the "vault" failed to write the file.
Questions:
1) Is that disconnect expected?
2) Is it expected the a disconnect/reconnect uses a different disk (xvdj vs. xvdi)?
3) Is it expected that the partitions appear twice in the file manager (see attachment)?
that happens also when a "bad electrical connection" happens (worn out
usb plug, for example). Then the usb-"attach" breaks, but the virtual
device number (xvd..) i still blocked, so a reconnect increases the
number (from i to j to k). etc. That is not "expected" but happens.
I would power down sys-usb and vault and try again. And I would not take
data from usb into vault, rather from usb into a dispVM first, if you
need to grab data into vault: There you can still perform (integrity)
checks before copying them to vault...
