which works great, but I would like to force package updates to also use a wireguard connection. I’m not quite sure what to alter to do this. Any help would be much appreciated.
The default is for updates to run in sys-net.
You need to change this by changing the policy - look in `/etc/qubes/policy.d/90-default.policy`
for the `qubes.UpdatesProxy` lines, and then create a new policy in
`/etc/qubes/policy.d/30-user.policy` like this:
`qubes.UpdatesProxy * @type:TemplateVM @default allow target=QUBE`
where QUBE is the name of the qube you want to use.
If you use Whonix you will need to copy the relevant Whonix lines also.
