Once I connect to a wifi network I’m unable to ever re-use that connection again. If I select the SSID it creates a 2nd (or Nth) connection to that network. It looks like network settings in xfe/gnome also don’t allow any way to connect to a network, only configure it.
I’m used to KDE is there something I’m just missing in how xfe/qube manages connections?
Maybe examine a previously working connection’s WiFi tab & the Device line for uniqueness. The trouble is variability of reference, I think. Say you see wlan0 or wifi0 plus a MAC? Try changing that to simply the device’s MAC (no snappy name, this is part of what I suspect the problem is), just the MAC for the device & save then attempt to activate the connection.
